VETCOMMS Posted March 13, 2023 Report Posted March 13, 2023 I've read that Windows XP, Windows 10 can be found at garage sales for cheap. Where else do people get laptops with the older operating systems to use for programming discontinued repeater models? Quote
SteveC7010 Posted March 13, 2023 Report Posted March 13, 2023 I found a refurbished Panasonic Toughbook with a new install of XP for $125 on Ebay a couple of years ago. It has a true COM 1 serial port and works perfectly for Waris, Commercial, M1225, and many Radius models plus older Vertex, Icom and more. VETCOMMS, gortex2 and WRKC935 2 1 Quote
WRKC935 Posted March 13, 2023 Report Posted March 13, 2023 Best investment you can make if you are going to get into working on radios seriously. Another piece of advice. Have someone reload the machine with DOS 6.2 then reload Windows XP for DUAL BOOT. Some of the older radios never had a Windows version of programming software and you will have to use DOS to run the programming application. SteveC7010 and VETCOMMS 1 1 Quote
WRQC527 Posted March 15, 2023 Report Posted March 15, 2023 I run Windows 10 on a desktop. I have several 30-40 year old Motorola Quantar repeaters. I just installed the "old" software on the desktop that loaded in a compatibility mode and using a 9-pin null modem cable, I successfully programmed one of the Quantars. We'll need to use an RS232-to USB adapter with a laptop for remote work. Quote
Lscott Posted March 15, 2023 Report Posted March 15, 2023 2 hours ago, JB007Rules said: Ebay - Old Toughbook. I found some nice functional desktops while walking at night through an apartment complex. They were just sitting on the ground next to the dumpster. Can't beat free. Some still had the hard drive installed with the OS on it. Quote
nokones Posted March 15, 2023 Report Posted March 15, 2023 I'm getting a Windows 8 from eBay for programming my Vertex Standard EVX R70-G7-40 Repeater. I have a very old Sony that was a originally a Windows ME machine that I had a computer Geek reformat it with DOS 6. something that I use for my HT1000, MT2000, and older version MTS2000 radios. I use a HP Pavillion Laptop with XP for my newer version MTS2000, and my Astro XTS3000. I use a Windows 11 laptop for my Astro 25 XTS 1500, XTS2500, and XTS5000 series, Midland MXT500, and my Wouxun KG1000G Plus radios. Quote
WRKC935 Posted March 15, 2023 Report Posted March 15, 2023 3 hours ago, WRQC527 said: I run Windows 10 on a desktop. I have several 30-40 year old Motorola Quantar repeaters. I just installed the "old" software on the desktop that loaded in a compatibility mode and using a 9-pin null modem cable, I successfully programmed one of the Quantars. We'll need to use an RS232-to USB adapter with a laptop for remote work. Yes, Quantars will work like that. MTR2000 software however doesn't, or at least I never had any luck with it. MTR2000 software, Astrospectra /XTS 3000's needed something older as well. You get into the old 3 digit model number Kenwoods and the Maratrac / Maxtrac / Spectra Motorola's and you are DOS only. But the software will run on a fast machine. The stuff that's older than that generation like the Syntor's needed a 386 / 486 at MAX to program them. I actually have an old 286 for the oldest stuff. Not even sure if it works any more. Those old MFM and ESDI drives could have the heads stick to the platters of the drives if they sat too long. I haven't done any work on that old equipment in 10 or more years. But I maintain the ability to or at least try to maintain it. And I have seen older Motorola radios get bricked by people trying to use Windows XP and a DOS window to program them. For some old mobile or HT, so what, you're out 30 bucks for another radio. Got brick an MTR or older Kenwood repeater and things get a bit more serious and costly. WRQC527 1 Quote
VETCOMMS Posted March 16, 2023 Author Report Posted March 16, 2023 Ahhh heck, I should just buy a brand new Motorola repeater and pony up the cash so I can just use my current Windows operating system, I suppose. Quote
VETCOMMS Posted March 26, 2023 Author Report Posted March 26, 2023 Or after seeing what a new Motorola costs..... Which is easier to program, an MTR2000 or a GR1225? Quote
gortex2 Posted March 26, 2023 Report Posted March 26, 2023 Both are easy to program. Both are windows based but wont run on W10/11. I run both on an old w95 pc VETCOMMS 1 Quote
VETCOMMS Posted March 28, 2023 Author Report Posted March 28, 2023 On 3/26/2023 at 4:02 PM, gortex2 said: Both are easy to program. Both are windows based but wont run on W10/11. I run both on an old w95 pc Understood, thanks. I think I've read the GR1225 can be programmed with Windows XP and in other places I've read Windows 7 will work as well. For the MTR2000 I think I've read Windows 7 works. I just want to be clear on what I need for a programming computer before I purchase the repeater. Also, would someone with real world experience be able to help me with programming once I purchase the repeater or what resources are there to help me? I see limited videos about how to do this but perhaps these come with a user manual that is excellent at describing how to program the repeater? Just trying to be prepared before the purchase. Quote
gortex2 Posted March 28, 2023 Report Posted March 28, 2023 I have used XP on both versions. I never had luck with either on W7. I still have multiple old units for programming stuff. My Toughbook has dual boot XP and 95 for alot of it. Once you have a codeplug its simple to do. MTR requires a special cable thats a bit different but is out there. GR1225 uses same cable as M1225/CDM etc. I still use a rib on my GR1225 radios. MTR is straight 9 pin to comm port. VETCOMMS 1 Quote
nokones Posted March 28, 2023 Report Posted March 28, 2023 After programming my Vertex Standard EVX R70-G7 repeater it would appear that there's not much to programming other repeaters, its not like programming a mobile or portable with tons of features. I assume most repeater have very few programming parameters such as, TX & RX freqs and tones, analog or digital emissions, power level, TOT, and hang time. Repeaters should be a piece-of-cake, insofar as programming. Just make sure that the duplexer is properly tuned and you build your cables with quality low-loss coax cable, and connectors. SteveShannon and VETCOMMS 2 Quote
