koni13 Posted November 8 Report Share Posted November 8 Hello everyone appears I have lost all the data programmed on UV82 radios via CHIRP. Anyone have a suggestions or supply a cheat sheet to re-enter and program radios. Quote Link to comment Share on other sites More sharing options...
SteveShannon Posted November 8 Report Share Posted November 8 1 minute ago, koni13 said: Hello everyone appears I have lost all the data programmed on UV82 radios via CHIRP. Anyone have a suggestions or supply a cheat sheet to re-enter and program radios. Read it from the radio. Quote Link to comment Share on other sites More sharing options...
koni13 Posted November 8 Author Report Share Posted November 8 16 minutes ago, SteveShannon said: Read it from the radio. Steve appreciate, however the repeaters and or frequencies are deleted. Sensing are the generic ones coming with radio. On CHIRP only the first frequency is displayed. Will contact the manufacturer directly, thanks again. Quote Link to comment Share on other sites More sharing options...
WRYZ926 Posted November 8 Report Share Posted November 8 Just now, koni13 said: Steve appreciate, however the repeaters and or frequencies are deleted. Sensing are the generic ones coming with radio. On CHIRP only the first frequency is displayed. Will contact the manufacturer directly, thanks again. CHIRP will normally input the correct frequencies when you choose the offset. For GMRS that is a positive offset of 5.000 MHz Did the radio loose its programming? And did you save the CHIRP file after making changes and before uploading to the radio? If so, then you should be able to re-download the file to your radio. koni13 1 Quote Link to comment Share on other sites More sharing options...
SteveShannon Posted November 8 Report Share Posted November 8 3 hours ago, koni13 said: Steve appreciate, however the repeaters and or frequencies are deleted. Sensing are the generic ones coming with radio. On CHIRP only the first frequency is displayed. Will contact the manufacturer directly, thanks again. In Chirp you have the ability to load all of the default GMRS channels. Would that help? You should also have the ability to import nearby GMRS repeater channels from Repeaterbook into Chirp. koni13 1 Quote Link to comment Share on other sites More sharing options...
Socalgmrs Posted November 8 Report Share Posted November 8 Wow that sucks. This is why you gotta save the original file and the new file and back everything up. I go so far as to drop all my files not a usb drive. do you not have other radios you can download from? It’s odd that the radio and the chirp file are both messed up Quote Link to comment Share on other sites More sharing options...
koni13 Posted November 8 Author Report Share Posted November 8 2 hours ago, Socalgmrs said: Wow that sucks. This is why you gotta save the original file and the new file and back everything up. I go so far as to drop all my files not a usb drive. do you not have other radios you can download from? It’s odd that the radio and the chirp file are both messed up Luckily I sense I can clone one radio to the other, viewing frequencies and repeaters were maintained for 1-radio. In your experience is there any particular radio GMRS and or HAM you favor. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
koni13 Posted November 10 Author Report Share Posted November 10 Ok guys, appreciate all the insight provided. Gain all the programing on CHIRP and a happy camper, somehow I delete yet had a copy on another computer. My next questions is attempting to add repeaters and if not provided a plus or minus how do you figure out what to place. Also notice some repeaters have a DN assigned number while others may have a offset, so confusing. Quote Link to comment Share on other sites More sharing options...
BoxCar Posted November 10 Report Share Posted November 10 All repeaters are +5 - period. The gods at the FCC have spoken and we must obey. Unless a digital code is followed by the I (eye) it is normal. Quote Link to comment Share on other sites More sharing options...
OffRoaderX Posted November 10 Report Share Posted November 10 16 minutes ago, BoxCar said: the gods at the FCC have spoken and we must obey.. OVERLORDS, not gods... WSEZ 1 Quote Link to comment Share on other sites More sharing options...
koni13 Posted November 10 Author Report Share Posted November 10 1 hour ago, BoxCar said: All repeaters are +5 - period. The gods at the FCC have spoken and we must obey. Unless a digital code is followed by the I (eye) it is normal. After numerous YouTube videos, finally came across one which explained easily repeater setups. Failed to understand step of deleting channel, followed by memory channel 3X to save, receive and transmit. Now I'm on repeater book manually inserting repeaters!!!! Quote Link to comment Share on other sites More sharing options...
SteveShannon Posted November 10 Report Share Posted November 10 7 hours ago, koni13 said: After numerous YouTube videos, finally came across one which explained easily repeater setups. Failed to understand step of deleting channel, followed by memory channel 3X to save, receive and transmit. Now I'm on repeater book manually inserting repeaters!!!! Can’t you use Chirp? Chirp will import from RepeaterBook. koni13 1 Quote Link to comment Share on other sites More sharing options...
