Wouxun KG-UVD1P "Dealer Channel Mode"?
8 answers to this question
Here is what I could find on the dealer mode.
Quote
4.5 Dealer Mode
Normally channel information is locked. If you must change channel parameters outside of software or without deleting and recreating a channel then
use Dealer Mode.
Enter dealer mode:
Release key 8 after beeps
Enter dealer password:
MENU TDR (you should see channel numbers at right side of LCD display)
MENU ▲ (to select CH = channel number, CH FREQ = channel frequency, or NAME
MENU 2 1
= channel name), MENU EXIT
(There is also a FREQ parameter, to set VFO mode on, but it is easier to toggle using MENU TDR )
MENU TDR (there should be no channel numbers at right side of LCD display)
1 4 5 9 5
MENU ▲ or ROTARY (until 026 selected), MENU EXIT
MENU 2 7
(the receive downlink frequency is now saved)
4 3 5 9 5
MENU ▲ or ROTARY (until CH-026 selected), MENU EXIT
MENU 2 7
(the transmit uplink frequency is now saved)
MENU , ROTARY , programmed channels show as, e.g., CH-025 while free unused
MENU 2 7
channels appear as 025, EXIT
Hold down keypad# 8 while turning the radio on POWER SWITCH/VOLUME CONTROL
(you should see 2 lines of 6 underscore characters on the LCD screen)
2 6 8 1 6 0
https://www.manualslib.com/manual/632574/Wouxun-Kg-Uvd1p.html?page=9
Posted (edited)
It's my understanding that "Dealer Mode" is for companies that rent radios to program them and then lock them from being changed by the users. I think BCI does this with the radios they rent.
Edit: Actually, I think they do this for radios they sell as well. Makes sure the end user stays inside the bounds of their privileges.
Edited by WRXB215
Added info.
I was thinking it was to unlock the radio for all the frequencies that it was able to Tx/Rx on but then you can also do that in CHIRP in the Settings as well. I don't want to try it if I don't know what it does.
Dealer mode for some devices that I’ve seen places the device into a repetitive demonstration routine designed to highlight its features.
I wouldn’t be afraid of putting it into dealer mode, but I would back it up first.
