WSDF258 Posted October 31, 2024 Report Posted October 31, 2024 I'm brand new to GMRS and just bought my first two radios (ICOM IC-F21GM) used from eBay. The radios are in really nice shape and are barely used in the factory boxes and appear to hold a charge just fine. When I first received the units, one channel was working to transmit from radio one and receive on radio two, but could not transmit from radio two to radio one. I attempted to follow the instruction manual to setup one channel for each unit to communicate bath and forth, but now they don't work on any channel after trying to change the settings. I would like to have a simple setup for them work together for around the yard, so not trying to do anything complex. For someone that is new to radios in general, what's the easiest way to setup these radios? Is my best bet to purchase the cable and software that work with these radios or is there a better way to do it? Quote
SteveShannon Posted October 31, 2024 Report Posted October 31, 2024 4 minutes ago, WSDF258 said: I'm brand new to GMRS and just bought my first two radios (ICOM IC-F21GM) used from eBay. The radios are in really nice shape and are barely used in the factory boxes and appear to hold a charge just fine. When I first received the units, one channel was working to transmit from radio one and receive on radio two, but could not transmit from radio two to radio one. I attempted to follow the instruction manual to setup one channel for each unit to communicate bath and forth, but now they don't work on any channel after trying to change the settings. I would like to have a simple setup for them work together for around the yard, so not trying to do anything complex. For someone that is new to radios in general, what's the easiest way to setup these radios? Is my best bet to purchase the cable and software that work with these radios or is there a better way to do it? First, for every channel, remove any CTCSS tones or DCS codes on both transmit and receive. Then just change them both to the same channel and you should be able to transmit from one to the other. Don’t try to transmit from one to the other when they’re just a few feet (or inches) from each other. That can cause desensing, which is when the strong transmit power from one overwhelms the sensitive receiver of the other. Put some distance between them. Good luck! WRHS218, WRUU653 and WRXB215 3 Quote
amaff Posted October 31, 2024 Report Posted October 31, 2024 44 minutes ago, WSDF258 said: just bought my first two radios (ICOM IC-F21GM) used from eBay SteveShannon and WRUU653 2 Quote
Guest Posted October 31, 2024 Report Posted October 31, 2024 Get a programming cable and what ever program they use. This will make your life 1000xs easier. You unfortunately didn’t pick the best beginner radios to start with. Your learning curve is going to be steep. Quote
WSDF258 Posted October 31, 2024 Author Report Posted October 31, 2024 Thank you for the responses and appreciate the insight from veterans. I have tried to remove the CTCSS tones and DCS codes, but still no luck. I will plan to purchase the cables and software and give that a shot. Quote
SteveShannon Posted October 31, 2024 Report Posted October 31, 2024 10 minutes ago, WSDF258 said: Thank you for the responses and appreciate the insight from veterans. I have tried to remove the CTCSS tones and DCS codes, but still no luck. I will plan to purchase the cables and software and give that a shot. Okay, but please don’t give up on learning to set and clear tones from the front panel. The Icom is a good radio. Being able to program it from the front panel could be extremely useful. Quote
SteveShannon Posted October 31, 2024 Report Posted October 31, 2024 If you're really thinking of spending $75 on programming software, I would recommend spending the same amount of money to get more current radios instead. WRUU653 1 Quote
wayoverthere Posted October 31, 2024 Report Posted October 31, 2024 Bluemax49ers has been my source for cables for most of the LMR radios in my collection, and some of the software as well. It does look like he has a cable for those Icoms, too, with an option to add the software. https://bluemax49ers.com/product-explorer/icom-ic-f21gm-ftdi-programming-cable-opc-i478/ WSDF258, SteveShannon and WRUU653 3 Quote
Lscott Posted November 1, 2024 Report Posted November 1, 2024 On 10/31/2024 at 9:39 AM, WSDF258 said: I'm brand new to GMRS and just bought my first two radios (ICOM IC-F21GM) used from eBay. The radios are in really nice shape and are barely used in the factory boxes and appear to hold a charge just fine. I hope you got the right band frequency range. Those radios come in two different ones. One of which would be basically useless. You want the 440-470 range. You should be able to tell from the FCC ID tag on the back of the radio. It should match the one found here: https://fccid.io/AFJIC-F21 Which seems to show the radio is certified for Part 95A, which is the old rule part for GMRS. This means it's still perfectly legal to use under the new rules. Looks like a nice solid basic radio. icom_ic_f11_f21_brochure.pdf WRXB215, WRUU653 and WSDF258 3 Quote
gortex2 Posted November 2, 2024 Report Posted November 2, 2024 The F21GM was the UHF GMRS Version of the radio. When I was an ICOM dealer we sold a ton of them to hunters. It was firmware locked to GMRS/FRS. https://www.ameradio.com/doc/Icom_IC-F21GM_brochure.pdf WSDF258 1 Quote
WSDF258 Posted November 11, 2024 Author Report Posted November 11, 2024 On 11/2/2024 at 6:02 AM, gortex2 said: The F21GM was the UHF GMRS Version of the radio. When I was an ICOM dealer we sold a ton of them to hunters. It was firmware locked to GMRS/FRS. https://www.ameradio.com/doc/Icom_IC-F21GM_brochure.pdf I tried all weekend to program the IC-F21GM's using the software and cable and even after making sure they share the same settings, no luck. I can read and write to the radios, but when I turn to the same channel on each unit they don't seem to transmit or receive. Any suggestions are appreciated. Screenshot below of how each radio is currently setup. Quote
SteveShannon Posted November 11, 2024 Report Posted November 11, 2024 23 minutes ago, WSDF258 said: I tried all weekend to program the IC-F21GM's using the software and cable and even after making sure they share the same settings, no luck. I can read and write to the radios, but when I turn to the same channel on each unit they don't seem to transmit or receive. Any suggestions are appreciated. Screenshot below of how each radio is currently setup. Edited: 1-8 would only work through a repeater. If you want to transmit directly from one radio to another you must have the transmit and receive frequencies the same. WRUU653 1 Quote
WRUU653 Posted November 11, 2024 Report Posted November 11, 2024 I’m not familiar with the software. Are the lines in the TX tone column indicating it’s set the same as RX? Quote
WSDF258 Posted November 11, 2024 Author Report Posted November 11, 2024 Just now, WRUU653 said: I’m not familiar with the software. Are the lines in the TX tone column indicating it’s set the same as RX? That's correct WRUU653 1 Quote
SteveShannon Posted November 11, 2024 Report Posted November 11, 2024 3 minutes ago, WRUU653 said: I’m not familiar with the software. Are the lines in the TX tone column indicating it’s set the same as RX? Good catch, Gil. I was wrong. He has 1-8 set as repeater channels. 9-15 are set for simplex. I would clear out tones at first though. WRUU653 1 Quote
