Nope. Never heard of a dummy antenna. Dummy load? Yes. Dummy antenna? Nope. Another question that could have been answered by a quick internet search.
WRUU653 reacted to a post in a topic: retevis RA87
WRUU653 reacted to a post in a topic: Linking GMRS Repeaters
EMR Corp, Celwave, and any quality brand from a Radio Electronics Retailer that measures out at 50 ohms with the appropriate power rating for the radio you are testing.
I'm sure you folks are getting great coverage where you are, but there are a lot a variables that make it so that works in those situations. It becomes problematic for a vast majority of the US. On the ocean or in perfectly flat land areas, if you have an antenna that is on a 100' mast, you are only covering 14 mile radius. Even if you bump to a 300' mast (which cost over $1m for a good commercial grade 300' tower) you are only looking at a radius of about 25 miles. To cover 100 miles (200 total miles end to end) your antenna needs to be almost 1 mile above the average terrain. That simply isn't possible in a vast majority of the US. If you are able to put an antenna on a mountain that overlooks a valley, you are golden, though. We have one of our antennas 1,000 feet above average terrain and we are barely pushing it a 45 miles, with dead spots inside that coverage area due to terrain. That particular repeater is known throughout the mid-Atlantic for being one of the top 3 repeaters, even when we include amateur radio coverage, and the top coverage repeater for GMRS in the area. Due to the terrain limits here, people/companies running farms need networked radios for reliable coverage and most of them are using commercial radio for it.
Any 50 ohm load rated for 50W or more.
Any 50 ohm dummy load that is rated for the maximum power output of your radio is just fine. Understand that there are continuous power ratings and ratings that are derated based on time and output power.
tcp2525 reacted to a post in a topic: OK, I have this problem...
SteveShannon reacted to a post in a topic: OK, I have this problem...
I have no idea the impact of the Heliax. It was only 25', less than 1/3rd the run. But the price difference wasn't that great so I said just do it. Was more worried about the problem of different metals in the coax blah blah blah. Plus this is an N connector antenna and the other was a 239 which isn't waterproof. The main reason is I already had to do it twice, and I do not plan on doing it a 3rd time.
WSHE531 started following Dummy Antenna
So is there any particular dummy antenna that is good for measuring output on your radio?
marcspaz reacted to a post in a topic: Linking GMRS Repeaters
SteveShannon reacted to a post in a topic: Linking GMRS Repeaters
There are still a few pretty active linked repeaters around me. Still programmed in the radio but set to skip on scan. There is just way to much garbage - from dead keys for hours on end, kerchunking, folks thinking they are GMRS police or professors (take your pick), irrelevant out of state traffic, bad voip connections, etc. Just no real control to be had. All the problems you may see on your local repeater and then some multiplied many times over. Don't really care if they exist or not - just not my thing.
GrouserPad reacted to a post in a topic: Linking GMRS Repeaters
I make my living working this type of scenario (huge ranches) and I’ve never come across a ranch big enough that a single repeater won’t cut it. I mean 50w does over 200miles. Most ranches I’ve been to from central California to Texas and Alabama run 20-40w used motorola repeaters. They are mooooore then enough for a few 1000 acres most cover well into town and adjacent ranches. The main 20w repeater I use every day all day covers the whole valley 100miles long and 60miles wide. I don’t really think linking would add anything in these situations.
Likewise Mark.. I appreciate your opinions as well. And i admit, i have learned a lot from your post.
I always love hearing/reading opinions of others. Especially if they are different than mine, because I may learn something new that could lead to a position change. Friendly chat is always welcome. You have some very good and very valid points. I don't see anything I disagree with. Good analysis, for sure.
from what i see, most people are linking repeaters through the internet because of its simplicity and easy access to equipment. Yes, you can link via radio waves and yes that would be legal, but i doubt it is the most used approach.. So if you want my opinion on linking, i don't agree with it GMRS Linking because they are not managed systems. No frequency coordination's, no consideration to other users wanting to exercise their rights as a GMRS user. And then where i draw the line with the practice is when someone doing it is making money doing it. And yes that is happening, I've spoke with someone that admitted to it. Fortunately they are in the process of decominishing due to the rule clarification.
Amazing what a little piece of Heliax makes. Buy it once, install it once, and never look back.
I don't like the idea of linking any repeaters for the sake of rag-chewing... but there is some practical applications that many seem to overlook. Things like remote receivers for extended talk-in to a high power repeater than can't hear handheld and other low power radios. Or, in an area that needs expanded coverage for emergency response (such as areas prone to flooding or severe snow causing issues) and any number of other situations. Maybe you own a massive farm or ranch and one repeater just won't cover it. Also, people keep saying linking repeaters is illegal and it is not. It is 100% legal. There is, however, a rule against using networks to link repeaters. You can do RF linking over GMRS frequencies (which uses more bandwidth, not a very friendly idea) or you can link repeaters over another radio service that you are licensed for. Also... just because you do or don't like something... that doesn't mean you're right. We are not in a world, or at least we shouldn't be in a world, were the majority bans what they don't like and mandates what they do. That is not freedom. If you don't like how the radio service is used near you, then don't use it.
I've got two maybe three FRN's in my name but with different business names and addresses. I see that happening as a person responsible for FCC stuff at work. But for someone with the same name and address for personal use make no sense not to mention the headache to keep tabs on each one.
I have two FRN's. Got my ham license in 1996 and don't remember anything about FRN's. Don't think they existed, were required yet or if the club I tested at handled it all for me. I let my license lapse in 2006 and when went to get my GMRS license in 2022 I saw I already had an FRN that was registered in 2001 that I knew nothing about and had a old physical address from when I got my ham license. From what I understand, FRN's were not required prior to Dec 2001 for amateur radio so I assume the FCC created one for me based on my license details that was still valid at the time. I didn't know or care to figure out the issue so I just created a new FRN with the FCC. I got my ham license back with a new call, requested and got my old call back under my new FRN with the checkmark box clicked "expired license" as the reason. FCC didn't question any of it.
The most surprising thing was I thought it would take me 2 hours with the bucket truck and I did it in 2 1/2. Usually you are off by a factor of at least double when you do things you aren't use to doing. And the original guestimate of time didn't really include the guy wires other than putting the harness on the mast. We attached 2 to the house which probably took about 20 minutes and then cleanup. I was very happy with how it progressed and the results. With my other antenna, even before the water infiltration issue going from my house to my shop repeater was usually R3-R5. Every once in a while it was R7. I had an wind issue that bent my mounting hardware at the shop repeater and that's when I had the best connection. I ended up turning the repeater antenna 10º and that helped a lot for some reason. Cheap antenna I'm guessing. Now with the new setup from my house it's coming in R9, not quite full quieting. But miles different than before. So between going from 7.2dBi to 9.8dBi gain and the new antenna being 5' taller (raising the center of radiation 2 1/2 ft) it made a world of difference. Now I have to investigate what's bad on the other setup. The antenna or the coax. Hoping the antenna so I can keep the length of coax for future repurposing.
Nice! You should really feel great that you it it behind you and it's working.
There might be some reason why a person would have multiple FRNs, such as to compartmentalize licenses. Just speculation on my part.
thats the 'sand box' i was pointing out
with exact info i would think the FCC would flag that with a auto response. FCC not as bright as i thought.
WSER247 joined the community
WRDT852 joined the community
Just following up with a few pictures and thoughts: 1R-TZx2sXZtB5VeoNzVYUUdh537kbVpeM 1R4AwUegDgP7ah-gv4selGUVxdnPf5BFR 1QvOYWltKxpcItGcxLZCTJskw-9aolGER One is the old Bronco with an MXTA26 antenna. Inside is an RA-87 mounted under the driver's side console above the driver's right knee. Plenty of room there. The other two are the newer F150. It's in pretty good shape, so I'm a little reluctant to make an amateurish attempt at routing wiring through the headliner to set up a rooftop drilled-through NMO mount. Yet that's probably the best option. I'm thinking I might get in touch with an audio installer and let them go at it. I think the roof is probably my best option, though as you can see from the picture I have a sun roof, and I'm not sure how far back the window equipment goes. Thus I don't know how far back I'll have to put the NMO mount to be out of the way while still having some ground plane available. Inside, things are pretty tight. I like the idea of putting a radio under the center console, and then running the head unit up to the sunglass holder overhead, OR to a seat mounted bracket.
WRXD746 started following New Member Check-In
New Member Check-In
WRXD746 replied to SteveGibbs's topic in South Central Tennessee GMRS's Club Forum Page
Checking in from Spring Hill. I'm in the middle of the Thompson Station, Franklin and Rutherford repeater areas. Would really like to know if/when people are on the net and what channel so I can start making contacts. -
WRXD746 joined the community
No, it’s extremely easy with no checking. I did it by mistake (I cannot claim an accident; it was my own ignorance) They both appear in my ULS account. Once I realized my old FRN still existed I simply used it, but the other one still exists.
Yeah, the radio doesn't get the love that some of the Wouxuns and other fairly popular models get. But it's really pretty solid. Very close to the full 40w across the GMRS range (within, say, 5% in my most recent testing). Good sound quality. I kind of wish that it had more than six character channel labels. I like the "left" and "right" side option; I set the left up for scanning repeaters, and set the right up for the channels my family is most likely to use, as well as for open scanning. Signal reports are favorable, though that has a lot to do with the antenna and geography. It has some quirks. From the front panel you can only swap between low and high power. But within chirp there are five power options. I usually set "medium" power in the programming using Chirp, knowing that I can push the power button to get to high if I need it, for example. But I've been using it about a year now in my dusty old Bronco and it has held up great.
