WSBA587 Posted April 5, 2024 Report Posted April 5, 2024 Hypothetical question. Would a Yaesu Motorized Mobile Antenna: 40m through 70cm - ATAS-120A tune GMRS frequencies on a MARS open yaesu 6000r. I completely understand the Atas isn’t “technically” spec for gmrs freqs but will it tune it in reality? Quote
0 back4more70 Posted April 5, 2024 Report Posted April 5, 2024 44 minutes ago, WSBA587 said: Would a Yaesu Motorized Mobile Antenna: 40m through 70cm - ATAS-120A tune GMRS frequencies on a MARS open yaesu 6000r. I don't know anything about that antenna. However, I have a MARS-modded Yaesu 6000r and it pairs wonderfully with my Tram 1181 on 2m, 70cm, and GMRS, without adjustments. WSBA587 1 Quote
0 kidphc Posted April 5, 2024 Report Posted April 5, 2024 Barely tunes 2m.So I would venture no.But you can try, would have to cut the antenna pretty fierce. I figure the internal coil is too long.In fact I haven't seen a screwdriver antenna (commercial) built even go to 70cm.Sent from my SM-S901U using Tapatalk gortex2 1 Quote
0 gortex2 Posted April 5, 2024 Report Posted April 5, 2024 No reason for a screwdrive to remotely go that high. A $5.00 quarter wave would work better. kidphc 1 Quote
0 kidphc Posted April 5, 2024 Report Posted April 5, 2024 I don't know anything about that antenna. However, I have a MARS-modded Yaesu 6000r and it pairs wonderfully with my Tram 1181 on 2m, 70cm, and GMRS, without adjustments.Yeasu's hf mobile motorized screwdriver. Works directly with the likes of a ft891,817,ft991a without the need for a controller.Gets shit on a lot due to weather seal issues, motor issues and missing features of its competitors. Frankly, you cant compare it to the competitors. Simply because even a baby tarheel is going to start at 350 or so, then if you want memory for the different bands, almost as much as the antenna a quality controller. Then there are the scorpions, easily 3x the atas cost for the screwdriver alone.Sent from my SM-S901U using Tapatalk Quote
0 SteveShannon Posted April 5, 2024 Report Posted April 5, 2024 3 hours ago, WSBA587 said: Hypothetical question. Would a Yaesu Motorized Mobile Antenna: 40m through 70cm - ATAS-120A tune GMRS frequencies on a MARS open yaesu 6000r. I completely understand the Atas isn’t “technically” spec for gmrs freqs but will it tune it in reality? The FTM-6000 isn’t listed as one of the ATAS interface radios. I think the hypothetical answer should be no. Quote
0 WRUI365 Posted April 5, 2024 Report Posted April 5, 2024 The radio in question doesn't have the circuitry in it to drive the ATAS120 motor to tune it, so the answer is a big no. WSBA587 1 Quote
0 WSBA587 Posted April 6, 2024 Author Report Posted April 6, 2024 13 hours ago, back4more70 said: I don't know anything about that antenna. However, I have a MARS-modded Yaesu 6000r and it pairs wonderfully with my Tram 1181 on 2m, 70cm, and GMRS, without adjustments. Thank you so much, was looking for something that works. Just ordered that antenna Quote
WSBA587
7 answers to this question
