dsm600rr Posted February 25 Report Posted February 25 Hello all, Looking to maybe upgrade the Antenna on my Wouxun KG-935G Plus. From researching, it seems the stock antenna performs quite well, so curious if anything would help get a bit more performance? I was looking at: - Nagoya NA-771G - Smiley 5/8 Slim Duck 465 - Smiley SUPER STICK IV 465 MHZ Very new - so open to other suggestions. Lastly, looking for an Antenna Setup to run with a Wouxun KG-1000G Plus (I haven't ordered this yet). I am open to drill or magnetic. These would go in a few Transit Connect Fleet Vans - looking for the best mounting solutions/suggestions that will work best together. Thanks! Quote
Socalgmrs Posted February 25 Report Posted February 25 I use 771s but the slime ducks work a little better but costs more then most of my radios so I won’t use them. I know you didn’t ask but I would t waste time and money on any woxoun let alone the junky kg-1000. They have many issues and are not as good as radios 1/3 the price. As for antenna mx26 is good. The comet 2x4 works even better. Through mini mount is the only real way to go but an nmo mag will work fine also. Quote
WRYZ926 Posted February 25 Report Posted February 25 I have tried the Nagoya 771G and the Abree version on my KG-935G. The stock antenna works better. And don't let the negativity bother you. There is nothing wrong with Wouxun radios. There are plenty of us that own Wouxun radios and don't have any issues with them. Quote
RIPPER238 Posted February 25 Report Posted February 25 I have a Q10H and 935G, for the 935 i got the Super-Elastic Signal Stick from signalstuff in 440 mono for GMRS. Super compact light weight thin and has no memory so super durable. I also got the longer 2m 70cm antenna which happens to be good at GMRS as well as AM which was surprising. I have a Nagoya NA-771G as well, not much better than stock. For my truck i got a Comet CA-2X4SR. Was thinking of the KG-1000H when my old GMRS Midland goes. Quote
RIPPER238 Posted February 25 Report Posted February 25 1 hour ago, Socalgmrs said: I use 771s but the slime ducks work a little better but costs more then most of my radios so I won’t use them. I know you didn’t ask but I would t waste time and money on any woxoun let alone the junky kg-1000. They have many issues and are not as good as radios 1/3 the price. As for antenna mx26 is good. The comet 2x4 works even better. Through mini mount is the only real way to go but an nmo mag will work fine also. What radio would you suggest that's better quality and has similar features? AdmiralCochrane and SteveShannon 2 Quote
