LeoG Posted April 10 Report Posted April 10 https://absolute-emc.com/calculator/convert/dBm WRXB215, WRYZ926 and WRNU354 3 Quote
WRYZ926 Posted April 10 Report Posted April 10 It would be nice if antenna manufacturers and retailers would list the antenna gain in dBd instead of dBi. The dBd value is more realistic and also what most coax loss calculators use. The conversion from dBi to dBd is pretty simple to remember, subtract 2.14 from the dBi value to get dBd. Quote
LeoG Posted April 10 Author Report Posted April 10 I was playing around with radio mobile online and notice that their calculations are off because they are using dBi numbers in dB and dBm equations. That's what prompted me to look for a calculator for µV to dBm. t They have it as (46.23-1.3+9.8+9.8-1.6)-132.0=-69.07dBm I believe it should be (46.23-1.3+7.65+7.65-1.6)-132.0=-73.37dBm Quote
LeoG Posted April 10 Author Report Posted April 10 1 hour ago, WRYZ926 said: It would be nice if antenna manufacturers and retailers would list the antenna gain in dBd instead of dBi. The dBd value is more realistic and also what most coax loss calculators use. The conversion from dBi to dBd is pretty simple to remember, subtract 2.14 from the dBi value to get dBd. dBi numbers are bigger therefore you can sell more antennas. Quote
WRYZ926 Posted April 10 Report Posted April 10 10 minutes ago, LeoG said: dBi numbers are bigger therefore you can sell more antennas. Yes I know and that is why they advertise gain in dBi. But it would still be nice if they would list the gain in dBd. Quote
Groundwire Posted April 12 Report Posted April 12 On 4/10/2025 at 2:47 PM, WRYZ926 said: It would be nice if antenna manufacturers and retailers would list the antenna gain in dBd instead of dBi. The dBd value is more realistic and also what most coax loss calculators use. The conversion from dBi to dBd is pretty simple to remember, subtract 2.14 from the dBi value to get dBd. Its 2.15 not 2.14 Quote
WRYZ926 Posted April 12 Report Posted April 12 Just now, Groundwire said: Its 2.15 not 2.14 I'm definitely not going to argue over 0.01. Plus 2.14 is what comes up most often when searching for the conversion for dBi to dBd. Quote
Groundwire Posted April 12 Report Posted April 12 On 4/10/2025 at 4:24 PM, WRYZ926 said: Yes I know and that is why they advertise gain in dBi. But it would still be nice if they would list the gain in dBd. It doesn't matter, just do the math, dbi is a real gain figure. if you know anything about antenna theory you will find that they lie about dbd gain figures all the time as well. 3dbd gain from a 1/4 vertical? Haha, please. The real antenna companies dont lie to sell, usually. Quote
Groundwire Posted April 12 Report Posted April 12 3 minutes ago, WRYZ926 said: I'm definitely not going to argue over 0.01. Plus 2.14 is what comes up most often when searching for the conversion for dBi to dBd. Nobody's arguing. One is right one is wrong. You made a mistake, no big deal Quote
WRYZ926 Posted April 12 Report Posted April 12 4 minutes ago, Groundwire said: Nobody's arguing. One is right one is wrong. You made a mistake, no big deal Well it seems that we are both correct and also both are wrong. I just did a web search and half of the links say 2.14 while the other half say 2.15. Either way 0.01 is not going to make a difference. And yes most manufacturers are optimistic when it comes to claims on antenna gain. This is especially true with hand held and mobile antennas. SteveShannon 1 Quote
LeoG Posted April 12 Author Report Posted April 12 14 hours ago, WRYZ926 said: Well it seems that we are both correct and also both are wrong. I just did a web search and half of the links say 2.14 while the other half say 2.15. Either way 0.01 is not going to make a difference. And yes most manufacturers are optimistic when it comes to claims on antenna gain. This is especially true with hand held and mobile antennas. So we can call it 2.145 to make it more complicated. WSHT333Oldude and WRYZ926 2 Quote
WRYZ926 Posted April 12 Report Posted April 12 7 minutes ago, LeoG said: So we can call it 2.145 to make it more complicated. Sounds good for me. In reality 0.01 is not going to make any difference in the calculations. That's like arguing over the differences between 20 watts output and 25 watts output. SteveShannon 1 Quote
LeoG Posted April 12 Author Report Posted April 12 So no one has any opinion on the calculation from Online Radio Mobile? Quote Quote They have it as (46.23-1.3+9.8+9.8-1.6)-132.0=-69.07dBm I believe it should be (46.23-1.3+7.65+7.65-1.6)-132.0=-73.37dBm Quote
SteveShannon Posted April 12 Report Posted April 12 6 minutes ago, LeoG said: So no one has any opinion on the calculation from Online Radio Mobile? Their calculation is correct. Total gain calculations should be relative to an isotopic antenna. Quote
LeoG Posted April 12 Author Report Posted April 12 So if the parameters were in dBd with their respected reduction in strength (dBi-2.15db) then the resultant output would still be correct only because the calculations were consistent and done with all dBd gains instead of dBi? The answer they give is in dBm, what would it be if you used dBd gain measurements? Quote
SteveShannon Posted April 12 Report Posted April 12 42 minutes ago, LeoG said: So if the parameters were in dBd with their respected reduction in strength (dBi-2.15db) then the resultant output would still be correct only because the calculations were consistent and done with all dBd gains instead of dBi? The answer they give is in dBm, what would it be if you used dBd gain measurements? In that case your calculations would be 4.30 db too low. An isotropic antenna is theoretical, a single infinitely small source with a gain of 0, meaning multiply the input times 1 to get the output when working with linear values. Having a dBd gain value for an antenna is convenient but for a calculator like this you always want to take the antenna gain back to dBi so you’re not inadvertently throwing the output value off. Maybe a better way to explain it is that the dBd value is only useful for comparing an antenna to a dipole. For purposes of calculating total gain you always need to start at 0 which is the dBi number. AdmiralCochrane and WRYZ926 2 Quote
