Guest Parker Posted June 28, 2024 Report Posted June 28, 2024 Is it possible to connect 2 of the Yeasu ftm 500dr to a duplexer to make a reapeater? I know this is done with other brands of radios, just want to know if this is possible with the 2 afore mentioned radios. Quote
SteveShannon Posted June 28, 2024 Report Posted June 28, 2024 10 minutes ago, Guest Parker said: Is it possible to connect 2 of the Yeasu ftm 500dr to a duplexer to make a reapeater? I know this is done with other brands of radios, just want to know if this is possible with the 2 afore mentioned radios. Technically it’s possible but it’s not really very smart. The FTM-500 is the top end price wise of the Yaesu mobile radios. You’re paying twice for features that simply aren’t needed. You would be much better with a purpose built repeater like the yaesu dr-2. WRYZ926, WRUU653 and marcspaz 3 Quote
marcspaz Posted June 28, 2024 Report Posted June 28, 2024 I agree with Steve. Especially since the FTM-500 is a crossband repeater already. I was using two FTM-300DRs as a repeater for EmComm purposes, but I had two radios in two different vehicles and only set them up as a same-band repeater for emergencies and training. Even then, it's not practical and I ended up getting another DR-1X repeater. WRYZ926, SteveShannon and WRUU653 3 Quote
gortex2 Posted June 29, 2024 Report Posted June 29, 2024 The FTM500 is not a GMRS radio anyway. I assume you want a ham repeater ? If so many better options out there but to stay Fusion the DR2 is all ou can use. WRYZ926 1 Quote
WRYZ926 Posted June 29, 2024 Report Posted June 29, 2024 6 hours ago, gortex2 said: The FTM500 is not a GMRS radio anyway. I assume you want a ham repeater ? If so many better options out there but to stay Fusion the DR2 is all ou can use. I was wondering how long it was going to take before someone mentioned that the FTM500 is a amateur 2m/70cm radio. Yes the FTM500 can be MARS modded. But they would still make a poor repeater. Plenty of people have used two mobile radios as repeaters, but they never work as well as a dedicated purpose built repeater. Mobile radios just can't handle the higher duty cycle like a repeater can. Quote
