Guest AKOVER33 Posted February 18, 2024 Report Posted February 18, 2024 Hello everyone, let me tell you about my situation... I AM A NOOB when it cames to walkies and repeaters. I was recommended to get H777 walkies and the RT97 Repeater. The issue is I cannot find a step by step process that breaks down how to expand the frequencies on these walkies and how to connect the walkies to the repeater. Retevis sent me some steps but I get into opening the app and then when I go to Read Radio with the radio connected to the computer with power on and this error message pops up "Can't read radio". I run a 400k sqft warehouse which is slowly filling up with product. I would like to expand the frequencies and connect to the repeater so when we get full I am ahead of the issue. Please let me know if you have any questions! Quote
WRXB215 Posted February 19, 2024 Report Posted February 19, 2024 What do you mean by "expand the frequencies?" Do you mean outside of the GMRS frequencies? Quote
OffRoaderX Posted February 19, 2024 Report Posted February 19, 2024 4 hours ago, Guest AKOVER33 said: I was recommended to get H777 walkies and the RT97 Repeater. The issue is I cannot find a step by step process that breaks down how to expand the frequencies on these walkies and how to connect the walkies to the repeater You should ask the guy that recommended them to you. WRPG745, SteveShannon, WRUU653 and 1 other 3 1 Quote
DominoDog Posted February 19, 2024 Report Posted February 19, 2024 I get "can't read radio" error in Chirp when my programming cord isn't plugged in all the way. The connector and radio don't mate exactly well, and have to push it snug. EDIT: Are you sure you even need the repeater? If you didn't, that would cut out some complexity. WRXB215 1 Quote
WRUU653 Posted February 19, 2024 Report Posted February 19, 2024 These appear to be FRS radios and as such should not be able to use a repeater per FCC. That said they do seem to be programmable via Chirp and according to the inter webs are the same as a Baofeng BF888 and use the same Chirp programming. A little research and there seems to be some question as to part acceptance??? 16 channels only, so less than a standard bubble pack yet you can program them, so more than your standard bubble pack. If you’re to follow the rules I can certainly see an issue using these with a repeater even if they do such a thing. This person that recommended this setup, did they sell the radios and repeater to you? WRXB215 1 Quote
gortex2 Posted February 20, 2024 Report Posted February 20, 2024 Are all your emplyees getting there GMRS licence ? While GMRS is valid for business use ever emplyee must have a license.... Quote
