Wouxun KG-1000G Plus Faceplate Mounting
Stiemey
Recently got my hands on a KG-1000G Plus and want to mount it in my 2021 Ram 1500 to replace my Midland MXT575.  I have a Bulletpoint Mounting RubiGrid with three ball mounting points.  Bulletpoint does not have an adapter for the KG-1000G+ (however I have asked them to develop one) so I am looking for a way to mount the faceplate on the dash.  Any and all suggestions are appreciated.
5 answers to this question
What kind of mounting plate does the kg1000g use?
Off the top of my head, I'm thinking either using one of the dual socket arms and screwing the camera post ball into the faceplate's mounting plate.
https://www.amazon.com/s?k=20mm+ball+mount
Other than that, will the phone mount go small enough to work?
Same radio here,  I have the RAM ball mounts left over from a motorcycle handlebar project... they make all kinds https://rammount.com/pages/components
Some folks used a cup holder mount.  Mine is in a 22 Chev PU.   Used the KG 1000+ flat plate and mounted directly to one ball head.  Installed a second head on the console with a arm that swivels to any position you like.   I'm sure there are some knock-offs now.  I'd post a picture but the truck is in the shop.
Something on my to-do is to add an RJ-45 coupler just behind the head where I can unplug the cable running to the base under the seat.
Google found me a couple other options that aren't directly using the bulletpoint mount...
Panavise appears to have a few options depending on the details of the truck (and dash screen)
https://www.panavise.com/index.html
Proclips also has a couple for left or right side of the dash near the HVAC vents.
https://www.proclipusa.com/products/855441-proclip-angle-mount-dodge-ram-2019-20xx
I added a couple shots from my truck (ham setup); this is the icom mounting plate on a panavise bracket that tucks in between the HVAC controls and the trim.
I followed @wayoverthere’s advice and got a ProClip for my RAV4 and KG-1000G:
I just had to drill a 2nd hole to match the middle holes in the head unit.  The mic hangar is just a metal hangar with the 3M sticky on the back.  I think it's similar to this one at WalMart. (can't remember where exactly I ordered it from)
