WRDJ205 Posted April 6, 2024 Posted April 6, 2024 I was recently gifted a Baofeng GM-5RH. I’ve looked all thru the webs and can’t find a straight answer. Is the manual for this radio similar too or the same as the UV-5G Plus? Is the programming software on Chirp? Thanks WRDJ205 Quote
OffRoaderX Posted April 6, 2024 Posted April 6, 2024 I haven't compared the two, but they are probably 98% the same, if not more. To see if it's compatible with CHIRP, read the words on the CHIRP compatibility page, here: https://chirpmyradio.com/projects/chirp/wiki/Supported_Radios Quote
BobFudge88 Posted April 10, 2024 Posted April 10, 2024 6 days into my GMRS journey I bought a UV-5G Plus. Been using it now for 2 days and I've enjoyed it so far. Today I came across the GM-5RH and re-realized that we're all plugged into the matrix anyway. For $5 less, I can get the same radio with a GM on the sticker, 2 antennas, a dock charger, and a programming cable. I ordered it so I will see firsthand that they are the same. My hunch is the GM-5RH is a precursor to the UV-5G Plus OR the other way around. Might be an international version vs a USA "locked" version... WHO KNOWS! Quote
WRDJ205 Posted April 10, 2024 Author Posted April 10, 2024 10 minutes ago, BobFudge88 said: bought a UV-5G Plus. I almost wrote that the UV-5G Plus was not on chirp but it is listed under Baofeng/Podung. I can confirm that the GM-5RH is on chirp. I’m curious, like you, if they’re the same radio. Quote
BobFudge88 Posted April 12, 2024 Posted April 12, 2024 Got the GM-5RH and I can confirm that the radios are exactly the same. There are 2 differences: the welcome screen when you turn it on and the brand of the longer antenna. I bought this on Amazon from ABBREE's listing which not-so-ironically came with branded ABBREE AR-771. It is "whippier" than the UV-5G+ longer antenna due to the thickness changing halfway up the antenna. Both radios use the GM-5RH listing on CHIRP to program which tells me the GM-5RH probably came first in production. (being that the UV-5G+ isn't listed and the GM model is) My thought is that, like Btech, ABBREE has some kind of agreement with Baofeng allowing them to sell radios with ABBREE antennas. The volume nob seems to be tighter on the GM model which I kind of like. Either way, I'm keeping the UV-5G+ and gifting the GM-5RH to a friend. Quote
WRDJ205 Posted April 12, 2024 Author Posted April 12, 2024 41 minutes ago, BobFudge88 said: Got the GM-5RH and I can confirm that the radios are exactly the same. Thanks for the information. I'll be making a recommendation to a friend soon for a pair of GMRS radios. I find that I'm using the GM-5RH more than the GM-15Pro and like the feel of it more. I'll have to do more reading on the UV-5G+. Quote
WRYS709 Posted April 12, 2024 Posted April 12, 2024 Do you have a link where to purchase this radio solo and not in a two-pack? Quote
WRDJ205 Posted April 12, 2024 Author Posted April 12, 2024 @WRYS709 If you were asking about the GM-5RH, it was a gift so i don't have the exact link. But I believe it came from amazon. I see a listing with this title, "BAOFENG GMRS Handheld Radio UV-5R Upgrade Long Range Walkie Talkies GM-5RH Two Way Radio with GMRS Repeater Capable,NOAA Weather Receiver,One Key Frequency Match and Type C Cable,Support Chirp". (I don't know if we're not supposed to put a link it so I just copied the title) Quote
BobFudge88 Posted April 12, 2024 Posted April 12, 2024 https://www.amazon.com/dp/B0CP3PH6V6?psc=1&ref=ppx_yo2ov_dt_b_product_details Quote
WRYS709 Posted April 12, 2024 Posted April 12, 2024 OK, thank you both. One reason I never purchased the UV-5G(X) was they were always sold in pairs. I see from the Amazon link, it is not really the style of the UV-5G(X) and appears to be an upgraded feature set. Quote
WRDJ205 Posted April 12, 2024 Author Posted April 12, 2024 I'm not sure about the UV-5G, but the GM-5RH version has USB C charging that has come in pretty handy already. @BobFudge88 might be able to answer if the UV-5G+ is USB c chargeable. Quote
WRXB215 Posted April 13, 2024 Posted April 13, 2024 @WRYS709 the ham version just might be my next purchase. SteveShannon 1 Quote
GreggInFL Posted May 23, 2024 Posted May 23, 2024 On 4/10/2024 at 6:03 PM, WRDJ205 said: I almost wrote that the UV-5G Plus was not on chirp but it is listed under Baofeng/Podung. I can confirm that the GM-5RH is on chirp. I’m curious, like you, if they’re the same radio. True: " UV-5G Plus (use Baofeng GM-5RH)" However, when searching for Baofeng GM-5RH I get this: "UV-5RH Pro Max (use Baofeng 5RM)" (Emphasis added). There appears to be nothing for the non-Pro Max version. I just opened a box of two new ones and don't want to brick them. Anyone know which one to use? TIA! Quote
WRXR255 Posted May 23, 2024 Posted May 23, 2024 10 minutes ago, GreggInFL said: True: " UV-5G Plus (use Baofeng GM-5RH)" However, when searching for Baofeng GM-5RH I get this: "UV-5RH Pro Max (use Baofeng 5RM)" (Emphasis added). There appears to be nothing for the non-Pro Max version. I just opened a box of two new ones and don't want to brick them. Anyone know which one to use? TIA! Try to do a download with the 5RH selection. Chances are if it does it clean/no errors, it will be fine to upload with that setting. And save / lock that file! Its like your backup of the factory settings. Quote
GreggInFL Posted May 23, 2024 Posted May 23, 2024 Never mind, I think I found the answer. The Chirp Next version that was issued yesterday has a beta for the GM-5RH listed under Baofeng. It seemed to connect and I was able to save the factory settings. Fingers crossed. Is there any way one could import settings from another radio, e.g. my GM-15 Pro into the GM-5RH? Would be convenient. (<This guy is obviously new at this.) Quote
GreggInFL Posted May 23, 2024 Posted May 23, 2024 2 minutes ago, WRXR255 said: Try to do a download with the 5RH selection. Chances are if it does it clean/no errors, it will be fine to upload with that setting. And save / lock that file! Its like your backup of the factory settings. Yup. The "Pro Max" version wasn't listed, just the 5RH so I went with that. So far so good. I'll report back if anything dramatic happens. Quote
WRXR255 Posted May 23, 2024 Posted May 23, 2024 1 minute ago, GreggInFL said: Never mind, I think I found the answer. The Chirp Next version that was issued yesterday has a beta for the GM-5RH listed under Baofeng. It seemed to connect and I was able to save the factory settings. Fingers crossed. Is there any way one could import settings from another radio, e.g. my GM-15 Pro into the GM-5RH? Would be convenient. (<This guy is obviously new at this.) You can copy memories like your channels, but the radio specific settings will not, as they are like radio specific firmware. WRXB215 and SteveShannon 2 Quote
GreggInFL Posted May 23, 2024 Posted May 23, 2024 Ah yes, I see the import function. I'll give that a try. The firmware settings being fixed makes sense. Thanks! Quote
Guest Posted May 23, 2024 Posted May 23, 2024 So glad I do my research first before I buy a radio and have never had these types of issues. Quote
GreggInFL Posted May 23, 2024 Posted May 23, 2024 35 minutes ago, WRXP381 said: So glad I do my research first before I buy a radio and have never had these types of issues. Good point. I wasn't too concerned here because one can do a manual factory reset off the keypad (Menu 42). Quote
WRYY714 Posted September 15, 2025 Posted September 15, 2025 Temu's www.temu.com has a listing for the GM-5RH radio and also provides the manual in the item's description. Note: the radio being offered is not the GM-5RH but is the UV-5RH; however, the manual is for the GM-5RH radio. Also, I found a 2 pack of the GM-5RH radios on Amazon's Baofeng store for $18.48 free shipping. YES, THEY ARE ACTUAL A 2 PACK OF THE GM-5RH FOR THAT PRICE. LIMITED TIME SALE! Quote
WRYY714 Posted September 15, 2025 Posted September 15, 2025 Just now, WRYY714 said: Temu's www.temu.com has a listing for the GM-5RH radio and also provides the manual in the item's description. Note: the radio being offered is not the GM-5RH but is the UV-5RH; however, the manual is for the GM-5RH radio. Also, I found a 2 pack of the GM-5RH radios on Amazon's Baofeng store for $18.48 free shipping. YES, THEY ARE ACTUAL A 2 PACK OF THE GM-5RH FOR THAT PRICE. LIMITED TIME SALE! I PURCHASED TWO 2 PACKS ON AMAZON. What a deal for Baofeng GM-5RH radios for $10 each. Quote
WRYS709 Posted September 15, 2025 Posted September 15, 2025 29 minutes ago, WRYY714 said: I PURCHASED TWO 2 PACKS ON AMAZON. What a deal for Baofeng GM-5RH radios for $10 each. Link please. I cannot find this deal on Amazon... Nevermind: I found it! UPDATE: Darn you! I was just about cured of my HT addiction... Quote
