SvenMarbles Posted February 2, 2025 Posted February 2, 2025 So the online repeater audio monitoring on the MyGMRS map hasn't been functional for a while. I assume that it correlates with when everyone took their links down for repeater linking. But, if I understand things correctly, the language clarification was such that it disallowed linking machines to each other via the internet. But does that necessarily mean that standalone machines cannot continue to provide an audio stream to MyGMRS for monitoring? I'd kind of like to see this feature return. I actually had some pretty good utility for it (hearing your own incoming at a remote site to better understand how you're doing). Quote
SteveShannon Posted February 2, 2025 Posted February 2, 2025 31 minutes ago, SvenMarbles said: So the online repeater audio monitoring on the MyGMRS map hasn't been functional for a while. I assume that it correlates with when everyone took their links down for repeater linking. But, if I understand things correctly, the language clarification was such that it disallowed linking machines to each other via the internet. But does that necessarily mean that standalone machines cannot continue to provide an audio stream to MyGMRS for monitoring? I'd kind of like to see this feature return. I actually had some pretty good utility for it (hearing your own incoming at a remote site to better understand how you're doing). I don’t know, but I was apparently wrong in my interpretation of the actual rules anyway. This sentence from the commission’s interpretation might indicate that sound cannot be streamed: Quote Repeaters may be connected to the telephone network or other networks only for purposes of remote control of a GMRS station, not for carrying communication signals. Quote
amaff Posted February 2, 2025 Posted February 2, 2025 That's actually a good question. Would being able to monitor it remotely count as remote control, and not communication? You aren't talking out through it that way. SteveShannon 1 Quote
SteveShannon Posted February 2, 2025 Posted February 2, 2025 7 minutes ago, amaff said: That's actually a good question. Would being able to monitor it remotely count as remote control, and not communication? You aren't talking out through it that way. It is a good question and you also make a good point. In the United States the limitations on monitoring signals are very limited. Almost all of the regulations are aimed at transmitting. amaff 1 Quote
amaff Posted February 2, 2025 Posted February 2, 2025 1 minute ago, SteveShannon said: It is a good question and you also make a good point. In the United States the limitations on monitoring signals are very limited. Almost all of the regulations are aimed at transmitting. Exactly how I was thinking of it. It's not too much different than listening in on a ham (or really any other analog, think Fire / EMS) frequency. SteveShannon 1 Quote
SvenMarbles Posted February 2, 2025 Author Posted February 2, 2025 3 minutes ago, SteveShannon said: It is a good question and you also make a good point. In the United States the limitations on monitoring signals are very limited. Almost all of the regulations are aimed at transmitting. Well just by virtue of the fact that ,yet again, the language is ambiguous it seems like it would allow for people to just go on ahead and do it just the same way that people just went on ahead and linked repeaters before.. SteveShannon 1 Quote
SteveShannon Posted February 2, 2025 Posted February 2, 2025 Just now, SvenMarbles said: Well just by virtue of the fact that ,yet again, the language is ambiguous it seems like it would allow for people to just go on ahead and do it just the same way that people just went on ahead and linked repeaters before.. Exactly. When the commission released their interpretation that made it clear they were against linking repeaters, they listed the harms done by linking repeaters: Quote In addition to violating Commission rules, linking repeaters is not in the public interest. Because GMRS spectrum is limited and used on a shared “commons” basis, the service only works well on a localized basis when users can hear each other and cooperate in the sharing of channels. Linking repeaters not only increases the potential for interference, but also uses up a limited spectrum resource over much larger areas than intended, limiting localized availability of the repeater channels. In my opinion (worth nothing), streaming the sound for the sole,purpose of listening does not have any of those negative consequences. But I can’t predict how the FCC might rule. I wouldn’t be afraid to try it though. We all know that a person would simply receive a letter first anyway. amaff 1 Quote
SvenMarbles Posted February 2, 2025 Author Posted February 2, 2025 12 minutes ago, SteveShannon said: Exactly. When the commission released their interpretation that made it clear they were against linking repeaters, they listed the harms done by linking repeaters: In my opinion (worth nothing), streaming the sound for the sole,purpose of listening does not have any of those negative consequences. But I can’t predict how the FCC might rule. I wouldn’t be afraid to try it though. We all know that a person would simply receive a letter first anyway. And it likely wouldn't even get to that point. The FCC is rarely compelled to enforce unless something is causing an actual problem, even in cases where rules are slightly bent. And I don't see how this would cause an actual problem for anyone.. amaff, WRHS218, Lscott and 1 other 2 2 Quote
gortex2 Posted February 3, 2025 Posted February 3, 2025 In the end your looking for a scanner feed. You are certainly able to set one up on your own. Takes a scanner, PC and internet. I have multiple scanner feed for SAR stuff but dont have any GMRS stuff on them. SteveShannon 1 Quote
SvenMarbles Posted February 6, 2025 Author Posted February 6, 2025 On 2/3/2025 at 5:24 AM, gortex2 said: In the end your looking for a scanner feed. You are certainly able to set one up on your own. Takes a scanner, PC and internet. I have multiple scanner feed for SAR stuff but dont have any GMRS stuff on them. No, having my own local outgoing scanner feed isn't going to do me any good. Are there such things as controllable scanner feeds? I've only ever heard one ones that are parked on set frequencies and just stream police, fire, or whatever.. I'd love to find a kiwisdr style thing for VHF/UHF, if such a thing exists I'd be very interested.. Quote
gortex2 Posted February 7, 2025 Posted February 7, 2025 No. All scanner feeds scan certain sources, frequencies. No one just scans unknown frequencies. Quote
SteveShannon Posted February 7, 2025 Posted February 7, 2025 12 hours ago, SvenMarbles said: No, having my own local outgoing scanner feed isn't going to do me any good. Are there such things as controllable scanner feeds? I've only ever heard one ones that are parked on set frequencies and just stream police, fire, or whatever.. I'd love to find a kiwisdr style thing for VHF/UHF, if such a thing exists I'd be very interested.. WebSDR might provide some of what you’re interested in if I understand you correctly. Unfortunately, in the United States I don’t see any VHF and UHF SDRs, but apparently they’re big in Russia . You might want to set up your own SDR using ka9q and an rtlSDR and a computer: http://www.sdrutah.org/info/using_ka9q_radio_with_the_rtlsdr.html Quote
SvenMarbles Posted February 7, 2025 Author Posted February 7, 2025 10 hours ago, SteveShannon said: WebSDR might provide some of what you’re interested in if I understand you correctly. Unfortunately, in the United States I don’t see any VHF and UHF SDRs, but apparently they’re big in Russia . You might want to set up your own SDR using ka9q and an rtlSDR and a computer: http://www.sdrutah.org/info/using_ka9q_radio_with_the_rtlsdr.html I'd do something like that if I had a bit better of a space circumstance. My radio desk situation is relegated to the downstairs laundry room lol. When the real estate/mortgage rate situation improves we'll definitely be getting a bigger house and maybe I can have a proper room office and have the ability of set up auxilary computers and stuff like that to host online SDRs. SteveShannon 1 Quote
SvenMarbles Posted February 7, 2025 Author Posted February 7, 2025 This is the entirety of what I can do radio stuff with… The good news is that it allows for short coax runs (I run them outside through the dryer vent cutout in the wall) and my mast pole setup is right there.. SteveShannon 1 Quote
DominoDog Posted February 9, 2025 Posted February 9, 2025 Very similar to my ham corner. Maybe one day I'll have a shack. or a room. or maybe a wall... a radio wall would be nice. Quote
