So, question(s) on the use of PL tones when programming repeaters vs. using them for simplex communication between two GMRS operators/HT's. I have the mechanics down for programming tones when programming local repeaters. It's the theory I'm struggling with somewhat. If I understand this correctly, using a PL tone when I transmit to a repeater opens the repeater to receive the transmission. The repeater then retransmits my transmission out to a greater distance than my radio is capable of doing on its own. Now, is that retransmission heard by 100% of the operators monitoring that repeater frequency and within range, or is it only heard by those operators that have also programmed in the PL tone on the receive side that matches the PL tone I programmed in on the transmit side? (geez) Also, can the transmit PL tone be different than the receive PL tone, or do they always have to be the same, say for example when participating in a GMRS social net being conducted through a repeater?
Now, when communicating on a simplex channel, can you use these same PL tones to set up "private" communication between two operators/radios? I understand that "private" is not really private in that anyone monitoring the same simplex channel will hear everything you say, but by using PL tones, it reduces the chance that others who are listening in from having the ability to break in on your conversation, right?
So, in the case of simplex communications, is the transmit PL tone doing the same thing to the receiving radio that it does for a receiving repeater - opening it up (breaking squelch? Not sure if that's the right term for this)?
Webslinger
Thanks!
4 answers to this question
