  • 2 weeks later...
What's funny is at this timestamp it mimicks a traditional seven-segment-display layout like the Midland units have.  However, at forty seconds:
We can see that it's actually a matrix LCD, because it simply says "WIDE BAND" across the display rather than being some obscure numerical code.  This makes the menus far clearer, and reduces the need to carry the manual around 24/7 in your glove box.
OK. I guess so but I've never needed a manual to do anything in my midland. I dont see anything other than the "wide band" that the midland downs show on the display. I think the mic on the midland is also a bit more conforming to the hand but sure they will sell some to the CCR world.
  • 1 year later...
I wanted to comment on the Retevis RA86, have it in the 4runner and I really like it.  Things I don't like, doesn't have channel naming ability through the program software, so have to have a laminated small cheat sheet when looking for an odd or new channel.  You can not, I repeat, can't extend the MIC with a CAT5 or CAT6 cable, it makes a ticking sound.  I have trouble shot this for hours, put the radio on my base power supply and antenna, etc.  I also talked to Retevis, they are sending me an extension cable that will work, but I let them know that isn't optimal if you want a clean dash punch out CAT6 Port.
Things I like, it just works, it is super easy and simple. The main unit is small and fits nicely under the driver's side dash.  Tested power, it was right under 20W at the GMRS frequencies.  Cheap....., if you order from Amazon for 110 bucks, it comes with the programing cable, so you don't need to purchase one.  I didn't know that so I also bought a second cable that I don't need if anyone wants one.
It has narrow and wide band, Midland doesn't.  That extra 5 watts is nice.  If anybody has any specific questions about this radio, I will be happy to give you the insight.
  • 4 weeks later...
I just got one last week, but haven't had a chance to use it much. So far I'm not able to get my computer to program it with the Retevis software.  I should add, I hate computers, so there's that, lol.  Anyway, I can't write to the radio from the software, which is inconvenient, as I need it for the cts tones that aren't listed in the manual, i.e. 114.8.  Could be my computer.  It is Windows 10, but it's getting old.  Wish it were as easy as my Wouxun KG 935g+
Generally I don't help others with radios I do not use, since so many others here with this radio can help you. But not here yet...
So I looked at their downloads and first is the USB cable driver for windows 10 and 11 and then the CPS software.
At what point do you fail?
On 2/3/2023 at 3:03 PM, Duck218 said:
Anyone try this radio out yet?
Retevis RA86
Looks like it may give some better options vs the Midland mxt275.  Wideband and possible more channels.  Looks interesting.
Well normally I’d say ANYTHING is better than midland but retivis is waaaay down on the list as well.  One is waay over priced and the other is still over priced.  One well work ok and one doesn’t work well at all.   There are much better radios available for the same or less money with the same or more features.
I recently got a RA86 and it’s worked great so far. The programming software was easy to use. I’m using a ghost antenna with it. The rinky dink antenna that came with it, left a lot to be desired!
Posted (edited)
That's interesting, I thought I had see good reviews on that antenna. Maybe I'm thinking of a different one.
Edit:
Just remembered, it was probably the small one from Midland that got good reviews.
Edited by WRXB215
Added info.
Edit:
I got a lot of static with the antenna that came with it.
  • 2 months later...
Can you program additional channels into this radio.  In the Houston/Galveston area there are many repeaters with at least 2 repeaters for each channel.  They each cover different areas though.  I think at last count there were close to 20.  I would like to be able to program most of those repeaters into the radio.
On 4/26/2024 at 11:22 PM, AmanGMRS said:
New stock Midland MXT275 does have wideband set for the repeater channels.
I can confirm this. My Midland MXT275 isn't even all that new. It's the USB-C version, but I bought it sometime in late 2021 or early 2022, I think. I've looked at the spectrum with SDR++ using an RTL-SDR BLOG v4, and it appears wider when I watch the repeater input frequencies while transmitting on 15R-22R than when transmitting on 1-7 or 15-22. Additionally when I receive a signal on 15R-22R it is a little quieter than when receiving on 15-22, which is another phenomenon that can be explained by a switch in RX bandwidth.
It was a PITA to test. Had to drive far enough away to avoid loading up the SDR's inputs. And I had to do it twice since repeater inputs are 5MHz above outputs, and the SDR's bandwidth is 2.4MHz.
  • 11 months later...
I know the last post was almost a year ago. I just received my RA86 with an antenna upgrade over the little one. Here is my findings.
It comes with privacy tones pre-programmed. You can delete them by turning the radio on while holding the PTT and Scan buttons.
You can program up to 99 channels, simplex or repeater. After programming repeaters, you need to turn on the repeater function from any channel. I programmed some public safety frequencies, but the RA86 will not allow the program to install the transmit frequency. This is where labeling the channel would be nice, but it doesn't have the capability.
The setting scan is done from the microphone. If you update the radio, you have to start over and set the scan and repeater functions. Scroll using the menu button and change the selected setting with the volume buttons, press menu again, and then wait for it to time out.
I downloaded both the programming software and driver from the Retevis website. I needed the driver for the programming software to work.
Reply to this topic...
