desertbird Posted July 30, 2024 Report Posted July 30, 2024 I am helping my friend who is getting his license program his Baofeng UV-5RTP to same as my Baofeng GM15. Got channel 1 programmed into his and was crazy inbound traffic, see video. I thought I had programming wrong till I left my office and what appears to be interference went away. What could cause this? Frequency is GMRS channel 1 462.5625. IMG_4691.MOV Quote
desertbird Posted July 30, 2024 Author Report Posted July 30, 2024 Outside everything works, and appears I have programmed correctly. GMRS channel 2 has no issue. just wonder what things are close to that frequency and understand that a little bit. Quote
WRHS218 Posted July 30, 2024 Report Posted July 30, 2024 I am not sure what would be close to that frequency but if the interference stops when you go outside I would guess it is something in your office. Your radio may not pick it up due to the receiver being less sensitive. Just a guess. Maybe a smart person can shed some light on the subject. Quote
desertbird Posted July 30, 2024 Author Report Posted July 30, 2024 Also, the GM15 does not have the same interference on that channel. same antenna. I adjusted the squelch through all ranges on his, no real difference. Quote
RayDiddio Posted July 30, 2024 Report Posted July 30, 2024 Splashy sounding. Almost spurious in a way. Quote
SteveShannon Posted July 30, 2024 Report Posted July 30, 2024 It could be a battery charger, one of those wall warts, a computer power supply with problems, fluorescent lights, LED lights, almost anything. Unplug things until it stops. Such noise is not uncommon. WRYZ926, Sonicgott and WRXB215 3 Quote
Guest Posted July 30, 2024 Report Posted July 30, 2024 The only thing you be ever heard like that is the kids down the street playing games with the FRS radios Quote
WRYZ926 Posted July 30, 2024 Report Posted July 30, 2024 I have to agree with @WRHS218 and @SteveShannon. The interference could be anything inside the building. It is common for computer monitors (and their power supplies) and unshielded network cables to cause interference. And those cheap gas station phone chargers are bad too. I had issues with unshielded network cables causing interference with my HF radio. And my some of my computer monitors cause interference with my Baofeng GT/UV-5R and Icom IC-T10 hand held radios. Quote
emory Posted July 30, 2024 Report Posted July 30, 2024 8 minutes ago, WRYZ926 said: I have to agree with @WRHS218 and @SteveShannon. motion carries, i get this occasionally on my scanners. in the mornings it's accompanied by being able to pick up repeater output multiple states away in the morning and goes away by 8-0830 and returns in the evening. i bought an RF/EM meter to wand around and figure out where it was coming from and one of them was only happening when HVAC kicked on to run fans. another one still to be determined, it ends up being audible in other GMRS frequencies. if you have a hard time finding a meter that isn't overdoing it (some instruments are out there for thousands of dollars you don't need that) here's an old hacker trick: add "ghost hunting" to the search, since apparently "ghost hunters" follow EM/RF physics Raybestos 1 Quote
WRYZ926 Posted July 30, 2024 Report Posted July 30, 2024 You can also use your hand held radio with a small yagi antenna to find and pin point sources of interference. The rubber duck antenna will get you close but the yagi will narrow the search down. WRHS218 1 Quote
Raybestos Posted July 30, 2024 Report Posted July 30, 2024 37 minutes ago, emory said: if you have a hard time finding a meter that isn't overdoing it (some instruments are out there for thousands of dollars you don't need that) here's an old hacker trick: add "ghost hunting" to the search, since apparently "ghost hunters" follow EM/RF physics That's a great bit of advice! I always wanted one of those, anyway. Thing is, I have so many actual ghosts in my house, one of those things would probably go haywire. emory 1 Quote
nokones Posted July 30, 2024 Report Posted July 30, 2024 11 hours ago, SteveShannon said: It could be a battery charger, one of those wall warts, a computer power supply with problems, fluorescent lights, LED lights, almost anything. Unplug things until it stops. Such noise is not uncommon. An old computer with a processor clock speed close to your receive frequency will cause havoc. SteveShannon, Raybestos and emory 3 Quote
SteveShannon Posted July 30, 2024 Report Posted July 30, 2024 17 minutes ago, nokones said: An old computer with a processor clock speed close to your receive frequency will cause havoc. Yeah, I remember when we opened up a “466” (as I recall it was a 486 processor running at 66 MHz) computer case and the security guy’s handheld went ape. Raybestos 1 Quote
nokones Posted July 30, 2024 Report Posted July 30, 2024 Back in the 80s when my Area Offices were changing over from Teletypes to Computer Terminals my company radio started going ape stuff every time that I was getting close to one of our Offices. It was wideband noise that tore up the radios. Quote
nokones Posted July 30, 2024 Report Posted July 30, 2024 18 hours ago, desertbird said: I am helping my friend who is getting his license program his Baofeng UV-5RTP to same as my Baofeng GM15. Got channel 1 programmed into his and was crazy inbound traffic, see video. I thought I had programming wrong till I left my office and what appears to be interference went away. What could cause this? Frequency is GMRS channel 1 462.5625. IMG_4691.MOV I had to look up that tone on the chart. I don't think I ever seen anyone using that tone freq. Quote
SteveShannon Posted July 30, 2024 Report Posted July 30, 2024 19 hours ago, desertbird said: I am helping my friend who is getting his license program his Baofeng UV-5RTP to same as my Baofeng GM15. Got channel 1 programmed into his and was crazy inbound traffic, see video. I thought I had programming wrong till I left my office and what appears to be interference went away. What could cause this? Frequency is GMRS channel 1 462.5625. IMG_4691.MOV Set Tone Mode to TSQL and it may help. desertbird 1 Quote
quarterwave Posted July 30, 2024 Report Posted July 30, 2024 Not uncommon with those radios, mine goes ape at some traffic lights. desertbird 1 Quote
GreggInFL Posted July 31, 2024 Report Posted July 31, 2024 It goes both ways. When I key up near my computer's UPS it triggers the alarm on the UPS. Go figure. SteveShannon, WRUU653 and WRXB215 2 1 Quote
WRXB215 Posted July 31, 2024 Report Posted July 31, 2024 1 hour ago, GreggInFL said: When I key up near my computer's UPS it triggers the alarm on the UPS. Oh you could have fun with IT with that one. WRUU653, GreggInFL and WRYZ926 1 2 Quote
WRYZ926 Posted July 31, 2024 Report Posted July 31, 2024 59 minutes ago, WRXB215 said: Oh you could have fun with IT with that one. I would have fun that way when I was in the Army. The PTO driven generator on my truck mounted machine shop would totally block all radios within a 150 foot radius. WRUU653 1 Quote
desertbird Posted July 31, 2024 Author Report Posted July 31, 2024 I remember when I was about 10 years old and Radio Shack had kits for crystal radios and all kinds of cool electronic stuff that fascinated me and I spent my lawn mowing money on. I hooked up a DC motor and some other weird stuff, I don't remember what I thought I was building but it scrambled the living room TV. This was when it was broadcast over the air, no cable at all, no satelite. I had so much fun pissing my Dad off with that little machine I made. I could hear him yelling "god damn it, here it goes again". He'd get off the couch and start banging it, which was the common TV fix back then. SteveShannon, WRUU653, WRXR255 and 1 other 4 Quote
WRUU653 Posted August 1, 2024 Report Posted August 1, 2024 14 minutes ago, desertbird said: I remember when I was about 10 years old and Radio Shack had kits for crystal radios and all kinds of cool electronic stuff that fascinated me Ahh yes, I had one of those kits as a kid… Great story! I have a clear picture of what that would have looked like with my dad. Quote
WSCS601 Posted August 1, 2024 Report Posted August 1, 2024 I've seen a treadmill knock a modem offline back in the dialup days and a MRI magnet starting up interfere with printers. Quote
emory Posted September 22, 2024 Report Posted September 22, 2024 my keyfob for my car (or any audi/vw) if i'm holding it near my radio or a scanner bursts a crazy transmission that startles me every time! there's something weird with my living room i still can't nail down. my doorbell WiFi connection is unreliable and i'm using Ubiquiti gear here. the chair in the corner of that room is like a portal to another dimension or something. possibly speaker related. Quote
LeoG Posted September 24, 2024 Report Posted September 24, 2024 On 7/31/2024 at 3:04 PM, GreggInFL said: It goes both ways. When I key up near my computer's UPS it triggers the alarm on the UPS. Go figure. At 467 my handheld will trigger my headlamp, my stove and the Fein vacuum in my shop. My 20 watt mobile will turn my neighbors motion lamp on. Quote
