All properly configured ones do.
(c) 467 MHz main channels. Only mobile, hand-held portable, control and fixed stations may transmit on these 8 channels. Mobile, hand-held portable and control stations may transmit on these channels only when communicating through a repeater station or making brief test transmissions in accordance with § 95.319(c). The channel center frequencies are: 467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000, and 467.7250 MHz.
Since these frequencies are explicitly reserved in the paragraph above for use transmission when communicating through a repeater, that designates these frequencies as the repeater inputs. And they are 5MHz above the 462.xxxx mains. The specification doesn't say that 467.5750 as an input must map to 462.5750 as an output, but any other mapping, such as 467.5750 input / 467.6000 output would be bizarre, incompatible with a lot of radios, and rather pointless.
Reply to this topic...
