WRUU653 reacted to a post in a topic: Linking GMRS Repeaters
OffRoaderX reacted to an answer to a question: Displaying Channel Name on a UV-5R
SteveShannon reacted to an answer to a question: Displaying Channel Name on a UV-5R
amaff started following Displaying Channel Name on a UV-5R
marcspaz reacted to a post in a topic: Linking GMRS Repeaters
SteveShannon reacted to a post in a topic: Can I use GMRS if i'm close to CANADA
WRUE951 reacted to a post in a topic: Can I use GMRS if i'm close to CANADA
Why are you telling this to OP who already IS a licensed Ham?!? I am convinced that some of the members of this Forum think they get paid by their sheer number of posts!!
the lack of volunteer frequency coordination to manage the GMRS repeater spectrum will kill any chance the FCC will even come close to consider permitting linking. And i honestly don't think it would take to many complaints about bandwidth hogging to awake the FCC sending out a few letters to the BIG abusers. Especially with some of these guys whom blatantly advertise what they are doing while taking money to do it. They don't affect me so i quite making noise about it, but i have been in cities where these guys operate and i can see the problems they create.
...because too many of them tell lies and fairy-tales to make themselves look more important...
Not to mention that this thread is 2 years old.
Marc, while I believe that you had that conversation (I've never had reason to doubt you) and find it interesting, it isn't however the official reason the FCC put forth with their clarification. Thus I think using "sending voice over POTS / Broadband is considered theft of services" as an antiquated idea argument wont go very far. Perhaps that was the genesis of the reason some time ago for not linking GMRS but it's clearly not the reason they put forth recently in writing despite what this engineer says. It certainly is an easier argument to fight in this day and age it just isn't the one I think would sway the FCC because it dosn't address what they have publicly stated as the reason. In addition to violating Commission rules, linking repeaters is not in the public interest. Because GMRS spectrum is limited and used on a shared “commons” basis, the service only works well on a localized basis when users can hear each other and cooperate in the sharing of channels. Linking repeaters not only increases the potential for interference, but also uses up a limited spectrum resource over much larger areas than intended, limiting localized availability of the repeater channels. GMRS and the Family Radio Service (FRS), which share many of the GMRS channels, are intended for individuals such as family members and friends, scouting troops, emergency response groups, and hobbyists to communicate with each other over short distances, directly or through a repeater station. Linking repeaters, via the internet or other networks, undermines the purpose and usefulness of the GMRS and FRS.
WSGP549 joined the community
Nice; appreciate it!
N5JAT joined the community
Northcutt114 replied to WSIC904's question in Technical Discussion
This ^ is correct. It's menu setting 21 & 22. MDF-A and MDF-B, hit the Menu button again to get the cursor down and then push the up or down arrow to toggle between Channel and Name. ETA: I see this has already been answered. -
But that's in Chirp! You asked how to do it after uploading, so the answer was referring to using the radio's menu, i.e. pushing buttons. [Everyone should read the regs carefully yourself, not take advice from random internet people.]
Disclaimer: I'm still on CHIRP Legacy, so this may be different on the current/new CHIRP Open your UV5R file in CHIRP, click the Settings tab, then click Basic Settings, you'll see Display Mode (A) & Display Mode (B), click there, you'll have the choices of Name, Channel, Frequency Select Name, save your file, re-upload, & you won't have to go into the menu settings It's been my experience that on some, not all, radios, that if you change something in the settings through the menu, the radio doesn't/won't keep it If you make your edits in the software & upload them, the edits are remembered & kept YMMV 73
There is no rule or regulation that says these frequencies must be "transmit blocked", and, nobody asked anyway..Stop making up lies, its making you look ignorant.
Thank you OffRoaderX and Uncle Yoda. Its in Basic Settings, under Display Mode A and Display Mode B. Using the pull down menu, the selection is now set to NAME.
On my oldest UV-5R: menu 21 MDF-A, menu 22 MDF-B (A & B correspond to the 2 displayed channels) *All those things you mention need to be transmit blocked to stay w/in regs. And you need a ham license for talking on ham frequencies.
I do not recall the exact name of it, but there is a Menu Setting that you can change to show name, frequency or channel.. Might be called MDF or something like that.. Find it, then set it to 'name'.
Jdavida10 joined the community
Programmed a UV-5R using Chirp. The MURS, FRS, NOAA Weather Frequency, and GMRS and names are displayed on Chirp. In the MR setting, how may the names be displayed on the UV-5R after successfully uploading the image to the UV-5R? Thank you! WISC904
it is an investment,, But not as bad as you think. RVing is all we do for entertainment.. We don't spend money on airfares, ships or hotels, so we look at it as a tradeoff from one or the other. Also, RV's can be written off on your taxes, like a home and i also took advantage of Californias Solar program, 30% off a 1600 watt systems and even qualifed for a PG&E rebate beacause i was temporally living in an RV Park when i installed it ..
WSJP404 joined the community
Not to mention all the Priate VOIP companies whom are actually stealing form the telephone companies and raking in billions with offsohre scams
I 100% agree. The rules are no where near in line with the times and tech of today. If I am paying for a data connection, the ISP really doesn't care what I put over the connection. Otherwise millions of people would be getting fined and sued for using apps like Skype, WebEx, Teams and free internet phone apps from companies like Google. Think about when the internet was young and we had dial-up. We had SpeakFreely in '91, and VocalTec. No one was accused of theft of service then, either.
SeaScholar created a club: General Mobile Radio Users Society
i heard that same theory a few years ago and it came from an AT&T Engineer.. But,, today with all these different Broadband providers, not incluidng the old POT companies, its prretty hard to establish a theft violeation because most ISP could care less, they're only interested in selling their serice. Personaly, because of this, i think the FCC needs to redo their deffination of Plain Old Telephone Companies..
I use both only because i have friends on HAM in some areas we travel.. I use GMRS 70% of the time.. It's nice to have the HAM license and utlize their linked systems which does come in handy at times.. Also, there are a couple RV Parks we travel to where the Park Manager is HAM and reaching out to them comes in very handy and really helps getting into the prime spots.. Yea, if yoiu have an interest to get a HAM license, i would go for it.
No, but that’s a myopic view. The U.S. government has regulations against conducting radio communications on the U.S. side of the border that violate international treaties that they have with other countries. So even though the communications you actually interfere with are in Canada, you can be penalized on the U.S. side.
WSJQ431 joined the community
Where is it written? Nowhere. No one is saying that. OP was asking for a Charleston area repeater and we were just saying that one out in the boonies on Clements Ferry Road isn't really going to help the "Charleston area."
Where is it written a repeater installation by a private citizen MUST cover a population the size of Charleston, SC? Geezz...
Ok so as long as your in the USA Canada can't touch you when it comes to radio communication. I mean they can make all the rules they want but nothing can be enforced because as long the user is on US soil nothing can't be done.
WSEK460 joined the community
I remember using pulse dial and even party lines.
