Guest Rick Posted February 9, 2024 Report Posted February 9, 2024 I'm trying to program my unit with a computer, cable, and CPS. When I plug in the cable and select the port it says it's not compatible with Windows 11. Wondering what the fix or workaround is? Quote
SteveShannon Posted February 9, 2024 Report Posted February 9, 2024 10 minutes ago, Guest Rick said: I'm trying to program my unit with a computer, cable, and CPS. When I plug in the cable and select the port it says it's not compatible with Windows 11. Wondering what the fix or workaround is? Welcome to the forums. Without telling us what radio you’re using and what software you’re using it’s impossible to say. WRYZ926 1 Quote
Doggorunning1 Posted February 9, 2024 Report Posted February 9, 2024 Windows 10 will automatically recognize it in the drop down when given the option in Chirp Here a thread on Windows 11, I also dont download the software on the manufactures site they send to have random error codes. https://chirp.danplanet.com/issues/9883 Quote
WRYS709 Posted February 10, 2024 Report Posted February 10, 2024 Where did anyone mention Chirp? WRUU653 1 Quote
OffRoaderX Posted February 10, 2024 Report Posted February 10, 2024 20 hours ago, Sshannon said: Without telling us what radio you’re using and what software you’re using it’s impossible to say. Or what cable.. WRUU653 and SteveShannon 2 Quote
WRYS709 Posted February 10, 2024 Report Posted February 10, 2024 23 hours ago, Guest Rick said: I'm trying to program my unit with a computer, cable, and CPS. When I plug in the cable and select the port it says it's not compatible with Windows 11. Wondering what the fix or workaround is? Go to Device Manager in Windows 11 and report what it is saying about the Serial or COM ports and what, if any, chip driver it is reporting. A screenshot would be helpful. WRUU653 1 Quote
WRYS709 Posted February 29, 2024 Report Posted February 29, 2024 When the OP comes back (if), then I’ll stop holding my breath Quote
