So I have currently been using an UV5G plus a UT72G stuck to a pizza pan on the end of an extension pole at about 12ft high. This has worked ok for simplex to a buddy about 3 miles away, as well as hitting a couple repeaters, though a little scratchy on the farther repeater(30miles +/-). Kind of a pain to set up, but it works. I currently set it up and down when I want to goof around.
I am wanting to start upgrading things a little with the ultimate goal being a base, probably 25 watt, lmr400, and a better antenna. Due to how my house is, shallow backyard with overhead power lines directly over the back fence, I was looking at doing an umbrella base with an extension pole so I can raise and lower when not in use. I live in the desert, so no trees, most houses 1 story, but high winds during the year.
So my question is primarily about antennas. I understand dbi vs dbd and gain, but what, if any, is the difference between a base (ie: Comet Ca-GMRS) vs a nmo mobile (MXTA26) with a ground radial adapter. I ask because it seems like the base/repeater style antennas are heavy and large , vs the mobile antennas are light and slim. I was concerned about 2-3 lbs antenna on a 16-20 ft extension pole vs a 1/2 lb mobile, thinking about wind load, or am I over thinking this. If all else is equal, is there a difference between a 6 dbi Base antenna vs a 6 dbi Mobile antenna?
Any help or insight is appreciated!
(sorry if this has been asked before. I tried searching, but didn’t find much)
WSGI548
46 answers to this question
