vefrancis Posted April 12, 2023 Report Share Posted April 12, 2023 New to GMRS, so be kind. Does GMRS have Weather channel frequencies? If so, What are they? Thanks in advance Quote Link to comment Share on other sites More sharing options...
WRQC527 Posted April 12, 2023 Report Share Posted April 12, 2023 40 minutes ago, vefrancis said: New to GMRS, so be kind. Does GMRS have Weather channel frequencies? If so, What are they? They're in the VHF spectrum. 162.400, 162.425, 162.450, 162.475, 162.500, 162.525, 162.550. Depending on your radio, you *might* be able to access them. The famous Baofeng UV5R, for example, can receive both UHF and VHF frequencies and can be programmed with those frequencies. Quote Link to comment Share on other sites More sharing options...
back4more70 Posted April 12, 2023 Report Share Posted April 12, 2023 Welcome. GMRS does not have weather frequencies, but your radio can most likely receive the NOAA frequencies if you set them up. Some radios also have them already programmed in. Quote Link to comment Share on other sites More sharing options...
WRWE456 Posted April 13, 2023 Report Share Posted April 13, 2023 So which radio are you using? I have the Wouxun KG-935G Plus and it receives vhf/uhf and has the weather frequency's built in. I also love being able to use it to scan the local Sheriff, Fire and EMS. So as mentioned not a GMRS feature but a few radios do have the capability. Quote Link to comment Share on other sites More sharing options...
Lscott Posted April 13, 2023 Report Share Posted April 13, 2023 6 hours ago, vefrancis said: New to GMRS, so be kind. Does GMRS have Weather channel frequencies? If so, What are they? Thanks in advance The official NOAA weather channel frequencies are on VHF. However some have discovered that the studio to transmitter site audio link at times is done on selected UHF frequencies. You can look at the attached file and see what kind of luck you have with it. NOAA UHF Weather Link Frequencies.pdf fe2o3 and WRUU653 1 1 Quote Link to comment Share on other sites More sharing options...
vefrancis Posted April 13, 2023 Author Report Share Posted April 13, 2023 Thanks everyone. I have a Wouxon 905 and have entered the channel frequency 162.400. Thanks again Quote Link to comment Share on other sites More sharing options...
WRUU653 Posted April 13, 2023 Report Share Posted April 13, 2023 13 hours ago, Lscott said: You can look at the attached file and see what kind of luck you have with it. Well I had some luck but not what I expected… Quote Link to comment Share on other sites More sharing options...
Lscott Posted April 14, 2023 Report Share Posted April 14, 2023 This is an old thread but a few more frequencies are mentioned in it on UHF for specific locations. https://forums.radioreference.com/threads/noaa-uhf-repeaters.253483/ Also I have a list of VHF frequencies used for weather broadcasts. See attached file. Two are listed for Canada. There is one for the US in the 163 MHz range you don't find commonly listed. I have no idea if that last one is really used. US and Canada Weather Channels.pdf Quote Link to comment Share on other sites More sharing options...
