Hi all, I just purchased a Nagoya NA-701G to play with for my Baofeng UV-9G. I wanted a shorter antenna than the dual-band stock antenna that was specific for GMRS. I have found that the local police frequencies I was listening to (~131 MHz) are not received as well as using the stock antenna. Would this be because the Nagoya is tuned for GMRS, and is much less sensitive versus the dual-band stock antenna when used outside the GMRS frequencies? Seems like the obvious answer, but not sure. Thank you.
back4more70
3 answers to this question
