Radioguy7268 Posted Friday at 03:00 AM Report Posted Friday at 03:00 AM A Fixed Station is one that's been repaired. /s TDM827, amaff, WRUU653 and 3 others 6 Quote
amaff Posted Friday at 04:07 PM Report Posted Friday at 04:07 PM 13 hours ago, Radioguy7268 said: A Fixed Station is one that's been repaired. /s I thought it was one that's been neutered BoxCar and marcspaz 2 Quote
WRKC935 Posted Sunday at 12:47 AM Report Posted Sunday at 12:47 AM Wow, we doing THIS AGAIN?!?!?!! Fixed stations are communicating with other fixed stations. Linking aside. If you have a repeater at a remote location, and a base station at your house, when you are talking on the REPEATER, that's fixed station operation. If you go to a simplex channel and talk to a mobile or portable radio, then you are operating fixed BASE. So ONE radio can operate in BOTH manners depending on how you are communicating. The other situation is simplex between two base stations. Both are 'fixed' or not mobile / portable. Reason for this is to NOT create unneeded interference on the frequency by operating at a power level above the minimum required to maintain reliable communications. Repeaters and other base stations have added range due to their elevated antenna systems over a mobile or portable and of course have antenna's with more gain as well. This isn't anything new... commercial has had this same regulation for years. The difference is in part 90 commercial they refer to the radio as a CONTROL STATION. It's still a 'base radio'. This is also how you get the maximum antenna height regulations for fixed base operations. Quote
BoxCar Posted Sunday at 02:15 PM Report Posted Sunday at 02:15 PM 11 hours ago, WRKC935 said: Wow, we doing THIS AGAIN?!?!?!! Fixed stations are communicating with other fixed stations. Linking aside. If you have a repeater at a remote location, and a base station at your house, when you are talking on the REPEATER, that's fixed station operation. If you go to a simplex channel and talk to a mobile or portable radio, then you are operating fixed BASE. So ONE radio can operate in BOTH manners depending on how you are communicating. The other situation is simplex between two base stations. Both are 'fixed' or not mobile / portable. Not quite, fixed stations are primarily used to pass DATA between two fixed locations i.e. flood monitoring stations and monitoring posts. "Base" stations are control sites which activate repeaters or fixed stations to report. Base stations are at either permanent or temporary locations and are used to pass both data and voice to other base stations or mobile stations either through repeaters or directly. This implies there are three classes of stations, fixed stations reporting to another, single, fixed station, control stations, which may serve as both control and base stations and mobile stations which have no permanent location. AdmiralCochrane and WRUU653 2 Quote
WRXL702 Posted Sunday at 06:18 PM Report Posted Sunday at 06:18 PM 4 hours ago, BoxCar said: Not quite, fixed stations are primarily used to pass DATA between two fixed locations i.e. flood monitoring stations and monitoring posts. "Base" stations are control sites which activate repeaters or fixed stations to report. Base stations are at either permanent or temporary locations and are used to pass both data and voice to other base stations or mobile stations either through repeaters or directly. This implies there are three classes of stations, fixed stations reporting to another, single, fixed station, control stations, which may serve as both control and base stations and mobile stations which have no permanent location. FCC Part 95 Subpart A - 95.303 Definitions: Base station. A station at a fixed location that communicates directly with mobile stations and other base stations. Fixed station. A station at a fixed location that directly communicates with other fixed stations only. The Term "DATA" Is Not Referenced In These Definitions For The Type Of Transmission. https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-A SteveShannon 1 Quote
BoxCar Posted Sunday at 06:54 PM Report Posted Sunday at 06:54 PM 4 hours ago, BoxCar said: Not quite, fixed stations are primarily used to pass DATA between two fixed locations i.e. flood monitoring stations and monitoring posts. "Base" stations are control sites which activate repeaters or fixed stations to report. Base stations are at either permanent or temporary locations and are used to pass both data and voice to other base stations or mobile stations either through repeaters or directly. This implies there are three classes of stations, fixed stations reporting to another, single, fixed station, control stations, which may serve as both control and base stations and mobile stations which have no permanent location. 33 minutes ago, WRXL702 said: FCC Part 95 Subpart A - 95.303 Definitions: Base station. A station at a fixed location that communicates directly with mobile stations and other base stations. Fixed station. A station at a fixed location that directly communicates with other fixed stations only. The Term "DATA" Is Not Referenced In These Definitions For The Type Of Transmission. https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-A Notice, I stated the primary purpose is to pass data. I did not state a fixed station was data only nor reference nor imply that was their only use. Quote
WRUU653 Posted Sunday at 09:25 PM Report Posted Sunday at 09:25 PM 19 hours ago, WRKC935 said: when you are talking on the REPEATER, that's fixed station operation Fixed station. A station at a fixed location that directly communicates with other fixed stations only. This statement would seem to indicate that a repeater is not a fixed station as it does not communicate with only fixed stations. Therefore talking to it is not the action of a fixed station. I will agree that this topic has been discussed for what seems an eternity. With some grasping the rules and others arguing the perceived vagueness. I would agree that for a radio service intended for friends and family the FCC could or should have written the rules for such. That said, all the debate is for what end I have no idea. Who is being affected negatively here? As Bill Murray stated in Meatballs it just doesn’t matter. SteveShannon 1 Quote
WRXL702 Posted Sunday at 09:25 PM Report Posted Sunday at 09:25 PM 2 hours ago, BoxCar said: Notice, I stated the primary purpose is to pass data. I did not state a fixed station was data only nor reference nor imply that was their only use. So - Stating "The Primary Purpose Is To Pass Data" Is an Opinion For The Use Of Fixed Stations, Not Reflected In Definitions In Part 95.303. WRKC935, In My Opinion Has The Correct - Explanation / Examples Of Base Stations vs Fixed Stations...... Quote
BoxCar Posted Sunday at 09:29 PM Report Posted Sunday at 09:29 PM 1 minute ago, WRXL702 said: So - Stating "The Primary Purpose Is To Pass Data" Is an Opinion For The Use Of Fixed Stations, Not Reflected In Definitions In Part 95.303. WRKC935, In My Opinion Has The Correct - Explanation / Examples Of Base Stations vs Fixed Stations...... Actually, it is based on observation of processing many thousands of requests to the Commission for processing. l Quote
WRUU653 Posted Sunday at 09:33 PM Report Posted Sunday at 09:33 PM 7 minutes ago, WRXL702 said: So - Stating "The Primary Purpose Is To Pass Data" Is an Opinion For The Use Of Fixed Stations, No, it’s an example. SteveShannon 1 Quote
WRXL702 Posted Sunday at 09:39 PM Report Posted Sunday at 09:39 PM 4 minutes ago, WRUU653 said: No, it’s an example. Then Folks Should Refrain On Commenting "Not Quite" If They Are Siting An "Example / Opinion" Of Documented FCC Definitions..... WRUU653 1 Quote
GrouserPad Posted 7 hours ago Author Report Posted 7 hours ago On 4/26/2025 at 8:47 PM, WRKC935 said: Wow, we doing THIS AGAIN?!?!?!! Fixed stations are communicating with other fixed stations. Linking aside. If you have a repeater at a remote location, and a base station at your house, when you are talking on the REPEATER, that's fixed station operation. If you go to a simplex channel and talk to a mobile or portable radio, then you are operating fixed BASE. So ONE radio can operate in BOTH manners depending on how you are communicating. The other situation is simplex between two base stations. Both are 'fixed' or not mobile / portable. Reason for this is to NOT create unneeded interference on the frequency by operating at a power level above the minimum required to maintain reliable communications. Repeaters and other base stations have added range due to their elevated antenna systems over a mobile or portable and of course have antenna's with more gain as well. This isn't anything new... commercial has had this same regulation for years. The difference is in part 90 commercial they refer to the radio as a CONTROL STATION. It's still a 'base radio'. This is also how you get the maximum antenna height regulations for fixed base operations. Thanks a lot for your reply. It is helpful…... my bad for posing a question that must have been beat to death here. Quote
WSHH887 Posted 6 hours ago Report Posted 6 hours ago Relax. Every "hobby" has subjects that come up from time to time and elicit opinions guaranteed to create chaos. Heck, after over a century of coexistence, asking which is better .45acp or 9mm will result in weeks of debate on firearms forums. SteveShannon and WRUU653 2 Quote
Davichko5650 Posted 3 hours ago Report Posted 3 hours ago 3 hours ago, WSHH887 said: Heck, after over a century of coexistence, asking which is better .45acp or 9mm will result in weeks of debate on firearms forums. Just steer 'em to the 30 Super Carry group... Quote
WRXL702 Posted 2 hours ago Report Posted 2 hours ago 1 hour ago, Davichko5650 said: Just steer 'em to the 30 Super Carry group... LOL - Too Funny........ "30 Super Carry" Was As Successful As The "Sig357" Round - Both Didn't Do Well........ Everyone Has Their Opinion, & As Long As The Gun Goes "Bang" For Your Specific Purpose - All Good For The Intended Purpose....... Quote
