WQZQ295 Posted September 8, 2022 Report Posted September 8, 2022 Question; I have a Retevis RT97 and a copper J-pole antenna for GMRS. Can I use them together without any issues. If so, what are the advantages and disadvantages? Just looking for options! Quote
WRUC860 Posted September 8, 2022 Report Posted September 8, 2022 Provided the antenna is properly tuned to the GMRS frequencies AND your cable/connector losses are low, you should see a marked increase in Rx and Tx over "some" 1/4 and 1/2 wavelength antennas. There is a lot of math and physics that go into any perceptible difference in distance and quality of comms. Probably the most important element to consider is "line of sight" based on your height ASL. Good luck WQZQ295 1 Quote
gortex2 Posted September 9, 2022 Report Posted September 9, 2022 I would not. Buy a real antenna and cable. The antenna is the most important part of a repeater. Manage expectations. You wont talk 50 miles with a JPole (well unless your at 5000'). Remember the RT is low power =/- 5 watts. Shorted antenna line and antenna they better. WQZQ295 1 Quote
SteveShannon Posted September 9, 2022 Report Posted September 9, 2022 On 9/9/2022 at 12:51 PM, gortex2 said: I would not. Buy a real antenna and cable. The antenna is the most important part of a repeater. Manage expectations. You wont talk 50 miles with a JPole (well unless your at 5000'). Remember the RT is low power =/- 5 watts. Shorted antenna line and antenna they better. Expand So a j-pole isn’t a “real antenna?” What’re the deficiencies? (Genuine interest- I have a lot of copper pipe and thought I’d experiment) WQZQ295 1 Quote
SteveShannon Posted September 9, 2022 Report Posted September 9, 2022 On 9/9/2022 at 5:08 PM, Sshannon said: So a j-pole isn’t a “real antenna?” What’re the deficiencies? (Genuine interest- I have a lot of copper pipe and thought I’d experiment) Expand I probably answered this myself. “The efficiency of a j antenna falls off rapidly as the operating frequency is raised.” https://books.google.com/books?id=_lUrAQAAMAAJ&pg=PA141&lpg=PA141&dq=quarter+wave+whip+vs+zepp&source=bl&ots=NaZVS10MdL&sig=ACfU3U3ZksxDFNcMl90bI_yGzoXgOg_KHQ&hl=en&sa=X&ved=2ahUKEwjg9-WLm4j6AhXMJDQIHW-5B4AQ6AF6BAg2EAI#v=onepage&q=quarter wave whip vs zepp&f=false WQZQ295 1 Quote
WRFP399 Posted September 9, 2022 Report Posted September 9, 2022 Eh, I had/have an RT97 that I use with a roll up J-Pole from N9TAX. Ideal? No, but it does work well with height. WQZQ295 and SteveShannon 2 Quote
