WSHE504 Posted March 5 Report Posted March 5 I’m new to the GMRS world. I’ve been running CB since i was old enough to drive but recently picked up a Midland M275 15-watt. I’ve scanned the channels without the repeater option on and off and hear lots of chatter but can’t get a single radio check. I’ve enabled the repeater option and move to RP 20 still with no luck. The details around who can use which repeaters is vague. I’ve used this radio to communicate with our handheld GMRS radios on channel 20 with no issues. Anybody have a “welcome to GMRS, n00bie” manual to figure out what I’m doing wrong? 2024 Chevrolet Silverado MicroMobile® GMRS 15-Watt Two-Way Radio - MXT275 MicroMobile® Antenna NMO Mag Mount - MXTA12 MicroMobile® Ghost 3dB Gain NMO Antenna - MXTA25 Quote
OffRoaderX Posted March 5 Report Posted March 5 You need the specific tone required for the specific repeater you are trying to use, and you have to enter that in the correct channel (presumably CH20). Without that you will not be able to use the repeater - you can hear them, they will not hear you. WRUU653, WSHE504 and WRHS218 3 Quote
WSHE504 Posted March 5 Author Report Posted March 5 @OffRoaderX, that’s part of my confusion. If I set it to non repeater 20, I still pickup the repeater 20 chatter? Quote
OffRoaderX Posted March 5 Report Posted March 5 Just now, WSHE504 said: @OffRoaderX, that’s part of my confusion. If I set it to non repeater 20, I still pickup the repeater 20 chatter? Yes.. that's how it works.. I found this random video on youtube that explains it very well. The guy is kind of a jerk, and I heard he only says what his sponsors tell him to say, but the info you want is in there: WRUU653, WSHE504, WRHS218 and 4 others 1 6 Quote
WSHE504 Posted March 5 Author Report Posted March 5 I see a few channel 20 repeaters in Dallas TX but one is restricted and the other is REACT. Quote
gortex2 Posted March 5 Report Posted March 5 Did you set the proper tone when you changed to RP20 ? Also are you sure they want to talk to you ? Contrary to popular belief alot of folks use GMRS for talking to friends. Not others. WSHE504 1 Quote
WSEN940 Posted March 5 Report Posted March 5 I don’t know what radio you are using, but I did a picture for a UV5G plus a while back that shows the programming sequence for that HT. if your using a different radio, it shows the relationship between the tx and rx frequencies and the tones. It ‘may’ be helpful…link below Programming WSHE504 1 Quote
WRYZ926 Posted March 5 Report Posted March 5 11 hours ago, OffRoaderX said: Yes.. that's how it works.. I found this random video on youtube that explains it very well. The guy is kind of a jerk, and I heard he only says what his sponsors tell him to say, but the info you want is in there: I agree that guy is a bit cranky at times. But he does give good information in his videos (most of the time) GMRS repeaters transmit on 462.XXX while receiving on 467.XXX. GMRS repeater transmit channels are the same as the corresponding simplex channels. So yes you can hear repeaters when on a simplex channel. You will also hear the corresponding simplex channel while your radio is on a repeater channel if you are not using a receive tone. This just how things work with GMRS since there are only so many channels available. We had one guy complaining about hearing a bunch of kids on the repeater when no one else was hearing the kids. The kids were on simplex and the guy did not have the receive PL Tone set on his radio. SteveShannon, WSFL951, WRHS218 and 1 other 3 1 Quote
nokones Posted March 5 Report Posted March 5 The repeater on RP20 is part of the Texas GMRS Club and requires a specific CTCSS Tone or DCS Code and a Club membership to access the repeater. The Texas GMRS Club has repeaters throughout Texas and it would be worth while for only about $24/year to be a member and get access to a lot of repeaters statewide. The vehicle and radio equipment you're using is great for starting out. Just bare in mind that the MXT275 is a 15 watt radio and is limited in the number of custom programming channels. The MXT575 is essentially the same radio with the same channel limitation, but with 50 watts of output power. The MXT500 has 99 channels and also is a 50 watt radio. You might want to try the Midland MXTA 26 antenna that may give you a few more farz in some cases. The Midland Antennae are great GMRS antennae and will give you good VSWRs on GMRS freqs. That guy in the video drives a Nissan Grocery Getter with chrome wheels and moon hub caps and cruises Pico Rivera looking to chat with strangers on the radio, but his stuff in the videos is very informative and helpful. WSHE504, SteveShannon, OffRoaderX and 1 other 2 2 Quote
nokones Posted March 5 Report Posted March 5 Oh, I forgot to mention, although he doesn't drive around with Whitewall tires, but he does use a Tire Dressing on his tires to impress the chick's on the Whittier Boulevard. Quote
WSHI722 Posted March 6 Report Posted March 6 How are you 504! I'm Tony in Fort Worth and I just got my radio and I can totally understand your frustration lol no seriously' I'm new at this all the way. Bought my radio for my security work and i wanted to chit chat on the off time. To hopefully shed some light. The basic thing you need to know is; Frequency Tone In/Out(PL Tone) Offset(+/-...etc) CTCSS(Transmit) and RXCTCSS(Receive) I thought the exact same, you just fire it up and start introducing lol. After hours on hours I ran into an old reddit post that helped me understand this isn't your jack in the box cracker jack radio, it actual requires you to put in some work first lol. Try adding this into your radio, I will be home tomorrow(March 6th) around 12:00PM; 443.85000 - No offset - FM Narrow - T Sql - CTCSS (110.9 on both) Hit me up if you need me to step you through it I'll give you my number or so but otherwise set it up call me out, I'll have the freq on around that time tomorrow. Can you message me on here? WSHE504 1 Quote
nokones Posted March 6 Report Posted March 6 504 will have very poor VSWRs trying to transmit on an Amateur Radio Service freq with a Midland GMRS specific antenna. Midland Antennae are designed with very narrow bandwidth. Also, I thought that Amateur freqs operate with CSQ on the receiver and simplex channels. Quote
WSEZ864 Posted March 6 Report Posted March 6 1 hour ago, nokones said: 504 will have very poor VSWRs trying to transmit on an Amateur Radio Service freq with a Midland GMRS specific antenna. Midland Antennae are designed with very narrow bandwidth. Also, I thought that Amateur freqs operate with CSQ on the receiver and simplex channels. "CSQ" (carrier squelch) is an optional setting on the receiving radio and works exactly the same way it would on GMRS frequencies, as do other squelch settings. On simplex, carrier squelch is most often used, with CTCSS being used most often when working repeaters. WSHE504 1 Quote
WSHE504 Posted March 6 Author Report Posted March 6 Thank you @WSEH456. First successful contact made on the REACT repeater. @nokones,no issues with Midland equipment and quality of transmission today. I was near midway / 635. But I’m sure I’ll fall down this rabbit hole and get some better equipment as I keep exploring. I appreciate your insight, everybody. Looking forward to getting deeper into this field. SteveShannon 1 Quote
WSHE504 Posted March 6 Author Report Posted March 6 Are you close enough? Do you have line of sight? Tones of coarse as well Yep, the tones and confusion of who can use what repeaters are where I was stumped. Lots of research to do!Sent from my iPhone using Tapatalk Quote
WSHE504 Posted March 6 Author Report Posted March 6 Did you set the proper tone when you changed to RP20 ? Also are you sure they want to talk to you ? Contrary to popular belief alot of folks use GMRS for talking to friends. Not others. Yeah, it was the tones. Friendly bunch on Channel 20, always introducing each other and saying hi to the new guys. But I don’t know which repeater they were on. I’m on the REACT 20 repeater now.Sent from my iPhone using Tapatalk Quote
WSHE504 Posted March 6 Author Report Posted March 6 I don’t know what radio you are using, but I did a picture for a UV5G plus a while back that shows the programming sequence for that HT. if your using a different radio, it shows the relationship between the tx and rx frequencies and the tones. It ‘may’ be helpful…link below ProgrammingOh I’ll be falling down that rabbit hole soon. I already see the limit of a basic GMRS radio having to be configured each time you want to communicate on a specific repeater especially if they’re all 20 but different tones. This will do for now, but I’ll be looking up new radios very soon.Sent from my iPhone using Tapatalk WSEN940 1 Quote
