antenna experiment
JohnE
will be conducting an antenna experiment w/575 machine in the near future to see if there is any real difference in pattern and range vs cost.  RSSI readings at fixed locations have been taken this week. waiting for the Comtelco antenna to show up.
all things being equal the only change will be the antenna itself.
the antennas will be a Laird 5dBd($150) currently in service
Comtelco 6dbd ($200)
PD 201 5 dBd ($450)
the Laird is physically the smallest one, the other 2 are roughly the same size/weight.
will post pics of the 3 together.
not looking for radical results but it should be interesting.
ground elevation ~150'
structure ~200'
I'm tuned in. I happen to have the 6dbd Comtelco. Got burned though, didnt do my home work and bought it straight from Comtelco only to find out I could have saved a hondo from one of thier vendors!
oh well, hopefully it compares well in your comparison so it takes some of my sting away...LOL
I call them directly and did not pay what they showed on their web page. it was actually less than what their vendors sell it for.
also just for the record I have one already and have been happy w/results I'm getting.
  • 3 weeks later...
the new antenna is here and here are some pics of the 3 antennas I will bu using.
L-R
Laird, Comtelco, RFS
http://i1105.photobucket.com/albums/h358/erscom/antennas/IMG_0226_zpsbicbvuwz.jpg
ID tags on the antennas
http://i1105.photobucket.com/albums/h358/erscom/antennas/IMG_0229_zpsw7pyn4ro.jpg
http://i1105.photobucket.com/albums/h358/erscom/antennas/IMG_0230_zps0zmcfqwk.jpg
http://i1105.photobucket.com/albums/h358/erscom/antennas/IMG_0231_zpsmolw5drl.jpg
for the record the machine is currently running a Laird like the one in the pics, I just used this one as a reference to the others.
hope to put up the Comtelco on Friday weather permitting.
one other interesting point on these, the Comtelco is not DC grounded the other 2 are.
Our shop has a slew of the Laird's (10+ in stock), I am thinking about using one for our new 675 repeater that we hope will go up in a month or 2, after the new tower and my experimental build of a Johnson PPL6000. I have been hearing really good things on the Laird's.
Sure! A $3000 spectrum analyzer with tracking generator and a VSWR bridge...
Send your rejected ones to me. Your worst is prob better than my best lol
Btw is there a way besides an antenna analyzer to see if an antenna is good? I have an older business band uhf that I have no clue about
Don't want to install it and find out it isn't any good
I would think the cheaper way would be to bolt it to something stable like a metal fence or just stand it up on a mast. Once you find a way to stand it up hook up a radio and an SWR meter and see what you get. How ever you test in be sure it has ample free space and don't get to close to it well keying it up. You may ask around and see if any of your fellow hams have an Anritsu Site Master and if so can you get them to sweep it for you.
Corey
swap 1 made to the Comtelco
as an added side note the VSWR for the Laird was 1.3 and the Comtelco was 1.65.
John,
Ever tried any of the dipoles on your repeater? I run a DB404-B on my base, DB411-B as the TX antenna and a DB413-B as the RX on my commercial UHF DMR system, I am getting ready to upgrade my other commercial site to a Duplexed DB408-B and my GMRS repeater runs a Duplexed DB420-B. I don't have a single bad thing to say about any of them. I do have some choice words about a few of the fiberglass sticks I have used over the years.
Corey
Corey
I agree with Corey.
Just remember, a dummy load has a 1.0:1 SWR. SWR just makes the radio happy. Your field strength meters and just testing the thing is going to give you your best findings.
HAPPY HUNTING!
James
I have an Agilent antenna/cable analyzer and a General Dynamics service monitor w/most of the options.
this is just a field test for the real world for S's and G's to compare if $$$$$ antenna performs as well as the $$ antenna.
I have never cared for exposed dipole arrays as I have had too many water intrusion issues w/them. I had a DB 411 and gave it to one of Rich's buddies
I have had some manufacturing issues w/fiberglass antennas. radomes coming out of the support pipes but those were Irene and Sandy related.
http://i1105.photobucket.com/albums/h358/erscom/antenna%20fails/kcc006.jpg
http://i1105.photobucket.com/albums/h358/erscom/antenna%20fails/kcc003.jpg
So far I have not had any issues with the Andrew / Comscope DB line of dipoles. The DB420-B on my GMRS site is over 10 years old and still works as good as day it was put into service. I have herd others complain about some of the DB knockoffs failing in the field but never any bad words about the real deal dipoles.
That is crazy how the antenna separated at the mount, must have been some crazy wind! My issue with past fiberglass was the gelcoat weathering and water soaking into the glass mat causing huge drops in performance. Your would be the first one I have seen sheer off at the mounting tube. Whats the broadcast antenna stack in the background?
RFI builds a sweet (fully welded) exposed dipole array that's worth checking out if you have some money to burn.
DB's water intrusion issues were mostly settled by 2005. Know of a 224 suffering from it currently.
Sent from my SM-T350 using Tapatalk
Corey
have to wait till the snow is gone lol.
Ps sorry for the hijack. John
