RetALRdDog Posted June 4, 2024 Report Posted June 4, 2024 Sometimes I hear what sounds like Morse Code, but in the form of static bursts, not tones, as if someone is keying a mic. Some days this can go on for a long time as if someone is having a conversation. Mostly on channels 16 - 21. Any idea? GP62 1 Quote
amaff Posted June 4, 2024 Report Posted June 4, 2024 It's repeaters identifying themselves periodically. 15-22 share the same frequencies as repeater output frequencies for GMRS. WRYZ926, WRXR255 and WRQC527 3 Quote
WRYZ926 Posted June 4, 2024 Report Posted June 4, 2024 A lot but not all GMRS repeaters use CW to identify. amaff 1 Quote
quarterwave Posted June 4, 2024 Report Posted June 4, 2024 It could be a harmonic of another frequency and you are hearing the carrier and no audio....thus the static sound. I have heard such before. Quote
Raybestos Posted June 5, 2024 Report Posted June 5, 2024 Sounds like you might be picking up actual CW from an HF, VHF, or UHF, source. CW used in conversation is far more common on HF (aka short wave), but there are hams who use it on VHF and even UHF in the "weak signal" portions of those ham bands. Morse ID's on repeaters (often erroneously referred to as CW) will contain a tone with each dit or dah. CW or Continuous Wave (interrupted by the use of a key or keying device) will normally sound like someone keying and unkeying a mic with no voice or other intelligence added. Most of the CCJ (Cheap Chinese Junk) radios on the market today have direct conversion receivers and little if any filtering, so your picking up actual CW from one of the aforementioned ham sources is entirely possible. If the signal is not strong or it mixes with other signals or modes, it very well could sound like buzzes or static. SteveShannon 1 Quote
amaff Posted June 5, 2024 Report Posted June 5, 2024 5 minutes ago, RayP said: Sounds like you might be picking up actual CW from an HF, VHF, or UHF, source. CW used in conversation is far more common on HF (aka short wave), but there are hams who use it on VHF and even UHF in the "weak signal" portions of those ham bands. Morse ID's on repeaters (often erroneously referred to as CW) will contain a tone with each dit or dah. CW or Continuous Wave (interrupted by the use of a key or keying device) will normally sound like someone keying and unkeying a mic with no voice or other intelligence added. Most of the CCJ (Cheap Chinese Junk) radios on the market today have direct conversion receivers and little if any filtering, so your picking up actual CW from one of the aforementioned ham sources is entirely possible. If the signal is not strong or it mixes with other signals or modes, it very well could sound like buzzes or static. If we're just going to straight up ignore the simplest explanation of why there might be morse code on repeater channels, screw it, let's just say it's aliens SteveShannon, WRQD922 and GP62 2 1 Quote
Raybestos Posted June 5, 2024 Report Posted June 5, 2024 33 minutes ago, amaff said: If we're just going to straight up ignore the simplest explanation of why there might be morse code on repeater channels, screw it, let's just say it's aliens Yeah, let's just go with the simplest explanation, even if is likely the wrong one. SteveShannon and amaff 1 1 Quote
dosw Posted June 5, 2024 Report Posted June 5, 2024 44 minutes ago, amaff said: If we're just going to straight up ignore the simplest explanation of why there might be morse code on repeater channels, screw it, let's just say it's aliens We ignored the OP's description of the sound, though: "I hear what sounds like Morse Code, but in the form of static bursts, not tones,". I don't typically hear repeaters identifying with bursts of static. I suppose a simple explanation for that could be that the repeater is a bit out of range, and is identifying with CW, so we're just hearing a signal that was mostly lost along the way. Raybestos and amaff 2 Quote
Raybestos Posted June 5, 2024 Report Posted June 5, 2024 Aye! Also ignored was OP's observation that, "Some days this can go on for a long time as if someone is having a conversation.", which leads me to believe this is a CW QSO rather than simply a repeater's Morse ID. WRXB215 1 Quote
dosw Posted June 5, 2024 Report Posted June 5, 2024 Just now, RayP said: Aye! Also ignored was OP's observation that, "Some days this can go on for a long time as if someone is having a conversation.", which leads me to believe this is a CW QSO rather than simply a repeater's Morse ID. And I ignored the part where you mentioned that CW is not synonymous with Morse Code. The HAM references often seem to use them interchangeably, but yes, CW is a carrier wave or continuous wave, with no modulation, whereas Morse Code is an encoding protocol that is often used in CW transmissions but can also be used in FM, AM, and SSB transmissions, or light transmissions, or banging on a heater duct in a prison. SteveShannon 1 Quote
GP62 Posted June 5, 2024 Report Posted June 5, 2024 1 hour ago, amaff said: If we're just going to straight up ignore the simplest explanation of why there might be morse code on repeater channels, screw it, let's just say it's aliens jsneezy and amaff 2 Quote
