You can always look at the map display. The only reason you need to sign in is to request permissions or to see public tones.  If you hit the carrot at the top right it will say map   It will have its own sign in once you’re on the map page.  Same credentials just different page
10 hours ago, Socalgmrs said:
You can always look at the map display. He o my reason you need to sign in is to request permissions or to see public tones.  If you hit the carrot at the top right it will say map   It will have its own sign in once you’re on the map page.  Same credentials just different page
Can I presume that is "There is no reason"?  And YES, I understand the reason for signing in, ....
17 hours ago, gortex2 said:
You should be able to go to mygmrs.com and register to login. Forum and main site are different logins so you need credentials in both.
IIRC, they used to be separate, but Rich got them standardized a year or so back, and they SHOULD now be the same login. However, the login doesn't carry over between the main site (where the map and repeater list live) and the forum.
