WRUE951 Posted October 26, 2024 Report Posted October 26, 2024 So I wake up this morning i get an alarm from my repeater. (High SWR) So i go to check out what's going on.. My antenna (Hustler G6-450) is buckled sitting at 2 o-clock.. What the hell????? Then at the base of the mast I see a bunch of large black bird feathers, but no bird, just feathers, looking like Raven feathers... So it looks like a G*d D*mn bird hit my antenna and destroyed it ($500 bucks).. I have never ever heard this happening... Mind Blowing.. Now i'm looking to re-order and i'm seeing everyone charging nearly $200 for shipping on these things.. WTH.. Sipping cost really that high.. Looks like its time for a trip to Vega.. Quote
WRYZ926 Posted October 26, 2024 Report Posted October 26, 2024 I have not seen that happen but I have seen a buck get tangled up in guy ropes and take an antenna mast down. SteveShannon 1 Quote
Raybestos Posted October 26, 2024 Report Posted October 26, 2024 1 hour ago, WRUE951 said: So I wake up this morning i get an alarm from my repeater. (High SWR) So i go to check out what's going on.. My antenna (Hustler G6-450) is buckled sitting at 2 o-clock.. What the hell????? Then at the base of the mast I see a bunch of large black bird feathers, but no bird, just feathers, looking like Raven feathers... So it looks like a G*d D*mn bird hit my antenna and destroyed it ($500 bucks).. I have never ever heard this happening... Mind Blowing.. Now i'm looking to re-order and i'm seeing everyone charging nearly $200 for shipping on these things.. WTH.. Sipping cost really that high.. Looks like its time for a trip to Vega.. That's some crazy stuff! I am sorry for the loss of your old antenna. When your new antenna comes in, here is some music to assemble it by. Quote
WRUE951 Posted October 26, 2024 Author Report Posted October 26, 2024 8 minutes ago, Raybestos said: That's some crazy stuff! I am sorry for the loss of your old antenna. When your new antenna comes in, here is some music to assemble it by. I hate that song wayoverthere and Raybestos 2 Quote
SteveShannon Posted October 26, 2024 Report Posted October 26, 2024 Ham Radio Outlet has the antenna for $349, not including drop-shipping. https://www.hamradio.com/detail.cfm?pid=H0-003375 Raybestos 1 Quote
WRUE951 Posted October 26, 2024 Author Report Posted October 26, 2024 30 minutes ago, SteveShannon said: Ham Radio Outlet has the antenna for $349, not including drop-shipping. https://www.hamradio.com/detail.cfm?pid=H0-003375 Thanks - i checked them,, shipping is about $85 bucks.. All together not bad. I'm thinking about going with a Laird FG450 and also looking at other choices since I'm in the market. Comet is a lot cheaper but warred about the winds we get here. Gigiparts if very limited on their antenna supply. gortex2 1 Quote
BoxCar Posted October 26, 2024 Report Posted October 26, 2024 Amazon also has it for $374.13 but you may be able to get free shipping if Prime. https://www.amazon.com/Hustler-G6270-R-Station-Antenna-Connection/dp/B00FYUW6H6/ref=sr_1_9?crid=2QDOYM4F018MF&dib=eyJ2IjoiMSJ9.Vd3s9Y4qmh9yveZ29u2R0gfB6CVJaqFgmTsW3_NH2jc_y4zQhAD3IOsDYLqsPydNKEHKLSjZyYbrGG8XB6myXI4souVsXOItKD9VMRsYzxlbNpxSxfcjdYsfiKeFqk3OJXvsFCJwIMzW2uHoezGae7Zf85NGMqFkftuiuuQc4zIyDqncvw_0Rv4kdnb9ciFOU7YmLX6UnEBsMCbgQeqFK3EfeaqeRTqisOH5bpn6DIc.lSJybktqJKFsJKYNI-4OUizVnJKoEN2X0pQDjQ0j1EE&dib_tag=se&keywords=hustler+g6+antenna&qid=1729965713&sprefix=hustler+g6+antenna%2Caps%2C97&sr=8-9 Raybestos and SteveShannon 2 Quote
WRUE951 Posted October 26, 2024 Author Report Posted October 26, 2024 2 hours ago, BoxCar said: Amazon also has it for $374.13 but you may be able to get free shipping if Prime. https://www.amazon.com/Hustler-G6270-R-Station-Antenna-Connection/dp/B00FYUW6H6/ref=sr_1_9?crid=2QDOYM4F018MF&dib=eyJ2IjoiMSJ9.Vd3s9Y4qmh9yveZ29u2R0gfB6CVJaqFgmTsW3_NH2jc_y4zQhAD3IOsDYLqsPydNKEHKLSjZyYbrGG8XB6myXI4souVsXOItKD9VMRsYzxlbNpxSxfcjdYsfiKeFqk3OJXvsFCJwIMzW2uHoezGae7Zf85NGMqFkftuiuuQc4zIyDqncvw_0Rv4kdnb9ciFOU7YmLX6UnEBsMCbgQeqFK3EfeaqeRTqisOH5bpn6DIc.lSJybktqJKFsJKYNI-4OUizVnJKoEN2X0pQDjQ0j1EE&dib_tag=se&keywords=hustler+g6+antenna&qid=1729965713&sprefix=hustler+g6+antenna%2Caps%2C97&sr=8-9 thanks for suggestion, however that one is not tuned to GMRS.. Haven't found one on Prime yet but I'm looking. Raybestos 1 Quote
WSFG777 Posted October 27, 2024 Report Posted October 27, 2024 Call Hustler, they should be happy to sell you individual replacement parts, all cut to fit. It’s standard practice for antenna manufacturers to sell the parts, usually all the part numbers are in the owners manual. Years ago someone gave me an old 2m Ringo with a broken center insulator, and I bought the replacement part for a few bucks. If buying parts from Hustler fails, maybe you can straighten the wire and “Max Gain Systems” sells fiberglass tubing. hope that helps, Joe K1VW SteveShannon 1 Quote
WRUE951 Posted October 28, 2024 Author Report Posted October 28, 2024 18 hours ago, WSFG777 said: Call Hustler, they should be happy to sell you individual replacement parts, all cut to fit. It’s standard practice for antenna manufacturers to sell the parts, usually all the part numbers are in the owners manual. Years ago someone gave me an old 2m Ringo with a broken center insulator, and I bought the replacement part for a few bucks. If buying parts from Hustler fails, maybe you can straighten the wire and “Max Gain Systems” sells fiberglass tubing. hope that helps, Joe K1VW I did,, they said the antenna is all one piece. I also tried taking a one foot section of 1 inch PVC conduit and wedging it down over the bent section.... It did support the damaged area very well but didn't work for the internal damage - still bad SWR. I'm gonna digest the antenna to see how it is built. in the meantime i think im gonna go with a Laird FG4607.. Hard to find a seller not charging arm and leg for shipping.. For right how I'm using an old home brew J-Pole i had and it's actually doing pretty good.... Getting 1:2 across the GMRS Band and talked with someone in 9-mile canyon, about 45 miles out.. Quote
piggin Posted October 28, 2024 Report Posted October 28, 2024 1 hour ago, WRUE951 said: I did,, they said the antenna is all one piece. I also tried taking a one foot section of 1 inch PVC conduit and wedging it down over the bent section.... It did support the damaged area very well but didn't work for the internal damage - still bad SWR. I'm gonna digest the antenna to see how it is built. in the meantime i think im gonna go with a Laird FG4607.. Hard to find a seller not charging arm and leg for shipping.. For right how I'm using an old home brew J-Pole i had and it's actually doing pretty good.... Getting 1:2 across the GMRS Band and talked with someone in 9-mile canyon, about 45 miles out.. I bought my Laird/ TE connectivity FG4607 from Mouser. 249 ish dollars. Shipping was 9.95! I apparently bought the last one in stock and it got here the day before the hurricane arrived. It is an excellent antenna...that varies wildly in price! Quote
WRUE951 Posted October 28, 2024 Author Report Posted October 28, 2024 21 minutes ago, piggin said: I bought my Laird/ TE connectivity FG4607 from Mouser. 249 ish dollars. Shipping was 9.95! I apparently bought the last one in stock and it got here the day before the hurricane arrived. It is an excellent antenna...that varies wildly in price! Wow,, thanks for the lead. I just placed an order same price.. That's a good deal. It's back ordered, but i got more time than i got money, so its good.. THANKS! Quote
piggin Posted October 28, 2024 Report Posted October 28, 2024 3 hours ago, WRUE951 said: Wow,, thanks for the lead. I just placed an order same price.. That's a good deal. It's back ordered, but i got more time than i got money, so its good.. THANKS! You are welcome! I bet the price goes up when they are in stock again. You scored! Quote
WRUE951 Posted October 28, 2024 Author Report Posted October 28, 2024 1 hour ago, piggin said: You are welcome! I bet the price goes up when they are in stock again. You scored! that is the best price i've seen for that antenna and the shipping cost, $9.00 is crazy low. The lowest i found was $80 bucks shipping.. I actually called them to order, he sad they have couple dozen on order and that they sell a lot of these.. Defiantly the best place to grab a good antenna.. They also sell quality connectors at crazy low prices.. I'll be buying a few things from these folks. Quote
WRUE951 Posted November 5, 2024 Author Report Posted November 5, 2024 Hustler Antennas said it can't be fixed.. Well, its fixed and better than the factory fiberglass shell. One inch pipe fits like it was meant to be and a taper to 3/4 inch finishes it .. Back to business. amaff 1 Quote
