Question - "no-communication squelch" / PR Frequency?
marcspaz
I am totally bewildered by a radio feature and can't find an answer anywhere.  I found one single page that says it reduces background noise when there is no audio is present, but that absolutely isn't happening on any of my radios.  Hopefully some of the smart people here know what this stuff is.
I have several Yaesu radios that have a squelch type called "PR" in the radio menu, and "No-Communication Squelch" in the manual.  There is nothing in any of the manuals I have that explain what No-Communication Squelch / PR is.  The only thing in any of the manuals is how to turn it on and how to set the "PR Frequency".  That's it.
Normally, I wouldn't even care, as long as the squelch works.  However, no matter what I do, it doesn't seem to squelch anything.  Like nothing.  It doesn't act as a regular squelch, a reverse squelch, really has no impact whatsoever on how the radio seems to work.  It exacts like nothing has been enabled.
Does anyone know what the heck PR / No-Communication Squelch is and actually does?
3 answers to this question
7 hours ago, marcspaz said:
I am totally bewildered by a radio feature and can't find an answer anywhere.  I found one single page that says it reduces background noise when there is no tone present, but that absolutely isn't happening on any of my radios.  Hopefully some of the smart people here know what this stuff is.
Normally, I wouldn't even care, as long as the squelch works.  However, no matter what I do, it does seem to squelch anything.  Like nothing.  It doesn't act as a regular squelch, a reverse squelch, really has no impact whatsoever on how the radio seems to work.  It exacts like nothing has been enabled.
I can’t claim to “know” what it is, but this tidbit from the FT5DR Advance manual seems to describe it:
User Programmed Reverse CTCSS Decoder
The tone signal frequency can be set at 100 Hz intervals between 300 Hz and 3000 Hz to mute the audio when receiving a signal containing a CTCSS tone matching the programmed tone.
1. Press the [F MENU] key[SQTYP].
2. Rotate the DIAL knob to select “PR FREQ”.
3. Press the PTT switch to save the setting and return to
normal operation.
4. Press the [F MENU] key[CODE].
The setting screen containing the CTCSS tone
frequencies is displayed.
5. Rotate the DIAL knob to select the desired CTCSS
tone frequency.
300Hz to 3000Hz (100Hz steps)
6. Press the PTT switch to save the setting and return to
normal operation.
So, a person could assign different PR Frequencies to different radios and then selectively block the audio when receiving a signal from a radio that sends the same PR Frequency.  Maybe for blocking audio from APRS  or digital transmissions on an analog radio?  1600 Hz is the default.
