WSCE741 Posted October 31, 2024 Report Posted October 31, 2024 Has anyone tried testing the antenna when folded vs upright? I have this antenna, i was using it as a temporary base station and am looking to put it on my car now. I have a ford edge so i cant have it sitting upright all the time or ill be hitting my garage door / ceiling everyday (we have an old small farmhouse garage). Im curious though how well this antenna would perform (specifically TX) on both murs or gmrs if i ended up having to use it while it was folded down? Quote
SteveShannon Posted October 31, 2024 Report Posted October 31, 2024 7 minutes ago, WSCE741 said: Has anyone tried testing the antenna when folded vs upright? I have this antenna, i was using it as a temporary base station and am looking to put it on my car now. I have a ford edge so i cant have it sitting upright all the time or ill be hitting my garage door / ceiling everyday (we have an old small farmhouse garage). Im curious though how well this antenna would perform (specifically TX) on both murs or gmrs if i ended up having to use it while it was folded down? Try it. I think it’ll have a really screwy propagation pattern, perhaps mostly vertical, but without trying it you’ll never know. If you have an analyzer put it on first because the SWR will probably change as well. Quote
WRYZ926 Posted October 31, 2024 Report Posted October 31, 2024 I know laying the antenna flat on top of the roof is different from laying it flat in a back seat. But I know the 2x4SR does not work well when laid flat inside a vehicle. I have to agree that your propagation pattern will most likely be straight up in the air when laid flat. WRUU653 1 Quote
Guest Posted October 31, 2024 Report Posted October 31, 2024 Yea sorry to say that won’t work well at all. Quote
WRXB215 Posted October 31, 2024 Report Posted October 31, 2024 Horizontal is used a lot for HF where you get skip but I doubt it would be useful for UHF. Especially since you will loose some because of the change in polarization. WRUU653 and SteveShannon 2 Quote
WRUU653 Posted October 31, 2024 Report Posted October 31, 2024 Aside from the performance issues already stated I imagine that in the folded down state it might be inclined to whip around in the wind at speeds spanking your car as you travel the highways and byways. Okay I realize that probably wouldn’t be your use scenario. All kidding aside I would swap out to a shorter antenna while using parked in the garage, something that stays vertical but isn’t affected by the height restriction. wayoverthere 1 Quote
wayoverthere Posted October 31, 2024 Report Posted October 31, 2024 19 minutes ago, WRUU653 said: All kidding aside I would swap out to a shorter antenna while using parked in the garage, something that stays vertical but isn’t affected by the height restriction. That was my thought as well. Curious what the pattern would be laid down, but in the end it boils down to folding and unfolding each time, or picking up a shorter whip. Personally, I'd park and measure at the lowest clearance point, and go from there to see what my options were for whip length. The ubiquitous 1/4 wave is around 6" and pretty inexpensive (not much over $10 last I looked), and a solid option of you have the ground plane for it, and the no ground plane 1/2 waves are around 12", iirc WRUU653 1 Quote
Davichko5650 Posted October 31, 2024 Report Posted October 31, 2024 12 hours ago, SteveShannon said: Try it. I think it’ll have a really screwy propagation pattern, But won't "Some People" tell him it won't work???? But I'm with you, try it! Be interesting to see how being folded down close to the vehicle body will affect SWR. Quote
dosw Posted October 31, 2024 Author Report Posted October 31, 2024 1 hour ago, Davichko5650 said: But won't "Some People" tell him it won't work???? But I'm with you, try it! Be interesting to see how being folded down close to the vehicle body will affect SWR. I would have expected that laying it flat against the ground plane would cause it to reflect a lot. So I gave it a try. Standing up, at 465MHz, on a pizza-pan ground plane, it measured 1.6:1. Laid flat it measured 2.3:1. So it got worse, but not terribly so. Nevertheless, VHF and UHF FM is supposed to be vertical polarization. Orienting the antenna horizontally isn't going to really help anything except clearing your garage roof. However, at 2m, it got much, much worse. Something like 5:1. I didn't write it down. But standing in the upright position, in the 2m band, it's down to about 1.2.1. Your mileage may vary. Laying it flat against a larger ground plane, one with a radius large enough that the entire antenna is adjacent to the metal ground plane, is going to be a lot worse. Maybe bad enough that "some people" would be right. I know even in the vertical position, I was having reflection / high SWR issues when I put reflectix along side the antenna to cover the opening necessitated by a window air conditioner in sideways sliding windows. wayoverthere and WRUU653 2 Quote
WRTT844 Posted November 12, 2024 Report Posted November 12, 2024 On 6/19/2024 at 3:24 PM, WRUU653 said: 1.0 on 146.520, 1.25 on 446.000, 1.83 on 151.940, 1.86 on 462.562, 462.550 and 462.725, and 2.38 on 467.625 Here is what I am using for a mount. It bolts on with the hood hinge bolts. It isn’t mounted as high as you have but it works and I have no complaints. Do you have a part number for this mount? Where could I possibly purchase this mount? I was looking for something like this. Can you point me a in a good direction? Quote
WRUU653 Posted November 12, 2024 Report Posted November 12, 2024 1 hour ago, WRTT844 said: Do you have a part number for this mount? Where could I possibly purchase this mount? I was looking for something like this. Can you point me a in a good direction? It's a second Gen Toyota Tacoma A-Pillar Antenna Mount from Rugged Radios. They do have them for 3rd Gen as well as some other vehicles, just go to the top of their page and shop by vehicle. SteveShannon 1 Quote
grasshopper139 Posted Wednesday at 06:42 PM Report Posted Wednesday at 06:42 PM I have the CA-2x4SR mounted on my Jeep. It's on a corner mount just above the taillight. My SWR in GMRS is less than ideal, but 2m is near perfect. I'm looking to try out the Laird B4505CNS next for GMRS. I don't think there is a flat enough ground plane to help out my GMRS numbers. SWR: 462 - 2.03 467 - 1.8 146 - 1.08 Quote
Lscott Posted Wednesday at 07:32 PM Report Posted Wednesday at 07:32 PM 42 minutes ago, grasshopper139 said: I have the CA-2x4SR mounted on my Jeep. It's on a corner mount just above the taillight. My SWR in GMRS is less than ideal, but 2m is near perfect. I'm looking to try out the Laird B4505CNS next for GMRS. I don't think there is a flat enough ground plane to help out my GMRS numbers. SWR: 462 - 2.03 467 - 1.8 146 - 1.08 These antennas are sensitive to the mount type and location. I ran an SWR scan on mine when on a roof rack type mount. https://forums.mygmrs.com/gallery/image/615-ca-2x4srjpg/?context=new There is also a Diamond antenna very similar in design. https://forums.mygmrs.com/gallery/image/613-nr240ca-roof-rack-mount-swr-and-photojpg/ Quote
WRYZ926 Posted Wednesday at 10:13 PM Report Posted Wednesday at 10:13 PM The Comet 2x4SR definitely does better with a good ground plane underneath. I have one mounted on a small metal plate that is bolted down to an expanded metal rack on my SxS and another mounted on the center of the cab roof on my 2010 Ford F150 Super cab. I get an SWR of 1.8 and below on 2m, 1.25m, MURS, 70cm, and GMRS with both setups. It's hard to find a good spot with a large enough surface for a good ground plane on a Jeep Wrangler. Going with an antenna that doesn't require a ground plane will work better. SteveShannon 1 Quote
