Guest Craig Posted March 7, 2024 Report Posted March 7, 2024 I just got a Nagoya na 771 for my baofeng and when I screw it all the way in it doesn’t receive. But when I screw it half way in. It receives. Any ideas why? Quote
WRYS709 Posted March 7, 2024 Report Posted March 7, 2024 Its internal connections are faulty; return it for a replacement. Usmc1968 and WRXB215 2 Quote
WRUE951 Posted March 9, 2024 Report Posted March 9, 2024 I had one do similar. I thought it was the radio, but after trading with a wouxon antenna, problem went away, But strangely the Nagoya worked fine in another radio. Quote
WRUU653 Posted March 9, 2024 Report Posted March 9, 2024 I haven’t had this happen with mine but it did come with some small ring spacers which makes me wonder if this is what’s needed for some radios. Quote
gortex2 Posted March 9, 2024 Report Posted March 9, 2024 Dont have this issue with factory provided antenna's WRUU653 1 Quote
TNFrank Posted March 14, 2024 Report Posted March 14, 2024 Not to get too far off topic but I've noticed that sometimes the O.D. of the antenna bade is too large to screw down into the I.D. of the hole on the radio. I had this issue with a Nagoya 701c and my Talkpod A36 Plus. It didn't seat far enough into the radio to make good contact so the factory antenna actually worked better. Quote
JBRPong Posted March 26, 2024 Report Posted March 26, 2024 I had this issue with one of my 771s, I just put a rubber o ring in between and it doesn't screw in all the way and it's working normally. WRXB215 and AdmiralCochrane 2 Quote
AdmiralCochrane Posted March 28, 2024 Report Posted March 28, 2024 On 3/26/2024 at 10:54 AM, JBRPong said: I had this issue with one of my 771s, I just put a rubber o ring in between and it does screw in all the way and it's working normally. I had to do that when I did a minor mod to add a "tiger tale" JBRPong 1 Quote
