I received my Wouxun KG-XS20G+ last week and I'm really enjoying it! Since I am a newbie to two-way radios my learning what each feature of my new radio does individually and in combination is really helping. Along the way I have encountered some interesting things about my new radio, of which this is the first of several I encountered.
Cycling DC power from the KG-XS20G+ while the Wouxun programming cable is connected to both the KG-XS20G+ and the powered-on PC may result in the KG-XS20G+’s initial power-on and main screens appearing with distorted colors and icons. Refer to attached pictures, wouxun1.jpg and wouxun2.jpg. I could not determine if the KG-XS20G+’s other functionality is affected. The problem can be cleared and also avoided by removing the Wouxun Programming cable prior to cycling DC power.
Test Methodology:
Perform the following actions in the listed order to re-produce the problem.
1) Power-up the PC with the Wouxon KG-XS20G+ programming software installed along with the USB driver, if needed.
2) Plug the programming cable into the PC and KG-XS20G+ (see manual for instructions).
3) Verify the KG-XS20G+ configuration can be read by the Wouxon KG-XS20G+ programming software.
4) Using KG-XS20G+’s RED power button turn off the radio.
5) Disconnect DC power to the XG-XS20G+, count to 5, and reconnect DC power.
6) Using KG-XS20G+’s RED power button turn on the radio.
NOTE: Steps 4 and 6 can be skipped allowing the KG-XS20G+ to power up automatically when DC power is restored.
WRNU354
Test Methodology:
Software and equipment used:
KG-XS20G Plus Commander version 1.10 (20221005)
Model: KG-XS20G Plus, GMRS
FCC ID: WVTWOUXUN25
S/N: MRGX121385
Manufacture Date Code 2024-12
Wouxun Mobile Radio USB Programming Cable (PCO-003)
BTECH RPS-30M Switching Power Supply
Output: 13.8VDC 30A
15 answers to this question
