dmcpher326 Posted February 5, 2024 Report Posted February 5, 2024 this is weird or just me. Went to chnl 30, freq 462.7250...put in NO offset, NO DCS, NO R/T-CTCSS but the radio added the + offset and I can't get rid of it. Does this chnl/freq automatically ad the offset? If I switch to VFO, it isn't there, just under chnl mode....Radio is a UV-5G plus... Ideas? Thanks David Quote
Guest Posted February 5, 2024 Report Posted February 5, 2024 It’s a gmrs radio. Anything after 22 will have offsets pre programmed for repeater use. 467.xxx is for accessing repeaters not for simplex. A 5g (gmrs radio) will not transmit in Vfo mode. Quote
OffRoaderX Posted February 5, 2024 Report Posted February 5, 2024 48 minutes ago, dmcpher326 said: Ideas? You didnt let us know what kind of radio it is, but just like @WRXP381 said, if its a GMRS radio, it is working exactly as designed and doing exactly what the user-manual says it will do. Quote
SteveShannon Posted February 5, 2024 Report Posted February 5, 2024 1 hour ago, dmcpher326 said: this is weird or just me. Went to chnl 30, freq 462.7250...put in NO offset, NO DCS, NO R/T-CTCSS but the radio added the + offset and I can't get rid of it. Does this chnl/freq automatically ad the offset? If I switch to VFO, it isn't there, just under chnl mode....Radio is a UV-5G plus... Ideas? Thanks David If you want to transmit and receive on the same frequency use one of the simplex frequencies. Channels 15-22 receive on the same frequencies as repeater channels 23-30, BUT there is no offset. So, rather than selecting channel 30, use channel 22. It transmits and receives on 462.725 MHz AdmiralCochrane and WRUU653 2 Quote
