Antenna Tuning help
ian3211
7 answers to this question
2 hours ago, ian3211 said:
I have an antenna tuning question. I'm tuning my antenna for my radio, on channels 1-8 the meter is reading 1.02. On channel 15 its reading at 1.52. The repeater channel swr is reading at 2.02. Whats the best way for me to tune my antenna?
A little bit of the philosophy of "tuning"...
The goal is to optimize antenna performance and by doing so increase transmit and receive performance.
Theoretically, an antenna plays best on a specific frequency and covers the neighboring frequencies with decreasing performance.
With that said, the tuning depends on the use of the antenna (who would have guessed?!? 😎)...
In plain words, if you are working in a specific frequency range and you use all of the range's frequencies, you are best off by tuning to the center of the range as that means your "losses" are somewhat evenly distributed.
However, if you have a preference for a specific frequency (your go to channel or repeater), there might be an argument to optimize for that use case. - In the extreme, however, that might mean that one "loses" performance at other frequencies / channels. In a case where the radio is basically only used for one channel, that might be acceptable...
Little side note: Tuning is more important on transmit than on receive as most radios could hear decently even if one would replace the antenna with a wire coat hanger (as many 70's and 80' car showed us).
In any case, there is no "one size fits all perfection" and as our YouTube friend stressed: Your setup is "plenty good enough" !!!
You will be fine with that. My Comet CA-712EFC which is a dedicated GMRS antenna gets 1.2 on channels 1-7, 1.1 on channels 8-14 and 1.6 on channels 15-22. My Comet 2X4SR (dual band) gets 1.5, 1.2, and 1.8.
A SWR of 2 or lower is fine. I wouldn't sweat about the 2.02 SWR reading.
