I read through old threads about issues with the programming cable, especially with windows 11. I spent hours going through drivers trying to find a solution. Radioddity told me to download prolific 2303 driver but that is not the chip in my cable. The only driver that is recognized is CH343.
When I connect it in the software the COM channel is correct. When I attempt to read/write the radio screen shows “clone” but the read/write never initiates and then gives me a “read/write data failed” window.
I’ve done everything possible. I run the programming software as admin. I tried windows 8 compatibility mode. I even tried all of these steps on an old laptop running Windows 7 as well. Nothing seems to work.
I’m just wondering if there’s anything else people have figured out to correct this or if this is just a faulty cable that Radioddity needs to replace?
WSDT708
I manually programmed the DB20-G with no issue.
Link to comment
Share on other sites
26 answers to this question
