koni13 Posted November 8, 2024 Report Posted November 8, 2024 Hello everyone appears I have lost all the data programmed on UV82 radios via CHIRP. Anyone have a suggestions or supply a cheat sheet to re-enter and program radios. Quote
SteveShannon Posted November 8, 2024 Report Posted November 8, 2024 On 11/8/2024 at 5:45 PM, koni13 said: Hello everyone appears I have lost all the data programmed on UV82 radios via CHIRP. Anyone have a suggestions or supply a cheat sheet to re-enter and program radios. Expand Read it from the radio. Quote
koni13 Posted November 8, 2024 Author Report Posted November 8, 2024 On 11/8/2024 at 5:47 PM, SteveShannon said: Read it from the radio. Expand Steve appreciate, however the repeaters and or frequencies are deleted. Sensing are the generic ones coming with radio. On CHIRP only the first frequency is displayed. Will contact the manufacturer directly, thanks again. Quote
WRYZ926 Posted November 8, 2024 Report Posted November 8, 2024 On 11/8/2024 at 6:05 PM, koni13 said: Steve appreciate, however the repeaters and or frequencies are deleted. Sensing are the generic ones coming with radio. On CHIRP only the first frequency is displayed. Will contact the manufacturer directly, thanks again. Expand CHIRP will normally input the correct frequencies when you choose the offset. For GMRS that is a positive offset of 5.000 MHz Did the radio loose its programming? And did you save the CHIRP file after making changes and before uploading to the radio? If so, then you should be able to re-download the file to your radio. koni13 1 Quote
SteveShannon Posted November 8, 2024 Report Posted November 8, 2024 On 11/8/2024 at 6:05 PM, koni13 said: Steve appreciate, however the repeaters and or frequencies are deleted. Sensing are the generic ones coming with radio. On CHIRP only the first frequency is displayed. Will contact the manufacturer directly, thanks again. Expand In Chirp you have the ability to load all of the default GMRS channels. Would that help? You should also have the ability to import nearby GMRS repeater channels from Repeaterbook into Chirp. koni13 1 Quote
Guest Posted November 8, 2024 Report Posted November 8, 2024 Wow that sucks. This is why you gotta save the original file and the new file and back everything up. I go so far as to drop all my files not a usb drive. do you not have other radios you can download from? It’s odd that the radio and the chirp file are both messed up Quote
koni13 Posted November 8, 2024 Author Report Posted November 8, 2024 On 11/8/2024 at 6:48 PM, Socalgmrs said: Wow that sucks. This is why you gotta save the original file and the new file and back everything up. I go so far as to drop all my files not a usb drive. do you not have other radios you can download from? It’s odd that the radio and the chirp file are both messed up Expand Luckily I sense I can clone one radio to the other, viewing frequencies and repeaters were maintained for 1-radio. In your experience is there any particular radio GMRS and or HAM you favor. Thanks in advance! Quote
koni13 Posted November 10, 2024 Author Report Posted November 10, 2024 Ok guys, appreciate all the insight provided. Gain all the programing on CHIRP and a happy camper, somehow I delete yet had a copy on another computer. My next questions is attempting to add repeaters and if not provided a plus or minus how do you figure out what to place. Also notice some repeaters have a DN assigned number while others may have a offset, so confusing. Quote
BoxCar Posted November 10, 2024 Report Posted November 10, 2024 All repeaters are +5 - period. The gods at the FCC have spoken and we must obey. Unless a digital code is followed by the I (eye) it is normal. Quote
OffRoaderX Posted November 10, 2024 Report Posted November 10, 2024 On 11/10/2024 at 12:46 AM, BoxCar said: the gods at the FCC have spoken and we must obey.. Expand OVERLORDS, not gods... WSEZ 1 Quote
koni13 Posted November 10, 2024 Author Report Posted November 10, 2024 On 11/10/2024 at 12:46 AM, BoxCar said: All repeaters are +5 - period. The gods at the FCC have spoken and we must obey. Unless a digital code is followed by the I (eye) it is normal. Expand After numerous YouTube videos, finally came across one which explained easily repeater setups. Failed to understand step of deleting channel, followed by memory channel 3X to save, receive and transmit. Now I'm on repeater book manually inserting repeaters!!!! Quote
SteveShannon Posted November 10, 2024 Report Posted November 10, 2024 On 11/10/2024 at 2:47 AM, koni13 said: After numerous YouTube videos, finally came across one which explained easily repeater setups. Failed to understand step of deleting channel, followed by memory channel 3X to save, receive and transmit. Now I'm on repeater book manually inserting repeaters!!!! Expand Can’t you use Chirp? Chirp will import from RepeaterBook. koni13 1 Quote
