TelecomGuy Posted August 9, 2024 Report Posted August 9, 2024 D047N D047l Can some explain the difference between these two? My radio is a TidRadio TD-H8 Quote
1 quarterwave Posted August 9, 2024 Report Posted August 9, 2024 "When programming a radio, the technician (or user) would select one of these 84 codes, which are represented as 3-digit octal numbers in the CPS. In some Motorola models, it is possible to select Inverse DPL - this is merely a 1's complement of the DPL code and allows another ~84 codes to be used on a system." WRXB215 1 Quote
0 BoxCar Posted August 9, 2024 Report Posted August 9, 2024 The letters designate if the code is normal or inverted. I haven't dug into DCS tones enough to understand the differences. WRUU653 1 Quote
0 SteveShannon Posted August 9, 2024 Report Posted August 9, 2024 (edited) 2 hours ago, TelecomGuy said: D047N D047l Can some explain the difference between these two? My radio is a TidRadio TD-H8 DCS isn’t a tone; it’s a digital pattern. All the bits are inverted for the I version compared to the N (normal) version but that doesn’t necessarily mean there are twice as many patterns because a digital pattern that is inverted is equal to a normal pattern. For example if you invert the hexadecimal value for “A” it’s “5”. So why is that done? Good question. Edited August 9, 2024 by SteveShannon Correct my statement. It’s been too long since I’ve thought about flipping bits. RayDiddio and WRUU653 2 Quote
0 TelecomGuy Posted August 9, 2024 Author Report Posted August 9, 2024 So if something is listed as 047 DPL it would be D047N ? SteveShannon 1 Quote
0 OffRoaderX Posted August 9, 2024 Report Posted August 9, 2024 33 minutes ago, TelecomGuy said: So if something is listed as 047 DPL it would be D047N Yes. The default is Normal. WSDM599, SteveShannon and WRUU653 3 Quote
TelecomGuy
D047N
D047l
5 answers to this question
