StillA0 Posted June 26, 2022 Posted June 26, 2022 The charging cradle is not working, so my BTech V-1 is dead. Short of buying a new charging setup is there a way I can charge the radio? Quote
0 SteveShannon Posted June 26, 2022 Posted June 26, 2022 One alternative is to figure out why it’s not working. Use a multimeter and troubleshoot it. Is it the base or is it the power supply? Many of the power supplies are interchangeable. I have four different handheld radios and three of them use wall warts that can be directly interchanged to use with each other’s charger bases. WRQJ683 1 Quote
0 StillA0 Posted June 26, 2022 Author Posted June 26, 2022 I did troubleshoot with the multimeter. The power supply worked (same power supply that comes with UV-5R's). But the base was not working. With the UV-5Rs the red light on the base comes on and after awhile it starts to flash red / green until the battery in fully charged. With the BTech base no power at the studs and no lights. The charging set up is almost a third of the price for a new V-2. Quote
0 SteveShannon Posted June 26, 2022 Posted June 26, 2022 Then troubleshoot the base. You may be able to compare its circuit to the Baofeng base circuit. They might even be the same inside. Quote
0 wayoverthere Posted June 26, 2022 Posted June 26, 2022 If you're willing to go ebay, does this look like your charger? https://www.ebay.com/itm/274907781614 That said, if you want to jump to a new radio it isn't a bad time. Quote
0 KAF6045 Posted June 26, 2022 Posted June 26, 2022 Looks a lot like mine does... I currently have three of them as the GMRS-V1, MURS-V1, and GMRS-V2 all use the same batteries. I might suggest the OP grab one, along with the -V2 (since any memory channel can be used for GMRS configurations -- useful if multiple repeaters on same frequency but with different CTCSS codes) I do hate their LED modes. No battery: flicker red/green to cause epileptic seizures Really dead battery: Red (the only time I've seen solid red was when I had the radio itself shut down from low battery) Partially charged battery: flicker red/green (duty cycle between red and green seems to track with level of charge) Fully charged battery: Green (though it takes hours to get to that point, even an overnight charge had mostly green with quick red flashes) wayoverthere 1 Quote
0 wayoverthere Posted June 26, 2022 Posted June 26, 2022 19 minutes ago, KAF6045 said: Looks a lot like mine does... I currently have three of them as the GMRS-V1, MURS-V1, and GMRS-V2 all use the same batteries. I might suggest the OP grab one, along with the -V2 (since any memory channel can be used for GMRS configurations -- useful if multiple repeaters on same frequency but with different CTCSS codes) I do hate their LED modes. No battery: flicker red/green to cause epileptic seizures Really dead battery: Red (the only time I've seen solid red was when I had the radio itself shut down from low battery) Partially charged battery: flicker red/green (duty cycle between red and green seems to track with level of charge) Fully charged battery: Green (though it takes hours to get to that point, even an overnight charge had mostly green with quick red flashes) as i understand, all three are based on the uv82/uv82c hardware, so i'd expect them all to be interchangeable. on the LEDs, i wonder if they're trying to copy the commercial stuff with that. my vertex stuff goes from solid red to green flash when it's 90% charged, and then solid green at 100%. my uv5r/bf-f9 cradles do the fast red/green for no battery, but otherwise solid red for charging, or solid green when charged. Quote
StillA0
6 answers to this question
