OldJunk2 Posted December 24, 2024 Report Posted December 24, 2024 I can't find a setting in the programming software from radioddity and it isn't adjustable from the radio. I can't get this radio to transmit. I can listen to local repeaters but I can't hit them. One repeater tower is less than 5 miles away, direct line of sight, from my house. I can't hear my transmission on simplex from my DB20 to my mobile KG-1000G-PLUS in my vehicle sitting in the driveway. My gut says the mic gain is turned down or off. How do I adjust? Quote
SteveShannon Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 11:45 AM, OldJunk2 said: I can't find a setting in the programming software from radioddity and it isn't adjustable from the radio. I can't get this radio to transmit. I can listen to local repeaters but I can't hit them. One repeater tower is less than 5 miles away, direct line of sight, from my house. I can't hear my transmission on simplex from my DB20 to my mobile KG-1000G-PLUS in my vehicle sitting in the driveway. My gut says the mic gain is turned down or off. How do I adjust? Expand I’ve not found a mic gain setting but there is an xmit inhibit setting. Which channel is it? Post your configuration file and let us look at it. There is a per channel checkbox for Compander, which just sounds bad on the db20. I recommend unchecking it. And Merry Christmas! Raybestos 1 Quote
tcp2525 Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 11:45 AM, OldJunk2 said: I can't find a setting in the programming software from radioddity and it isn't adjustable from the radio. I can't get this radio to transmit. I can listen to local repeaters but I can't hit them. One repeater tower is less than 5 miles away, direct line of sight, from my house. I can't hear my transmission on simplex from my DB20 to my mobile KG-1000G-PLUS in my vehicle sitting in the driveway. My gut says the mic gain is turned down or off. How do I adjust? Expand It sounds more of an issue of a defective mic element or broken wire going to the radio. As for an adjustable feature for gain, you really don't need one if the radio was calibrated correctly from the factory. I'm assuming you are hearing a carrier with no audio? Quote
WRYS709 Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 11:45 AM, OldJunk2 said: I can't find a setting in the programming software from radioddity and it isn't adjustable from the radio. I can't get this radio to transmit. I can listen to local repeaters but I can't hit them. One repeater tower is less than 5 miles away, direct line of sight, from my house. I can't hear my transmission on simplex from my DB20 to my mobile KG-1000G-PLUS in my vehicle sitting in the driveway. My gut says the mic gain is turned down or off. How do I adjust? Expand How long have you had the DB20-G? Did it work before? You are probably encountering "desense" between your DB20-G and the mobile as they are too close to each other. If you can drive away and have someone work you from the DB20-G that is a better test. What Channel are you using for Simplex? The older units, including the Anytone AT-779UVs, did have a microphone hole issue, but the more recent generation of these mini-mobiles have mostly fixed that problem. Don't use Tones for Receive for now. That may also be the problem. SteveShannon and OldJunk2 2 Quote
OldJunk2 Posted December 24, 2024 Author Report Posted December 24, 2024 On 12/24/2024 at 12:56 PM, tcp2525 said: It sounds more of an issue of a defective mic element or broken wire going to the radio. As for an adjustable feature for gain, you really don't need one if the radio was calibrated correctly from the factory. I'm assuming you are hearing a carrier with no audio? Expand Correct, I can hear conversations, they can't hear me Quote
OffRoaderX Posted December 24, 2024 Report Posted December 24, 2024 are you transmitting, but with no audio, or are you not even transmitting? Quote
OldJunk2 Posted December 24, 2024 Author Report Posted December 24, 2024 On 12/24/2024 at 6:01 PM, WRYS709 said: How long have you had the DB20-G? Did it work before? You are probably encountering "desense" between your DB20-G and the mobile as they are too close to each other. If you can drive away and have someone work you from the DB20-G that is a better test. What Channel are you using for Simplex? The older units, including the Anytone AT-779UVs, did have a microphone hole issue, but the more recent generation of these mini-mobiles have mostly fixed that problem. Don't use Tones for Receive for now. That may also be the problem. Expand I do have recieve tones on all of mt gmrs radios. Not having any issues on my other radios. Are we not supposed to program in recieve tones? I'm a ametur operator also, we always use tones for in/out Quote
OldJunk2 Posted December 24, 2024 Author Report Posted December 24, 2024 On 12/24/2024 at 9:10 PM, OffRoaderX said: are you transmitting, but with no audio, or are you not even transmitting? Expand I'm not getting any audio out. Quote
OffRoaderX Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 9:12 PM, OldJunk2 said: I'm not getting any audio out. Expand Ok - so, just to confirm. other radios are picking up the signal, correct? So you know that the radio is transmitting? Quote
OldJunk2 Posted December 24, 2024 Author Report Posted December 24, 2024 On 12/24/2024 at 9:27 PM, OffRoaderX said: Ok - so, just to confirm. other radios are picking up the signal, correct? So you know that the radio is transmitting? Expand No, no one can hear me on this radio. My other 3 gmrs mobiles and 4 HT's work great Quote
OffRoaderX Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 10:38 PM, OldJunk2 said: No, no one can hear me on this radio. My other 3 gmrs mobiles and 4 HT's work great Expand I am trying to make a determination between the radio transmitting, but with no audio, and the radio not transmitting at all - and you still have not confirmed which is occurring. These are two very different things with two very different causes. Please answer either #1 or #2 Answer number one: the guys at the other end are receiving a signal when I transmit, but with no voice Answer number two: the guys at the other end are not receiving any transmission/signal at all. Quote
SteveShannon Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 11:00 PM, OffRoaderX said: I am trying to make a determination between the radio transmitting, but with no audio, and the radio not transmitting at all - and you still have not confirmed which is occurring. These are two very different things with two very different causes. Please answer either #1 or #2 Answer number one: the guys at the other end are receiving a signal when I transmit, but with no voice Answer number two: the guys at the other end are not receiving any transmission/signal at all. Expand Pardon the intrusion, Question 0: does the screen indicate the radio is transmitting when the PTT is pressed. Quote
OldJunk2 Posted December 24, 2024 Author Report Posted December 24, 2024 On 12/24/2024 at 11:00 PM, OffRoaderX said: I am trying to make a determination between the radio transmitting, but with no audio, and the radio not transmitting at all - and you still have not confirmed which is occurring. These are two very different things with two very different causes. Please answer either #1 or #2 Answer number one: the guys at the other end are receiving a signal when I transmit, but with no voice Answer number two: the guys at the other end are not receiving any transmission/signal at all. Expand I'm not hitting the repeater My original question is if it could simply be that the mic gain is low, I've had this programming problem on HT's in the past. This unit is a base station. I live in a HOA, so my antenna is in the attic along with my 2m antenna. My 2m hits repeaters as far as 65 miles away. It's not an interference issue. My current gmrs base antenna is a comet ground plane and I'm using M&P low loss UHF coax Quote
OldJunk2 Posted December 24, 2024 Author Report Posted December 24, 2024 On 12/24/2024 at 11:37 PM, SteveShannon said: Pardon the intrusion, Question 0: does the screen indicate the radio is transmitting when the PTT is pressed. Expand Yes, I get a full red line showing TX SteveShannon 1 Quote
SteveShannon Posted December 24, 2024 Report Posted December 24, 2024 On 12/24/2024 at 11:41 PM, OldJunk2 said: Yes, I get a full red line showing TX Expand Is the frequency shown when transmitting the correct one? Quote
WRYS709 Posted December 25, 2024 Report Posted December 25, 2024 How long have you had the DB20-G? Did it work before; that is, have others heard you? Yes: I recommend leaving out Receive Tones for now Quote
WSAM454 Posted December 25, 2024 Report Posted December 25, 2024 It is still not clear if you are actually transmitting a carrier or not. It may not matter if the radio shows a full red line or not. If you key the radio, can you hear an audio-less signal (carrier) on another radio? if not, then you are not actually transmitting, and mic gain really does not enter into whether or not you are hitting a repeater, since it is the carrier that will activate the repeater, even if you have no audio. If another radio can 'hear' your carrier, but no audio when you talk, then the mic may be defective. Another thought: Does the repeater you are trying to access have a CTCSS (PL) tone needed by your transmitter, and if so, are you sure you have it programmed in correctly? Quote
OldJunk2 Posted December 25, 2024 Author Report Posted December 25, 2024 On 12/24/2024 at 11:55 PM, SteveShannon said: Is the frequency shown when transmitting the correct one? Expand Yes SteveShannon 1 Quote
OldJunk2 Posted December 25, 2024 Author Report Posted December 25, 2024 On 12/25/2024 at 12:06 AM, WRYS709 said: How long have you had the DB20-G? Did it work before; that is, have others heard you? Yes: I recommend leaving out Receive Tones for now Expand It's brand new, maybe a week old Quote
OldJunk2 Posted December 25, 2024 Author Report Posted December 25, 2024 On 12/25/2024 at 1:10 AM, WSAM454 said: It is still not clear if you are actually transmitting a carrier or not. It may not matter if the radio shows a full red line or not. If you key the radio, can you hear an audio-less signal (carrier) on another radio? if not, then you are not actually transmitting, and mic gain really does not enter into whether or not you are hitting a repeater, since it is the carrier that will activate the repeater, even if you have no audio. If another radio can 'hear' your carrier, but no audio when you talk, then the mic may be defective. Another thought: Does the repeater you are trying to access have a CTCSS (PL) tone needed by your transmitter, and if so, are you sure you have it programmed in correctly? Expand Yes, I've tried hitting two separate repeaters that are both line of sight from my house. I'm using the same tones that are working with my 6 other radios. One repeater is a few miles away at 3000ft, the other is 12 miles away at 1500ft. I can physically see the repeaters from my house, which is on the side of a mountain at 1000ft It's either a programming issue, or faulty equipment. I'm going to hook my nanovna up tomorrow and test my antenna and coax, then go from there SteveShannon 1 Quote
SteveShannon Posted December 25, 2024 Report Posted December 25, 2024 On 12/25/2024 at 1:26 AM, OldJunk2 said: Yes Expand What frequency shows on transmit? Quote
OffRoaderX Posted December 25, 2024 Report Posted December 25, 2024 On 12/25/2024 at 1:32 AM, OldJunk2 said: I'm going to hook my nanovna up tomorrow and test my antenna and coax, then go from there Expand You should hook up your power meter to see if anything is coming out of the radio, and how much. Quote
OldJunk2 Posted December 25, 2024 Author Report Posted December 25, 2024 On 12/25/2024 at 1:39 AM, OffRoaderX said: You should hook up your power meter to see if anything is coming out of the radio, and how much. Expand I hooked up a dummy load when i first got it and it's constantly putting out 17w on high. I will check it again Quote
OffRoaderX Posted December 25, 2024 Report Posted December 25, 2024 On 12/25/2024 at 1:45 AM, OldJunk2 said: I hooked up a dummy load when i first got it and it's constantly putting out 17w Expand I assume you mean the dummy load AND your power meter? or are you relying on what the internal meter of the radio says (if it has one?) Quote
SteveShannon Posted December 25, 2024 Report Posted December 25, 2024 On 12/25/2024 at 1:45 AM, OldJunk2 said: I hooked up a dummy load when i first got it and it's constantly putting out 17w on high. I will check it again Expand Using an antenna my db20g puts out about 19 watts on high power, 6-7 watts on medium, and 3-4 watts on low power. Quote
