WRPQ991 Posted February 12, 2023 Report Posted February 12, 2023 I'm hearing a repeater Loud and Clear, it says "welcome to the military repeater", I should be able to reach it as I'm less than 5 miles from FT Hood. But so far nothing..It transmits the same message about every 30 minutes or so...Is there any way to find out if it uses input or output tones? Or any information? Its on 462.550 Ch15 Also while scanning this morning I spoke with a ham operator about 12 miles away, who was just playing on the GMRS band... Quote
SteveShannon Posted February 12, 2023 Report Posted February 12, 2023 16 minutes ago, WRPQ991 said: I'm hearing a repeater Loud and Clear, it says "welcome to the military repeater", I should be able to reach it as I'm less than 5 miles from FT Hood. But so far nothing..It transmits the same message about every 30 minutes or so...Is there any way to find out if it uses input or output tones? Or any information? Its on 462.550 Ch15 Also while scanning this morning I spoke with a ham operator about 12 miles away, who was just playing on the GMRS band... If you’re that close to the repeater you may be able to listen to the repeater input frequency which is probably 467.550 MHz. Then, if someone uses the repeater you can scan for the input tone. WRUU653 1 Quote
gortex2 Posted February 12, 2023 Report Posted February 12, 2023 It may not be an open repeater. Just because its there doesn't mean its available for your use. The map shows one in Temple that is open. Hopefully the ham was using a valid GMRS call sign. kmcdonaugh 1 Quote
nokones Posted February 12, 2023 Report Posted February 12, 2023 11 hours ago, WRPQ991 said: I'm hearing a repeater Loud and Clear, it says "welcome to the military repeater", I should be able to reach it as I'm less than 5 miles from FT Hood. But so far nothing..It transmits the same message about every 30 minutes or so...Is there any way to find out if it uses input or output tones? Or any information? Its on 462.550 Ch15 Also while scanning this morning I spoke with a ham operator about 12 miles away, who was just playing on the GMRS band... There is a 550 repeater near the west end of Santa Anna Mtn using 141.3 Hz in/out. Quote
WRWD373 Posted February 12, 2023 Report Posted February 12, 2023 Just about every military base I have ever been to has a radio club. Check out the Ft Hood MWR website or Facebook account to see if they have a base funded repeater. 99.9% of the time, they are happy to have local residents volunteer/donate/participate at events...especially if they are held off base. It helps to get the young, homesick soldiers/airmen/sailor/marine OUT of their dorm and out in the community. It helps morale, and probably lowers disciplinary actions too, I'd guess. I'd be very, very surprised if it was a bunch of comm guys setting up their own repeater and locking out the community. They wouldn't be using GMRS if that was their intention SteveShannon and kerstuff 2 Quote
