Hey everyone, I'm hoping to get some help with a bit of a head-scratcher. I recently installed a Btech 50 watt radio with a Tram 1181 antenna on an MNO mount.
I've double-checked that everything is grounded properly, and while the radio transmits just fine, the reception is absolutely plagued with noise. Here's the weird part: if I completely remove the antenna from the MNO mount (but leave the mount itself attached to the bracket), reception improves dramatically! It's still not perfect, but it's a world of difference compared to having the antenna screwed on normally. In its normal configuration, the reception quality is worse than my handheld radio, and the range is definitely suffering too. I'm at a loss here. Any ideas what could be causing this? I am thinking antenna but I am not sure.Â
WSBV575
12 answers to this question
