WRZX444 Posted January 18, 2024 Report Posted January 18, 2024 I hope this is not an obvious question but I heard an Icom IC-7300 can be used to receive/transmit on GMRS frequencies? Thanks for any responses... Quote
MarkInTampa Posted January 18, 2024 Report Posted January 18, 2024 It can not. It's a HF/6 meter radio and can't receive over 75MHz. WRZX444 and SteveShannon 2 Quote
tweiss3 Posted January 18, 2024 Report Posted January 18, 2024 And the IC-9700 can't even receive GMRS, its filters are too tight it has a hard stop at 450MHz. Quote
WRYZ926 Posted January 18, 2024 Report Posted January 18, 2024 There are a few Icom radios that can have the MARS Mod done which will allow them to transmit on GMRS. The IC-7300 is NOT one of them though. I will let others discuss the actual legalities of doing such modifications. Quote
OffRoaderX Posted January 18, 2024 Report Posted January 18, 2024 1 minute ago, WRYZ926 said: I will let others discuss the actual legalities of doing such modifications. Here, I'll just get it over with: You will get a $250,000 fine AND go to jail!! WRXB215 and WSBZ227 2 Quote
Lscott Posted January 18, 2024 Report Posted January 18, 2024 40 minutes ago, WRYZ926 said: There are a few Icom radios that can have the MARS Mod done which will allow them to transmit on GMRS. The old IC706MKIIG is one, but the power output is low due to the filters. IC-706MKIIG Freqequency Mod Power Output.pdf IC-706MKIIG Transmit Power Mod.pdf IC-706MKIIG Frequency Expansion.pdf WRXB215 1 Quote
WRYZ926 Posted January 18, 2024 Report Posted January 18, 2024 The IC-5100 is another one that can be modded. I know guys that have done it and the mod works fine. Quote
WRUU653 Posted January 18, 2024 Report Posted January 18, 2024 The IC-2730A as well. SteveShannon 1 Quote
