OldJunk2 Posted December 25, 2024 Author Posted December 25, 2024 49 minutes ago, OffRoaderX said: I assume you mean the dummy load AND your power meter? or are you relying on what the internal meter of the radio says (if it has one?) Dummy load and sure com meter OffRoaderX 1 Quote
WRYS709 Posted December 25, 2024 Posted December 25, 2024 3 hours ago, OldJunk2 said: It's brand new, maybe a week old Sound like a bad unit to me; return for a swap if none of the suggested steps solves the problem Quote
tcp2525 Posted December 25, 2024 Posted December 25, 2024 Come on folks, Oppenheimer didn't have this much difficulty building the atomic bomb. I wonder how he would have fared against a Chinese radio? Raybestos 1 Quote
WRYS709 Posted December 25, 2024 Posted December 25, 2024 4 hours ago, tcp2525 said: Come on folks, Oppenheimer didn't have this much difficulty building the atomic bomb. I wonder how he would have fared against a Chinese radio? Christmas Spirit! tcp2525 1 Quote
SteveShannon Posted December 25, 2024 Posted December 25, 2024 13 hours ago, WRYS709 said: Sound like a bad unit to me; return for a swap if none of the suggested steps solves the problem Could still be coax, antenna, incorrect frequency or tone. Once @OldJunk2 has finished troubleshooting it’s certainly possible that it’s a bad unit, but giving up now would be premature. Quote
LeoG Posted December 26, 2024 Posted December 26, 2024 On 12/24/2024 at 6:37 PM, SteveShannon said: Pardon the intrusion, Question 0: does the screen indicate the radio is transmitting when the PTT is pressed. I know on my KGXS20G when the output went dead the radio still looked like it was transmitting. Only way I could tell was to put my watt meter on the output to find out it was zilch. SteveShannon and WRYZ926 2 Quote
OldJunk2 Posted December 27, 2024 Author Posted December 27, 2024 Update: I'm a dummy. I had the TX tones entered into the RX of the programming. The radio is performing as good as a 20w should. I'm getting 15.5w on high with a SWR of 1.4 to 1 as tested with my NanoVNA SteveShannon 1 Quote
tcp2525 Posted December 27, 2024 Posted December 27, 2024 3 hours ago, OldJunk2 said: Update: I'm a dummy. I had the TX tones entered into the RX of the programming. The radio is performing as good as a 20w should. I'm getting 15.5w on high with a SWR of 1.4 to 1 as tested with my NanoVNA You did good, son. Generally, these issues are self correcting as the user gets more familiar with their radio. Now you will really enjoy the DB20 as its an amazingly good sub-$100 radio. SteveShannon and OldJunk2 2 Quote
WRYS709 Posted December 28, 2024 Posted December 28, 2024 Glad to hear that the suggested tips worked for you, so that you do not have to return your DB20-G. I 2nd @tcp2525's comment that it is a terrific radio. I have purchased two DB20-Gs and my original Anytone AT-779UV. OldJunk2 1 Quote
