Rebuilding the Chain O' Lakes Repeater - Ingleside IL
Due to the duplexer failing I decided over the winter months I would rebuild the Chain O' Lakes repeater in Ingleside IL. I had a spare 100W MTR2000 in the garage and decided this was going to be the heart of the new machine. Tuning it down to 50W would insure a solid 100% duty cycle and provide years of service. Due to past bad experiences with EBay duplexers I decided to purchase a new one and settled on an EMR 4 cavity pass / reject with a factory tune. Being a tinkerer that loves to build things I decided to dig out all the radio junk and see what I could come up with. The finished system will have an on board Bird 43 SWR / power meter and one of those micro mobile UHF radios for testing , monitoring and local use. To limit loss and interference I plumbed the entire system with ¼ helix superflex trimmed to critical lengths. Over the past several months I was having issues with another systme on .550 so come spring it will be moving to .725. I am still waiting on a few more items to finish this build and will keep this thread updated.
http://cor3com.com/mygmrs/fr.jpg
http://cor3com.com/mygmrs/emr.jpg
This is the tower at my site, 150' with a DB420 on the top.
http://cor3com.com/mygmrs/tower.jpg
We used to have 2 repeaters at the site. The Yagi ran a Motorola R100, you could get into it 48 miles away at the house. It has since been taken down and replaced with a side arm and station master running a friends Ham repeater.
wow what a relic.
I wish I had a nice tower for my future repeater. Alas, I'm stuck with a tripod roof mounted antenna at about 42'. It still should be good enough to cover the roughly 10 mile radius I need for now.
Can't beat that MTR for solid performance, I run one with a Zetron and a ASP fiberglass antenna (800 model I think) 22 feet long on my 50 foot tower, which is on a hill 150 feet above average terrain. It has always provided good range. Before the MTR, I had 2 mobiles running, it was good, the MTR is the real deal though. For duplexing I run 2 receive cans, and one transmit can, stuff salvaged out of an old Motorola community repeater. Works great.
Came across the cable left over from another project and didn't want it to go to waste ! The MTR is a rock solid repeater. Unfortunately mine is a MTR3000 and I'm not a huge fan of it. Have a few Quantars sitting so may swap one in.
n4gix. don't feel bad, we are doing a similar setup, eave mount at 15' and a 30 foot channel master pipe with a 6dbd/9dbi Comet antenna. We get 15 miles mobile for the most part and we have lots of hills and gullys in the way.
If I had that 150 foot monster I would rule the world ;)
Well, your county maybe. That is one fine and professionally built repeater Cory is building! B)
Well thanks William, I think it turned out OK. I try do build all my gear as good as I can using the best parts I have on hand of can afford. I am sure the 1/4 helix jumpers are overkill but way better then 90% shielded coax... I know its made a difference on my commercial repeaters so it can hurt the GMRS ones.
1/4 " is definitely not overkill. most of the stuff I do uses 1/2" superflex, beats  using 213/400 cables.
I used some 1/2 on the amplifier output on my commercial Mototrbo system but mostly 1/4 for jumpers etc... Pic's included.
Second rack to the left of mine is the National Weather Service radio for our area.
Everybody loves an equipment shelter pic!
should have hooked up to that LOL
That would have been fun, and it would have a lot less loss at the tower top. (485') I am lucky to have shared use of a receive antenna at the top but only licensed for 150' on my transmit.
Reply to this topic...
