Luish19779 Posted October 24, 2022 Report Posted October 24, 2022 Hi everyone. I just want to know if I have to change this 2 Code from 23? I got some problem when I hit the repeater. Thanks Quote
0 OffRoaderX Posted October 24, 2022 Report Posted October 24, 2022 What kind of problems are you having hitting the repeater, and what are the correct codes for the repeater? Luish19779 1 Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 I hit the repeater, but I not have audio or modulation are really low. I connect my GMRS 9R to chirp and I hit properties and I see all that. The Rx Tone is 85.4 & Tx tone 229.1. Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 If I have to add something, let me know brother. Thanks for your time. nice catch with the Fox Hunt.. Quote
0 OffRoaderX Posted October 24, 2022 Report Posted October 24, 2022 In your image, you have the RX and TX tones set to 23, so I'm not understanding how you're even hitting it.. The only setting that would affect YOUR modulation is the bandwidth, so make sure the radio is set to WIDEBand. If you are receiving no audio from the repeater, then replacing the incorrect tone of 23 with the correct tone of 84.5 would help so give that a try. Luish19779 1 Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 Thanks for the help Randy Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 Now I have the Rx &Tx Tone, but the question is, the 23 on DTCS & Rx DTCS Tone keep with the 23? Quote
0 Photoman5k Posted October 24, 2022 Report Posted October 24, 2022 what program are u using to program the radio? nevermind i just caught you said chirp. Just to verify the Rx tone is 85.4 and the Tx tone is 229.1 correct? Quote
0 Photoman5k Posted October 24, 2022 Report Posted October 24, 2022 I dont normally program from the properties like that. I programed a channel into my radio using the freq and rx tx code. if i open up the memory properties mine looks like this. Frequency: 462.625 Name: RPT18 Tone Mode: Cross Tone: 229.1 ToneSql: 85.4 Tone Mode: Tone->Tone DTCS Tone: 23 Rx DTCS Tone: 23 DTCS Pol: NN Duplex: + Offset: 5.000000 Mode: FM Skip: Power: High Luish19779 1 Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 This setting #41, is right o I have to change it? Quote
0 KAF6045 Posted October 24, 2022 Report Posted October 24, 2022 17 hours ago, Luish19779 said: Hi everyone. I just want to know if I have to change this 2 Code from 23? I got some problem when I hit the repeater. Thanks I'd be concerned at having a "cross mode" specified, but that may just be how CHIRP shows it. The key criteria is "Tone Mode". The displayed window (I've never used the "property" page, just edited in line on the spreadsheet layout) shows you have "TONE" selected. That choice means you are SENDING a CTCSS tone, but do not expect one on receive. If you need a receive tone, the mode needs to be TSQL. DTCS entries are ignored. "Tone Mode" of DTCS would mean the DTCS entries are active, and the tone/tonesql entries are ignored. 1 hour ago, Luish19779 said: This setting #41, is right o I have to change it? That looks to be the Tone-Burst setting (menu #40 on my BTech units). I don't know of any GMRS system that requires tone-burst (and don't even know of a US Amateur repeater that uses it). Tone Burst is common in the UK and likely the rest of Europe on Amateur repeaters (they don't have GMRS services). To "wake up" a repeater, one has to first send (often using a dedicated button on the radio) a few seconds of the required tone-burst (1750 seemed to be the value used for most UK repeaters). After the repeater is awake, regular PTT activity keeps it alive. After a pause (no PTT) of a few minutes, the repeater goes back to sleep. On the BTech, the tone-burst is sent using [F]+[PTT] WRUU653 and Luish19779 2 Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 I hit the repeater, but I got problems with the audio. I try on simple and I don’t have any problems of modulation or audio. Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 My radio is Baofeng GMRS 9R. Quote
0 Photoman5k Posted October 24, 2022 Report Posted October 24, 2022 1 hour ago, KAF6045 said: I'd be concerned at having a "cross mode" specified, but that may just be how CHIRP shows it. Thats just how chirp does it for some reason, even if it's tone->tone it lists it as cross though strangely not always. not sure why either. Quote
0 Luish19779 Posted October 24, 2022 Author Report Posted October 24, 2022 thank you very much for your help. my question is, is that the correct way to configure a gmrs repeater? Those tones are from the repeater. Quote
Luish19779
Hi everyone.
Thanks
15 answers to this question
