seanpatrickrice Posted yesterday at 05:11 AM Report Share Posted yesterday at 05:11 AM Can I cut the darn cigarette plug off and put some Anderson power poles on this so I can swap the radio from the car to an ammo can base station? Quote Link to comment Share on other sites More sharing options...
1 amaff Posted 20 hours ago Report Share Posted 20 hours ago You CAN. But unless you'll never use the cigarette lighter plug, it might make sense to pick up a socket adapter and wire that to the Anderson connector so you can preserve the stock wiring. If you never use and never plan to use the "damn" cigarette plug, then yeah go nuts. wayoverthere 1 Quote Link to comment Share on other sites More sharing options...
1 SteveShannon Posted 16 hours ago Report Share Posted 16 hours ago 12 hours ago, seanpatrickrice said: Can I cut the darn cigarette plug off and put some Anderson power poles on this so I can swap the radio from the car to an ammo can base station? I did and I put power poles on the plug end as well so I can still use the cigarette lighter power. amaff and WRXB215 2 Quote Link to comment Share on other sites More sharing options...
0 OffRoaderX Posted yesterday at 05:20 AM Report Share Posted yesterday at 05:20 AM Yes, as long as the ammo-can can feed the radio enough electricities. Quote Link to comment Share on other sites More sharing options...
0 WRXB215 Posted 21 hours ago Report Share Posted 21 hours ago Just curious, why an ammo can for a base station. Is it also going to be a go box? Quote Link to comment Share on other sites More sharing options...
0 Socalgmrs Posted 21 hours ago Report Share Posted 21 hours ago Yes for sure this can be done. But… if you have to ask do you have the skills to do this? A bad 12v wiring job can burn down your car/truck. So please be careful and make sure you have the proper connections with the proper wire size and fuses in the proper places. Quote Link to comment Share on other sites More sharing options...
0 WRXB215 Posted 21 hours ago Report Share Posted 21 hours ago 5 minutes ago, Socalgmrs said: A bad 12v wiring job can burn down your car/truck. So please be careful and make sure you have the proper connections with the proper wire size and fuses in the proper places. This is true but lets not forget the house. @seanpatrickrice what are you going to use for a power supply for the house? Quote Link to comment Share on other sites More sharing options...
seanpatrickrice
Link to comment
6 answers to this question
