Wouxun KG-1000G-PLUS external speaker issues
My old Jeep is noisy. I added a Lido headrest speaker and used a 3.5mm "Y" adapter to connect the speaker to both out puts as directed in the manual. I only get output on the external speaker to area b, no matter how I have the speakers set on the radio (radio, mic, both)
What is going on with this radio?
1 hour ago, WRUU653 said:
The Y adapter is the most logical issue. However and this may sound silly, have you turned both volumes up?
Also I saw this note in the manual “The radio must be powered off/on after external speakers are connected before they will become active.”
Yes, tried all of that
Electrically this should be simple.  Are you certain both output ports work?
If a single mono speaker works fine plugged into either of the outputs individually then you know the ports both work and are active.  Better yet, plug two separate mono speakers with mono plugs.  Do they both work simultaneously?
One last thing to try is to use a mixer to combine the two separate audio feeds.  Most mixers are meant for line level outputs rather than speaker level, but if you can find something that matches the impedance and will accept speaker level output it should work. Or you can use speaker level to line level converters and then run the outputs into the mixer, and then take the mixed output and amplify it to feed a single speaker, but that seems like a lot of work.
I ran into the same problem about a year ago when I tried several Y adaptors with my KG-1000G. All of the adaptors were stereo to stereo. They work fine when connecting a single mono speaker to a single port but not when trying to use both ports at the same time.
As I stated before, part of the problem is the impedance mismatch. And @SteveShannon a mixer would definitely help along with the correct mono to stereo y adaptor.
The only thing I have not tried yet was using an actual stereo speaker with both left and right speakers in one unit.
Some radios, like the Icom IC-2730, will push audio out for side A and side B from one single port. But the KG-1000G definitely won't.
I think it really should be 2 channel mono to single channel mono combiner.  Yes, it’s taking two outputs, which we typically considered stereo, and combining them into a single speaker, but specifying a mono to stereo Y adapter may result in one of the connectors being a stereo connector.
@OldJunk2 really needs an adapter that has two mono plugs (tip and sleeve only, no ring connector) with the tips connected to each other and the sleeves connected to each other leading to the appropriate mono connector (depending on what the speaker he’s trying to use has; if it indeed has a stereo plug then you’re right, but if it has a mono plug then he needs a mono jack with only a tip and sleeve connector.)
Most of the adapters out there are two TS (which is mono with a tip and sleeve) to a single TRS (which is stereo with a tip, ring, and sleeve).  Someone who is hoping to combine two separate mono speaker outputs to a single mono speaker doesn’t want that.  Instead they want two TS to a single TS, mono on all three connectors.
Here is the one I found on Amazon:
https://a.co/d/2wMGnEy
This is what I found as far as a dual male mono to female stereo y adaptor. I don't know 100% if that would even work.
&D 3.5mm Stereo Female to Dual 3.5mm Mono Male Audio Cable, 3ft 3.5mm 1/8" TRS Female to 2 x 3.5mm 1/8" TS Male Y Breakout Cable Splitter
I might be the guinea pig for $6. If I get that adaptor then I can try it with my mono Icom SP35 and along with a stereo speaker that I use with my Xiegu G90. The G90 only has a headphone jack which is stereo and a mono speaker doesn't work well. Again muffled sound.
@brasda91 Thanks for sharing that link.  Yes that is always an option. But I don't want to have speakers right next to my head like that for several reasons.  One  is the fact that I wear hearing aids. Another is safety, I try to keep things that can be projectiles in an accident down to a minimum
I cringe every time I see people bejewel their steering wheels and dashes right overtop the airbags. Thats nothing but a claymore waiting to go off.
I wear hearing aids too. It's not an issue. This actually keeps me from having to turn the radio up excessively.
I don't know why people keep commenting on "projectiles". There is no reason to think this would be a projectile. Projectiles are loose items laying in the passenger compartment. This mount is secure to the headrest. I've been a vol firefighter/EMT for years. I've seen my fair share of vehicle accidents and never once did I think this would be unsafe.
To each their own.
I do not trust anything attached to the headrest to stay put in an accident. And I too have seen my fair share of accidents and weird things do happen in an accident. I personally won't take the chance if I don't have to.
Plus I don't want any type of speakers right next to my head while driving. I want to be able to hear everything that's going on.
So to re-cap this, would someone be able to give a proper example of what we'd need, say as a link on Amazon?
To give an idea of my setup, I have:
  • KG-1000G base mounted underneath the passenger seat
  • Midland 21-406 mounted above the seat belt inside the cab so I can actually hear the radio
  • Federal Signal ES100C external siren connected to a Whelen HHS3200
The Midland is meant to be used to hear the radio since the base is under the seat and muffled. It seems sometimes it works and others it doesn't.
I originally had a Y connector purchased from Amazon and it would only ever output audio from one of the outputs. I suspect it was either stereo or somehow the wrong kind. I figured it was just bad quality and broken, and later bought two separate plugs, and spliced them together with a third to connect to the Federal Signal so I can hear it outside if I'm out of the vehicle. But still had issues with only hearing one output and it mysteriously not working at certain times (along with low/muffled audio).
I figured I must be dumb or something's wrong with the radio, but after reading this thread, I am leaning on the culprit of me just being dumb. Could someone give an example of what would be a proper connector to get all these things working as intended? (I'm looking to hear both A/B channels through a single external speaker (and since there are actually two speakers, just have them mirrored--- aka broadcast the same sound).
I do expect there would be distortion issues if both channels receive at the same time but I assume there isn't really anything that can be done with that.
Okay I have an update for everyone.
A dual mono to single stereo y adaptor will work BUT only if you are using a true stereo external speaker with two speakers.
Here is the y adaptor I used: J&D 3.5mm Stereo Female to Dual 3.5mm Mono Male Audio Cable, 3ft 1/8" TRS Female to 2 x 1/8" TS Male Y Breakout Cable Splitter Adapter
Speakers I tried:
  • Icom SP35 - mono plug, single speaker
  • Xiegu GY03 - stereo male plug, single speaker
  • Anker portable wireless speaker - connected with stereo cable, dual speakers
I could only get sound out on the radios left -Side A with the Icom and Xiegu speakers. There was no sound output on side B.
The true stereo Anker speaker worked just fine and I had equal volume from side A and B
The volume was not cut back/ sound muffled with the J&D adaptor like there was when using a mono to mono y adaptor. But you definitely need to use a true stern speaker with two speakers for it to work.
Stereo to mono plugs DO NOT combine two channels but keep them separate. Combining the two channels through wiring only affects the impedance seen by the amplifier and speaker. To work correctly, the two channels have to be fed into a mixer which combines the audio signals and keeps the impedance of the circuit constant. What the stereo to mono plugs go is combine the ground return path while putting one audio signal on the tip and the other to the ring.
Well I was trying to keep things as simple as possible so that everyone would understand and also so they would know what does and does not work. I kept it simple so everyone would understand.
Some got confused when I tried explaining impedance matching in the past.
And yes yo are correct that stereo to mono plugs do not combine two channels and that is why a single mono speaker will not work. The stereo speak will work since it has a left and right speaker. Which is what I though and mentioned in previous posts.
The down and dirty simple answer here is to either use two separate mono speakers or use a dual mono to stereo adaptor to a stereo speaker with separate left and right speakers.
And the only stereo speakers I can find on Amazon all have rechargeable batteries or need a separate USB power supply.
