desertbird Posted July 25, 2024 Report Posted July 25, 2024 I think I have an active repeater near me to test my first time use of a repeater. I programmed my radio and get the tail kerchunk thing. I program my wifes and get same. I turn both on, shouldn't I be able to talk to my wife's radio through that channel as a test? Quote
amaff Posted July 25, 2024 Report Posted July 25, 2024 Just now, desertbird said: I think I have an active repeater near me to test my first time use of a repeater. I programmed my radio and get the tail kerchunk thing. I program my wifes and get same. I turn both on, shouldn't I be able to talk to my wife's radio through that channel as a test? Not if they're close by. Here's a good thread on the topic w explanations. SteveShannon and Raybestos 2 Quote
desertbird Posted July 25, 2024 Author Report Posted July 25, 2024 OK that makes sense. Is there a reason I hear the kerchunk on both? Quote
amaff Posted July 25, 2024 Report Posted July 25, 2024 Just now, desertbird said: OK that makes sense. Is there a reason I hear the kerchunk on both? So, when your radio is transmitting, it's desensing the other radio on the receive frequency it's listening to. When you stop transmitting, you'll get the kickback on both because now it can 'hear' again. SteveShannon and Raybestos 1 1 Quote
desertbird Posted July 25, 2024 Author Report Posted July 25, 2024 thank you so much!!! Maybe you can help me with one other noob question. If the tones listed are let say 371 DPL when I go to select from the list there are two 371 DCS tones. D371N and a D371I. What is different and how do I know which to use? Quote
Guest Posted July 25, 2024 Report Posted July 25, 2024 I have all my radios lined up on a desk with chargers touching. 11 HTs of different types and 2 base units. I hear the repeater on all of them when I transmit out on any of them. Desencing has never been an issue for me. I’d bet you’re just to far away. You can kerchunk a repeater but be too far away for it to pick up a voice signal. I’d drive closer and try again. When you hear people on the repeater try again. Ask for a radio check and introduce yourself. What radios are you using? What antennas? How far away are you from the repeater? How is the line of sight? . you will not be able to talk to your wife’s radio as a test because your transmitting on 467 and she is listening on 462 Quote
amaff Posted July 25, 2024 Report Posted July 25, 2024 Usually, unless otherwise stated, it's the "N". They stand for "normal" and "Inverted"? I think? Don't quote me on that. But if the N doesn't work, try the I. I'm sure they're out there, but I haven't seen a GMRS repeater using an "I" tone. Raybestos 1 Quote
SteveShannon Posted July 25, 2024 Report Posted July 25, 2024 24 minutes ago, amaff said: Usually, unless otherwise stated, it's the "N". They stand for "normal" and "Inverted"? I think? Don't quote me on that. But if the N doesn't work, try the I. I'm sure they're out there, but I haven't seen a GMRS repeater using an "I" tone. That’s correct. They are digital codes and the I version has the bits flipped compared to the N version. They are definitely not the same. But DPL and DCS are two different names for the same thing. amaff and Raybestos 1 1 Quote
amaff Posted July 25, 2024 Report Posted July 25, 2024 4 minutes ago, WRXP381 said: I have all my radios lined up on a desk with chargers touching. 11 HTs of different types and 2 base units. I hear the repeater on all of them when I transmit out on any of them. Desencing has never been an issue for me. I guess that must mean that the rest of us are liars I haven't tested talking through a repeater on a handheld while listening on my mobile, but all of my H/Ts, from $18 Fegs to $100 Wouxuns do it. If they're listening on 462, and another HT is transmitting on 467 in the same room, I won't hear the transmission from the radio through the repeater on any of the other radios. I'll only get the kickback after I stop transmitting SteveShannon and dosw 2 Quote
desertbird Posted July 25, 2024 Author Report Posted July 25, 2024 6 minutes ago, WRXP381 said: I have all my radios lined up on a desk with chargers touching. 11 HTs of different types and 2 base units. I hear the repeater on all of them when I transmit out on any of them. Desencing has never been an issue for me. I’d bet you’re just to far away. You can kerchunk a repeater but be too far away for it to pick up a voice signal. I’d drive closer and try again. When you hear people on the repeater try again. Ask for a radio check and introduce yourself. What radios are you using? What antennas? How far away are you from the repeater? How is the line of sight? . you will not be able to talk to your wife’s radio as a test because your transmitting on 467 and she is listening on 462 I tried to radio check. But maybe no one is listening just now. Baofeng Gm-15, AR-771 antenna, within 10 miles, Only houses in the way. So I thought the repeater used the inverse of the handheld frequency. So if both of our radios are on Rx 462.625 tx467.625 the repeater is on rx 467.625 tx 462.625 and my communication is now going through a repeater no longer simplex? Quote
SteveShannon Posted July 25, 2024 Report Posted July 25, 2024 Just now, desertbird said: I tried to radio check. But maybe no one is listening just now. Baofeng Gm-15, AR-771 antenna, within 10 miles, Only houses in the way. So I thought the repeater used the inverse of the handheld frequency. So if both of our radios are on Rx 462.625 tx467.625 the repeater is on rx 467.625 tx 462.625 and my communication is now going through a repeater no longer simplex? That’s correct but you must also send the correct CTCSS tone or DCS code in order for the repeater to pass what it receives to the transmitter. Quote
amaff Posted July 25, 2024 Report Posted July 25, 2024 2 minutes ago, desertbird said: I tried to radio check. But maybe no one is listening just now. Baofeng Gm-15, AR-771 antenna, within 10 miles, Only houses in the way. So I thought the repeater used the inverse of the handheld frequency. So if both of our radios are on Rx 462.625 tx467.625 the repeater is on rx 467.625 tx 462.625 and my communication is now going through a repeater no longer simplex? Correct, that's dulplex comms. If you want to test have your wife using it on the other side of the house or yard. Usually they just need a little bit of separation. Even if you only had 1 radio set to transmit on 467.xxx, if the other radio is listening on the appropriate *simplex* channel it'll still hear the re-transmission from repeater. ...unless it's desensing because they're too close. SteveShannon 1 Quote
desertbird Posted July 25, 2024 Author Report Posted July 25, 2024 Just now, SteveShannon said: That’s correct but you must also send the correct CTCSS tone or DCS code in order for the repeater to pass what it receives to the transmitter. Here is the repeater info: Here is how I sent programmed it. amaff 1 Quote
desertbird Posted July 25, 2024 Author Report Posted July 25, 2024 3 minutes ago, amaff said: Correct, that's dulplex comms. If you want to test have your wife using it on the other side of the house or yard. Usually they just need a little bit of separation. Even if you only had 1 radio set to transmit on 467.xxx, if the other radio is listening on the appropriate *simplex* channel it'll still hear the re-transmission from repeater. ...unless it's desensing because they're too close. Thank you, I think it's that. Quote
SteveShannon Posted July 25, 2024 Report Posted July 25, 2024 3 minutes ago, desertbird said: Here is the repeater info: Here is how I sent programmed it. That looks right. Quote
desertbird Posted July 25, 2024 Author Report Posted July 25, 2024 2 minutes ago, SteveShannon said: That looks right. I think amaff is correct, i'll walk to mail box when she gets home and test it. I use to deal with a similiar issue with drone rx and tx being too close for testing. THANK YOU ALL!!!! SteveShannon, GreggInFL and amaff 1 2 Quote
SteveShannon Posted July 25, 2024 Report Posted July 25, 2024 5 minutes ago, desertbird said: I think amaff is correct, He often is!! amaff 1 Quote
nokones Posted July 25, 2024 Report Posted July 25, 2024 1 hour ago, desertbird said: Here is the repeater info: Here is how I sent programmed it. You have the W/N setting wrong. It should be set for Narrowband. The Sun City West 625 repeater is a narrowband operating repeater and the DPL Tone polarity is Normal which you have correct. WRXB215, SteveShannon and desertbird 3 Quote
amaff Posted July 26, 2024 Report Posted July 26, 2024 5 hours ago, nokones said: You have the W/N setting wrong. It should be set for Narrowband. The Sun City West 625 repeater is a narrowband operating repeater Good coaching. I did not realize that was a thing, but I see it referenced in the 'notes' for the repeater. Would that actually preclude the radio for getting through? Or would they come in over-modulated? Quote
nokones Posted July 26, 2024 Report Posted July 26, 2024 8 hours ago, amaff said: Good coaching. I did not realize that was a thing, but I see it referenced in the 'notes' for the repeater. Would that actually preclude the radio for getting through? Or would they come in over-modulated? Yes, in some parts of the modulation It definitely would cause a lot of missed syllables from the clipping of the transmitted audio. amaff 1 Quote
amaff Posted July 26, 2024 Report Posted July 26, 2024 What's the advantage of setting a repeater up using narrowband on a service that is primarily wideband? Other than potentially weeding out people who didn't read the notes closely enough? Quote
gortex2 Posted July 26, 2024 Report Posted July 26, 2024 3 minutes ago, amaff said: What's the advantage of setting a repeater up using narrowband on a service that is primarily wideband? Other than potentially weeding out people who didn't read the notes closely enough? Mine are set for narrowband as my parents and I use Midlands. They work much better on narrowband than wideband. amaff 1 Quote
amaff Posted July 26, 2024 Report Posted July 26, 2024 Ah, yeah I could see that with their repeater capable narrow-band only radios. Quote
nokones Posted July 26, 2024 Report Posted July 26, 2024 48 minutes ago, amaff said: What's the advantage of setting a repeater up using narrowband on a service that is primarily wideband? Other than potentially weeding out people who didn't read the notes closely enough? I'm not sure how that would weed out sloppy readers but it will definitely cause their transmitting audio be clipped and have missing syllables. There is nothing wrong with narrowbanding and I support it and my Part 90 license requires the freqs to be narrowband. Quote
