WSBP738 Posted May 8, 2024 Report Posted May 8, 2024 I have a Radioddity DB20-G. The antenna is a UT72G Nagoya mag base and a pyramid powersupply. I am using this as a base in an apartment on the 2nd floor. I have the antenna setting on the power supply near my sliding glass door. I'm hitting the repeater, but the person on the other end says I'm very quiet. My question is, I have a baking pan but is not magnetic but it is aluminum. Will that still work as a ground plane? Sent from my SM-A156U1 using Tapatalk Quote
Borage257 Posted May 8, 2024 Report Posted May 8, 2024 Move the mic closer to your mouth kidphc 1 Quote
SteveShannon Posted May 8, 2024 Report Posted May 8, 2024 9 hours ago, WSBP738 said: I have a Radioddity DB20-G. The antenna is a UT72G Nagoya mag base and a pyramid powersupply. I am using this as a base in an apartment on the 2nd floor. I have the antenna setting on the power supply near my sliding glass door. I'm hitting the repeater, but the person on the other end says I'm very quiet. My question is, I have a baking pan but is not magnetic but it is aluminum. Will that still work as a ground plane? Sent from my SM-A156U1 using Tapatalk Yes, even though it is not magnetic as long as your antenna base is on it it can work as a ground plane. Check to make sure that the hole in the microphone is clear and speak closely to it. We had one guy that was very quiet and he discovered that the mic hole was plugged. Putting the antenna outside could also help. WSBP738 and Raybestos 2 Quote
WSBP738 Posted May 8, 2024 Author Report Posted May 8, 2024 Well you were right the hole opening was to small. I took the mic apart and made the hole a little bit bigger and of course it made a huge difference. Thanks again for the advice!Sent from my SM-A156U1 using Tapatalk JBRPong, SteveShannon, Raybestos and 1 other 4 Quote
WRYZ926 Posted May 8, 2024 Report Posted May 8, 2024 That is a common issue with hand mics, especially the cheaper mics. About the only good mics I have used in the past were the Motorola mics. WSBP738 1 Quote
Guest Posted May 8, 2024 Report Posted May 8, 2024 24 minutes ago, WRYZ926 said: That is a common issue with hand mics, especially the cheaper mics. About the only good mics I have used in the past were the Motorola mics. I’ve only ever seen problems with radioditty and retivis mics. Quote
WRYZ926 Posted May 8, 2024 Report Posted May 8, 2024 28 minutes ago, WRXP381 said: I’ve only ever seen problems with radioditty and retivis mics. Baofeng and TYT hand mics have the same issue with the mic hole being too small. Quote
dosw Posted May 8, 2024 Report Posted May 8, 2024 Is the radio configured to wideband? Raybestos, SteveShannon and GizzardGary 3 Quote
Guest Posted May 9, 2024 Report Posted May 9, 2024 7 hours ago, WRYZ926 said: Baofeng and TYT hand mics have the same issue with the mic hole being too small. Not in my experience. I have several boofwang and tyt radios in the trucks. None of them have these issues. The Tyts do especially well on signal reports. I think 1/2 the time people need to just speak up. I’ve used radios all my life. Some very expensive professional radios and some extremely cheap junkers that make uv5s look really nice. The biggest thing I’ve always had to tell people is speak up. Quote
WRYZ926 Posted May 9, 2024 Report Posted May 9, 2024 While the TYT hand mics for their mobile radios are fine, their hand held mics are a different story. I have an Explorer QRZ-1 with hand mic that is nothing but a TYT UV88 with custom firmware. And the two hand held Baofeng hand mics I have aren't any better. I had to open up the mic hole on all three hand mics. SteveShannon and WRUU653 2 Quote
WRDJ205 Posted May 9, 2024 Report Posted May 9, 2024 First time I used this one someone mentioned that it sounded like I was under glass. I started trying to talk a little louder and it seems to have corrected the issue. JBRPong 1 Quote
WRXB215 Posted May 9, 2024 Report Posted May 9, 2024 9 hours ago, WRXP381 said: I think 1/2 the time people need to just speak up. It's weird how some people will whisper on the radio. As if they don't way anyone to hear them. Raybestos 1 Quote
WRXB215 Posted May 9, 2024 Report Posted May 9, 2024 @WRDJ205 I use that same mic when I'm at the park. Not a bad mic realy. Quote
WRQI583 Posted May 9, 2024 Report Posted May 9, 2024 1 hour ago, WRXB215 said: It's weird how some people will whisper on the radio. As if they don't way anyone to hear them. Oh, when it comes to DMR, I WISH all radio operators would whisper. When it comes to analog, unless you have a radio like mine that is hot on the audio, There is no need to whisper. On the same note, you dont need to jam the mic down your throat and scream like you are on CB radio. WSBP738 1 Quote
WSBP738 Posted May 11, 2024 Author Report Posted May 11, 2024 Is the radio configured to wideband?No it's narrow band the mic hole was to small.Sent from my SM-A156U1 using Tapatalk Quote
